Phanteks Enthoo Evolv Shift/Shift X Owners Club - Page 49 - Overclock.net - An Overclocking Community
post #481 of 484 (permalink) Unread 03-19-2019, 02:18 AM
GuniGuGu's Avatar
Rep: 0
Quote: Originally Posted by PetrosK View Post
Phanteks evolv shift
The best itx case that had potential but they didnt made it right .
The gap between the front aluminioum panel and the case is 20mm , which means the noctua 15mm fans would be SWEEEEEEEEEEEEEEEEEET to be put there . IF ONLY the panel had ventalation
https://imgur.com/BKQiKpk
https://imgur.com/Wwj35te
https://imgur.com/V1U7fZw
100% It's soo annoying phanteks even showed off those mesh panels they were working on at computex last year, but have since scrapped them. They would've FIXED EVERYTHING!
So I went down a similar path. Dual AIO's because I thought that was my only option in this case to keep the 8700k and 2080ti cool... Only to discover how much the front sucks with ventilation... so I just got the front cut to allow for ventilation. The dude left a little scratch in the top right, but oh well.
I'm wondering, can I go push pull with a slim fan on the front now? Is there enough space for a fan and the front panel? Has anyone tried this?
Main Evolv Shift
HTPC
Intel - Core i7-8700K 3.7GHz 6-Core Processor
Asus ROG Strix Z370-I Gaming Mini ITX LGA1151 Motherboard
GeForce GTX 1070 8GB Founders Edition Video Card
G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory
Intel - Pro 6000p 1TB M.2-2280 Solid State Drive
Silverstone - 600W 80+ Gold Certified Fully-Modular SFX Power Supply
Corsair - H80i v2 70.7 CFM Liquid CPU Cooler
Phanteks - ENTHOO EVOLV SHIFT Mini ITX Tower Case
Acer - Predator X34 34.0" 3440x1440 100Hz Monitor
Dell - P2217H 21.5" 1920x1080 60Hz Monitor
Keyboard
Logitech - G613 Wireless Standard Keyboard
Mouse
Logitech - G603 Wireless Optical Mouse
Audio
Astro - A50 - Black 7.1 Channel Headset
Intel Core i5-3470 3.2GHz Quad-Core
Gigabyte - GA-Z77X-UD5H ATX LGA1155 Motherboard
EVGA - GeForce GTX 960 4GB Superclocked Video Card
A-Data XPG V1.0 16GB (2 x 8GB) DDR3-1600
Plextor - M5M 256GB mSATA Solid State Drive
4x Western Digital Caviar Green 3TB 3.5" 5400RPM
3x Western Digital - Red 6TB 3.5" 5400RPM Internal Hard Drive
Corsair CX-600W
Silverstone - GD08B (Black) HTPC Case
Operating System
Microsoft Windows 8.1
LG 55LM6700 LCD TV
Keyboard
Logitech k400r
Audio
Sony 5.1
GuniGuGu is offline
post #482 of 484 (permalink) Unread 03-24-2019, 04:17 AM
qiUip's Avatar
Rep: 1 (Unique: 1)
Shift X Watercooled
Finally got around to watercooling my build that started off in post #6 https://www.overclock.net/forum/50-s...l#post26398028
Changed only a few things like adding an extra 1TB m.2 Samsung 970 Evo, removed all the 2.5" SSDs and upgraded the GPU to a 2080Ti. All the rest is the same as in the original post. Watercooling parts are all EK other than the rads which are HWL GTS (240mm+120mm) and the GPU block which is the Phantheks Glacier Strix 2080Ti. I did a few nice custom bales to connect the pump and the fan splitter and sleeved everything else other than the PSU cable set which was made by To-The-Wire.
This is my first hardline build and I had a strict deadline of 3 days to complete it - so things aren't 'prefect'. Unfortunately, when I first replaced the distilled water in the loop which I was running for a couple of days with a premixed clear coolant I had a bit of a disaster and the coolant foamed up and really messed up the loop. I've since flushed it with loads and loads of distilled water as I had no time to take the loop apart and deep clean every component (which is what is really required) so please excuse the slight staining in the blocks, res and tubes.
P.S. OS is Manjaro Linux
Name:	Photo 24-03-2019, 09 41 12.jpg
Name:	Photo 24-03-2019, 09 42 41.jpg
Name:	Photo 24-03-2019, 09 41 25.jpg
Name:	Photo 24-03-2019, 09 45 06.jpg
Name:	Photo 24-03-2019, 10 02 27.jpg
Name:	Photo 24-03-2019, 10 10 59.jpg
Name:	Photo 01-03-2019, 10 21 40.jpg
Name:	Photo 04-03-2019, 18 50 52.jpg
Name:	Photo 02-03-2019, 09 29 51.jpg
Name:	Photo 15-03-2019, 11 31 02.jpg
Name:	Photo 24-03-2019, 09 45 32.jpg
Name:	Photo 24-03-2019, 10 10 48.jpg
qiUip is offline
post #483 of 484 (permalink) Unread 03-26-2019, 01:32 AM
GuniGuGu's Avatar
Rep: 0
Does anyone know if you can mount either 120 or 140mm phantek halo's to the front of the case is there enough space? what about a dust filter as well? I just had the hexagons cut into the case and next step is controlling the dust and maybe having some light shine through those holes
Main Evolv Shift
HTPC
Keyboard
Mouse
Audio
Corsair CX-600W
Operating System
LG 55LM6700 LCD TV
Keyboard
Logitech k400r
Audio
Sony 5.1
GuniGuGu is offline
post #484 of 484 (permalink) Unread 03-26-2019, 04:44 AM
Trinergy's Avatar
Rep: 3 (Unique: 2)
Quote: Originally Posted by GuniGuGu View Post
Does anyone know if you can mount either 120 or 140mm phantek halo's to the front of the case is there enough space? what about a dust filter as well? I just had the hexagons cut into the case and next step is controlling the dust and maybe having some light shine through those holes [IMG class=inlineimg]/forum/images/smilies/tongue.gif[/IMG]
I was able to fit one on the bottom but the motherboard tray is too offset to the front to fit another in the top position. If you use slim fans it should fit.
-=>Trinergy<=-
Computing since the C64, Overclocking since '92 (486SX2 50 -> 66)
Trinergy is offline
