Phanteks Enthoo Evolv Shift/Shift X Owners Club - Page 3 - Overclock.net - An Overclocking Community
post #21 of 541 (permalink) Old 10-19-2017, 03:54 PM
2 Easy
nyk20z3's Avatar
Rep: 70 (Unique: 52)
Originally Posted by Schnitter View Post
This case is just too pretty. I have an 850 SeaSonic gold 160mm that I don't want to downgrade to a 600 Corsair because I don't want to hamper my overclocking.
Am I overreacting? Or are components so efficient now that 600 is just as good as 850 for overclocking?
Your not downgrading you wont use anything close to 800 watts a any given time you will be fine.
nyk20z3 is offline
post #22 of 541 (permalink) Old 10-20-2017, 02:54 AM
qiUip's Avatar
Rep: 1 (Unique: 1)
Beautiful build nwkrep82. Def going to take some inspiration for my loop design. I think I’m going to go for a single 280 though (as I have one already) and an ek DCC pump/res combo that I will mount horizontally over the PSU, plus some Noctua Industrial PPC fans with the Phanteks Halos. I might go the extra mile and custom cut some ventilation into the front panel too (water jet cutter), but really not sure if I can manage that!
Hope I can get started on it this year, but more likely early next year. :/
qiUip is offline
post #23 of 541 (permalink) Old 10-20-2017, 05:16 AM
Linux Lobbyist
nwkrep82's Avatar
Rep: 16 (Unique: 13)
Originally Posted by nyk20z3 View Post
I would have went with the SE rads to give yourself more breathing room but great work its similar to my build.
Hey! How have you been? I'm the guy that purchased your Lian Li PC05SX, with 240 rad, and EK Asus Impact Monoblock.
This build mostly transferred from the later revision of the Lian Li build. I actually did a mod on the Lian Li case to fit a 38mm thick 240 rad...The SE I got from you really wasn't giving me the ideal amount of cooling capacity I wanted for an overclocked TItan Xp and 7700K. So I went with the PE rad. That rad just transferred to this build.
My idea was to push the limit of what can fit in this case (of course with the aesthetics and performance to match). I have other ideas for this case to push it even further...
I definitely appreciate inspiring you...as I have been inspired by others in the community.
The pump/res combo I used was from a previous build this replaced. I actually have another idea for a custom pump/res combo that I'm still working out all the details.
A custom cut front panel would be awesome and definitely add to overall air flow in this case. It's an idea I have also been thoroughly investigating.
nwkrep82 is offline
post #24 of 541 (permalink) Old 10-20-2017, 07:39 AM
Aggrotech's Avatar
Rep: 10 (Unique: 9)
tbh i think it'd be juuuust right if the vertical rad wasnt push/pull. i mean, its still amazing and very similar to my mock up but to me the push/pull is just too much.
RIP.
2017 OCN best OCN.
Aggrotech is offline
post #25 of 541 (permalink) Old 10-21-2017, 10:30 AM
xP_0nex's Avatar
Rep: 25 (Unique: 21)
Specs in sig. Just waiting for a 4790k from my buddy.
xP_0nex is offline
post #26 of 541 (permalink) Old 10-21-2017, 06:40 PM
Archer S's Avatar
Rep: 17 (Unique: 15)
Im seriously thinking about getting this case and cramming a whole lot of liquid cooling in it. But in order for my plans to work i would need to remove the internal divider between the motherboard and the psu area. The thing with the phanteks logo that opens to hide the cables.
Is that part removable or is it riveted on?
Thanks in advance
Archer S is offline
post #27 of 541 (permalink) Old 10-21-2017, 07:53 PM
xP_0nex's Avatar
Thanks in advance
Took a quick glance and looks riveted.
xP_0nex is offline
post #28 of 541 (permalink) Old 10-21-2017, 09:07 PM - Thread Starter
CaptainZombie's Avatar
Rep: 33 (Unique: 27)
I am quickly learning these cables for the SF600 are the worst, they are so damn stiff.
I've worked in some PITA ITX cases in the past, but I feel like this one if you don't have the right hardware can be just as tough even though it is a bit bigger in size. For one, if you have a mobo that can use 1 or even 2x M.2, you will be golden. My SATA cables will only reach to use 2 HDD's in this case, and those are very tight. I'll probably have to put this build I think on the back burner till I figure out what I am doing with my system hardware.
I did try the 1070 Strix OC, it does fit without having to bend the bracket which is nice.
CaptainZombie is offline
post #29 of 541 (permalink) Old 10-22-2017, 07:29 AM
Linux Lobbyist
nwkrep82's Avatar
For the Corsair SF600, I'm actually using a combination of 2 of their premium sleeved cable kits (which I happened to already have on hand from previous builds). I really am not a fan of the flat cables.
Corsair CP-8920144 - This is their standard length starter kit...the 24-pin and the CPU 4+4 pin are long enough to reach with the route I wanted the cables to run.
Corsair CP-8920202 - This is their SF premium cable kit (shorter cables) ...I used the pcie and sata cables from this kit.
Of course, I have a Shift X, so cable length requirements may be different if your in a Shift and the orientation of your GPU, motherboard, desired cable routing, etc.
nwkrep82 is offline
post #30 of 541 (permalink) Old 10-22-2017, 07:37 AM - Thread Starter
Thanks! I’ll take a look at both of these kits then. What did you do about any hard drives and/or sSDs? The SATA connectors bend the heck out of the ssd connectors. I was looking through some of the builds and looks like many are just using M.2 drives. Yeah I’m using standard Shift. I love the case but damn is there some rather difficult maneuvering in this one and I’ve even built systems in the SilverStone Sg13 which wasn’t easy either but not as bad as this case.
