Fractal Design Nano S Owners Club - Page 13 - Overclock.net - An Overclocking Community
post #121 of 123 (permalink) Old 12-08-2018, 08:49 PM
Rep: 0
Hey guys this is my first time building my pc on my own and i loved this case.
Tho i have 3 3.5inch HDDs and 1 SSD, so i was wondering if this setup would work.
arashn.wili is offline
post #122 of 123 (permalink) Old 07-17-2019, 06:14 AM
Rep: 0
Hi,
I plan on building my first PC with this case. I would put an i7-9700k and a RTX2080 (still not decided on model). I will do a bit of overclocking on the cpu with a cpu cooler but not on the gpu and I plan to use the case stock fans. Some people seem to have concerns high temperatures because of the the GPU/PSU clearance and I was wondering if it's really a problem with the setup I want. Should I consider another case?
thanks for your help!
mikecs333 is offline
post #123 of 123 (permalink) Old 08-11-2019, 02:36 PM
jsbombjack's Avatar
Rep: 0
I have an i7 9700k coupled to a corsair h100x.
I also put in a gigabyte windforce 2080 ti (non-oc version). Made sure of clearance on the gfx by putting in an evga 650w sfx power supply.
Radiator is mounted to the front (with fans as intake) then I have one fan in the bottom as an intake and one at the back as an exhaust.
CPU tops out at 60 when gaming (at most) and the GPU hovers between 75 and 80. Not the best temps maybe, but well within tolerance.
Also found a place that will make a mesh top for the case for cheap, which helps reduce the temps more
Word of the Day: What?
jsbombjack is offline
