Fractal Design Nano S Owners Club - Page 3 - Overclock.net - An Overclocking Community
post #21 of 123 (permalink) Old 05-29-2017, 01:51 AM
fabz88's Avatar
Rep: 1 (Unique: 1)
hi guys this is my build just about to start a custom loop started a build log check it out if you like
fabz88 is offline
post #22 of 123 (permalink) Old 05-29-2017, 07:35 AM
becks's Avatar
Rep: 30 (Unique: 23)
becks is offline
post #23 of 123 (permalink) Old 05-30-2017, 06:21 PM
PC Evangelist
ZealotKi11er's Avatar
Rep: 1794 (Unique: 1173)
I should have bough a SFX PSU for mine so I could use aftermarket cards.
Yamato
(10 items)
Ishimura
Intel Core i9-9900K
ASUS ROG Maximus XI Hero (Wi-Fi)
nVIDIA GEFORCE RTX 2080 Ti FE
G.SKILL Trident Z RGB (4x8GB) DDR4 3200MHz CL14
Samsung SM961 512GB
HGST DeskStar NAS 6TB
EVGA SuperNOVA 750 P2
Gamdias Chione M1A-280R
Fractal Design Meshify C TG
Operating System
Microsoft Windows 10 Pro 64 Bit
Intel Core i7-3770K @ 4.8GHz
ASRock Z77E-ITX
AMD Radeon Vega Frontier Edition
AVEXIR Blitz 1.1 16GB DDR3-2400MHz CL10
SanDisk Ultra II 960GB
Toshiba X300 5TB
EVGA SuperNOVA 750 G3
Corsair H100i GTX
Fractal Design Define Nano S
Operating System
LG OLED55C7P
Keyboard
Cooler Master MasterKeys MK750
Mouse
Finalmouse Air58 Ninja
ZealotKi11er is offline
post #24 of 123 (permalink) Old 06-20-2017, 09:56 AM
Rep: 6 (Unique: 6)
Alright...close to final part list I think. Would the Arctic Liquid Freezer 120 fit on the front panel, top position, with the EVGA hybrid cooler mounted on the front panel, bottom position? And then just add an exhaust fan to the rear? Thought about adding 1-2 intake fans on the bottom as well but don't think I'll really need them.
https://pcpartpicker.com/user/Petehmb/saved/BFNMpg
Petehmb is offline
post #25 of 123 (permalink) Old 06-27-2017, 03:15 AM
bazu08's Avatar
Rep: 0
I have a question for doing a custom loop on my Nano S :
I've made a lot of research but i don't find any answer, so i hope you can answer to me :
Do you know if a EK-XRES 100 DDC (link)+ EK-UNI Pump Bracket (link) would fit on the rear fan slot of the case (without fan) ?
The setup would be :
240mm rad front
240mm top (if no clearance issue with the pumb res combo)
Pump Res Combo on rear fan slot
bazu08 is offline
post #26 of 123 (permalink) Old 06-27-2017, 04:59 AM
becks's Avatar
240mm rad front
If you can wait another week or so... I can give you the exact measurement as I get my last parts for a similar (2x240 rads) Nano S build.
becks is offline
post #27 of 123 (permalink) Old 06-27-2017, 05:09 AM
bazu08's Avatar
Rep: 0
Hello,
Sure ! biggrin.gif you will do the same thing with the pump res combo on the rear fan slot ?
bazu08 is offline
post #28 of 123 (permalink) Old 06-27-2017, 05:15 AM
becks's Avatar
Hello,
I will use the same bracket to hold the pump, and I am using the same reservoir, but mines are separate (pump + res) I don't have a combo as you.
Also I will mount them in the front of the case...with the GPU in between. Res at the top of the rad...Gpu...pump at the base of the Rad, hope it makes sense smile.gif
But once the top rad is in the case I can give you some measurements.
becks is offline
post #29 of 123 (permalink) Old 06-27-2017, 05:17 AM
bazu08's Avatar
Rep: 0
yes it does smile.gif i guess you will go like JayzTwoCents build ?
bazu08 is offline
post #30 of 123 (permalink) Old 06-27-2017, 05:21 AM
becks's Avatar
Have not seen hes build, it's just my "idea" of cramming everything in. Will have to check hes build.
Mine will have some top notch hardware and a 60 mm wide radiator in the front (the XE 240) so I have plenty to think about when it comes to planning and installing things in there..also will have to take in consideration all that hot air that needs exhaustion so I really need that back fan pushing things out...
becks is offline
