Phanteks Enthoo Evolv Shift/Shift X Owners Club - Page 51 - Overclock.net - An Overclocking Community
post #501 of 520 (permalink) Old 08-15-2019, 07:59 AM
Rep: 0
Quote: Originally Posted by tubbed View Post
Hi All,
Thought I'd throw up some progress pictures of my shift build. Really only waiting on hardline fitting/tubing now. Looking forward to see if this setup works, I'm coming from AIO cpu and air-cooled 2060 strix, cpu was fine but gpu would eventually choke.
This is a HTPC/gaming rig for the lounge and sits horizontal on a shelf, I'm pulling air in through the I/O side and pushing it down the front panel (sealed up the mesh and chassis holes) and into the 1st rad, then ducting the warm air into the second rad and out the bottom via the 2nd 140mm static fan. The "hope" is the cool air and removal of hot air within the case will offset the warm air the second rad receives and maintain a decent loop temp. Toying with the idea of adding a cutout for a slim 120mm where the 3.5" drive sits but will wait to see how it runs, hoping to have one 140mm idling through netflix sessions.
Specs;
2700x
b450 strix
zotac 2070 mini
silverstone psu
2x140 nf-a14
m.2 slots full
alpha-cool rads, gpu block, solo pump/cpu and fittings
printed duct and a low-profile 120 to 140 adapter for the bottom fan.
Will post completed photos and hopefully some decent thermals both stock and oc.
Edit: the 3D image it the latest concept, the 2nd picture was the 1st, using the full length strix that required a notch in the duct, it could have worked with a custom riser cable but in the end it just made life easier upgrading to the mini.
Cheers
Please share the 3d file, thanks
jonacanar is offline
post #502 of 520 (permalink) Old 08-15-2019, 04:18 PM
Rep: 1 (Unique: 1)
I'm plumbing it up this weekend, if it works I'll post the files for sure.
tubbed is offline
post #503 of 520 (permalink) Old 08-16-2019, 11:25 PM
Rep: 0
I have an EVGA 2-slot 1080 Ti.
I know this case is prone to heat issues with open air cards, so I was thinking of laying the case on its side and removing the glass from the GPU side,
to let it suck in cool air from below.
Could any current Shift owners give me their thoughts on this?
TheLeadPontoon is offline
post #504 of 520 (permalink) Old 08-17-2019, 06:04 AM
Rep: 0
I think the best way to cool down that card will be adding AIO to the GPU, maybe the nzxt bracket, or try made some custom panels as me. With the glass panels on, the system will overheat, maybe taking out one will help but consider the dust.
post #505 of 520 (permalink) Old 08-18-2019, 06:25 PM
Rep: 1 (Unique: 1)
ahhh little optimistic on the plumbing, took all weekend just finishing the cabling (never never again)
Anyway few more progress photos, got one piece of HT in at least!
tubbed is offline
post #506 of 520 (permalink) Old 08-18-2019, 06:42 PM
Rep: 0
I just made some modding, I set a 140mm fan in the bottom to suck air, one 120mm fan with a rad intake, one 120mm in the middle to help my psu to cool down in stress situations, mesh panels help with the gpu with stock cooler that is facing forwards Attachment 1Click image for larger version
Enviado desde mi iPhone utilizando Tapatalk
post #507 of 520 (permalink) Old 08-20-2019, 05:08 AM
Rep: 0
Please don’t forget to share the 3D file thanks
post #508 of 520 (permalink) Old 08-21-2019, 02:01 AM
Rep: 0
The 3D model of the case
Is anyone has the 3D model file of the Evolv shift case ? recently want to build an itx but so struggle about the AIO or custom water loop due to space
Snieprbb is offline
post #509 of 520 (permalink) Old 08-21-2019, 07:07 AM
RaduV's Avatar
Rep: 5 (Unique: 5)
Upgraded my 2600X to 3600X and the 1080 hybrid to a 2080+Kraken G12 thanks to good old amazon . Stacked the gpu rad over the cpu one with a rad bracket, gpu temps up to 77 in heaviest work loads, usually around 60.
https://photos.google.com/share/AF1Q...1ITzVkT1VXYzBn
RaduV is offline
post #510 of 520 (permalink) Old 08-27-2019, 08:56 PM
Rep: 1 (Unique: 1)
#update
Leak down test next, seriously difficult to get the bends with such limited space.
tubbed is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
