Phanteks Enthoo Evolv Shift/Shift X Owners Club - Page 52 - Overclock.net - An Overclocking Community
post #511 of 531 (permalink) Old 08-29-2019, 11:39 PM
RaduV's Avatar
Rep: 5 (Unique: 5)
That's a very planned job right there, carefully executed.
RaduV is offline
post #512 of 531 (permalink) Old 09-01-2019, 05:47 PM
Rep: 1 (Unique: 1)
cheers radu,
all plumbed up and live, pending OS install. Not quite as planned out as it could have been, turns out the pump inlet/outlet is not what I had hoped (or even considered TBH), the GPU is being feed through into the outlet...shize. I'm assuming you can't just reverse a pump impeller and this means re routing the tubing, maybe I just roll with it and see how it runs??
tubbed is offline
post #513 of 531 (permalink) Old 09-02-2019, 07:15 AM
Rep: 0
Quote: Originally Posted by tubbed View Post
cheers radu,
Your cable management is great, can’t even see where you put all the cables, what’s parts are you using in the water cool setup?? Maybe some quote of all ?
Enviado desde mi iPhone utilizando Tapatalk
jonacanar is offline
post #514 of 531 (permalink) Old 09-02-2019, 04:38 PM
Rep: 1 (Unique: 1)
it's not the prettiest cable management just the shortest possible run between each component, no space for combs literately, it took a ridiculous amount of time and blood but really helped with space and airflow imo.
Its all alpha-cool, 2 x 120 rads, LT solo, 5 x 90 degree & 5 x straight and a huge pile of scrap 10/13 tubing.
Managed a little bit of testing last night, Asus Tweaker took the little mini straight to 1980mhz, just with OC scanner which made me smile! Will look for 2k manually but TBH if I can maintain high 1900's in Metro I'll be a happy camper!
Furmark got the CPU (auto OC) to 70 max and the GPU (OC) to 58 max, the loop temp maxed out at 44 both fans @ 1200rpm.... I have low noise adapters on both atm, its a touch louder than the original setup at idle no joke! This was with all panels and glass on, laying horizontal.
This wasn't a heat saturation test yet, want to play around with the fans and potentially dial back the CPU (peaked @ 4.1) as I favor GPU temp and noise more than anything. At the moment I have both fans on the CPU header but think I'll move one to the chassis (on low duty) and leave the other on the cpu for high temp/max load and maybe take off the LNA if required?
So far quietly optimistic even with the backwards GPU flow but will wait for a long run on a synthetic before I celebrate too much.
Cheers
tubbed is offline
post #515 of 531 (permalink) Old 09-09-2019, 03:37 AM
azkaban3000's Avatar
Rep: 0
Here some photos of the new Shift Air. Mine is on the way eta 3 days.
https://imgur.com/gallery/Nv6kTsQ
azkaban3000 is offline
post #516 of 531 (permalink) Old 09-09-2019, 08:05 AM
Rep: 0
Where did you get it ?? It didn’t show in the phanteks site yet
post #517 of 531 (permalink) Old 09-10-2019, 06:15 AM
Rep: 0
It already available in Vietnam. You could google the model: PH-ES217A_AG. From what I searched it also available in China, Australia and Singapore
post #518 of 531 (permalink) Old 09-14-2019, 05:43 AM
Arnavut's Avatar
Rep: 0
did they release only shift air and no shift X air? damn I was waiting for only the X mesh panels...
Arnavut is offline
post #519 of 531 (permalink) Old 09-14-2019, 02:36 PM
iMik's Avatar
Rep: 0
They have no plans for Shift X air.
iMik is offline
post #520 of 531 (permalink) Old 09-15-2019, 12:18 PM
Rep: 0
Temp is much better in Shift Air.
Setup 1: GPU fan facing inward. CPU rad at the bottom with a ML120 as intake. A default Phantek 140m fan exhausts air in the top front, one ML120 as intake in bottom front.
Setup 2: GPU facing outward. Other fan as setup 1, except default Phanteks 140mm has to be removed to fit the VGA.
Here's the temp result: (tested with Assassin Creed Origin benchmark)
Setup 1: CPU idle at around 50, load at 56. GPU idle at 50, load at 70
Setup 2: CPU idle at around 42, load at 52. GPU idle at 67, load at 59.
