SG13B-Q Front mount PSU, R7 1700, RX580. (stupid pic heavy) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 26 (permalink) Old 02-12-2018, 10:27 PM - Thread Starter
Max78's Avatar
Rep: 52 (Unique: 45)
Got the front cover printed. It looks pretty good, but it has some issues so I opted to not finish it with paint and a good sanding. I will make some adjustments here and there and make another. Plus it looks much better in person, the camera brings out all the little details you wouldn't otherwise see. The power button didn't fit like I had hoped, but its out now so I can model the switch itself and make the next one work.
The hard drive area has little tabs that lock the drive into place without the need for screw. I did have to do some trimming on the front of the metal case because it was protruding into the HDD circuit board.
A little hot glue here and there was used to secure the existing LED to the side of the vent, It was also used here and there to help with cable management. The rats nest on top was re-organized in an attempt to clean it up a little bit.
Overall it looks prett neat and I'm quite happy with the results so far. Now I can start designing the fan mount and supporting pieces.
CPU: R7 1700 Memory: Patriot Viper 4 @3200mhz Video Card: Red Devil RX 580 8GB Motherboard: ASRock Fatal1ty B350 ITX
SSD:
Crucial MX300 275GB SSD: Samsung 860 Evo 500GB Case: Silverstone SG13
Monitor: 24" AOC 1080p 144hz VA (AOC C24G1)
Max78 is offline
post #22 of 26 (permalink) Old 02-13-2018, 12:30 AM
FstokA's Avatar
Rep: 0
This is awesome.
Any changes in temps?
Would the hdd restrict the air from psu?
how thick is it compare to the old cover?
how long did take to print?
is it sturdy and hold good to the case?
this is really cool man.
FstokA is offline
post #23 of 26 (permalink) Old 02-13-2018, 09:44 AM - Thread Starter
Max78's Avatar
I haven't run any benchmarks or anything yet but I do notice an improvement in idle temps. Before my GPU was around 55° and would creep up to 60° where the fans would then kick on and drop back down to 55°, that cycle would continue every 3 to 5 minutes or so. Now it will idle for over an hour and the GPU is at a happy 40°. My GPU fans don't spin below 60°
The CPU idle temp is a good 10° cooler as well. I will work on adapting the F12 to the CPU this weekend and start doing some tests.
The HDD has about 3/8" (9mm) air gap from the PSU fan and there is more ventilation on both sides of the PSU so there is plenty of area to draw air from. I can feel a nice draft still coming from the bottom of the PSU so it seems to be flowing good still.
The new cover is approximately .625" (16mm) thicker overall than the old cover.
On my printer at home it took 14 hours with conservative speeds, there is a lot of areas I could have thinned out to make it print faster with less material, but I wanted a sturdy part as well.
It's just as sturdy if not sturdier than the old one that came off, it has significantly more material everywhere. The current weak point is where the screws attach the cover to the case, the layer orientation is not optimal for the stress direction. I think the next one I print I will make those parts separate so I can print them with a more optimal layer direction.
SSD:
Max78 is offline
post #24 of 26 (permalink) Old 02-13-2018, 10:35 AM
FstokA's Avatar
Rep: 0
20c in gpu and 10c in cpu... maaan that's significant.
folks over SFF club would love your work, the mod will add you to a list of approved sffpc.
https://www.overclock.net/forum/50-sm...-sff-club.html
FstokA is offline
post #25 of 26 (permalink) Old 02-13-2018, 01:28 PM - Thread Starter
Max78's Avatar
Thanks for the link! Went ahead and posted over there.
SSD:
Max78 is offline
post #26 of 26 (permalink) Old 02-23-2019, 06:39 AM - Thread Starter
Max78's Avatar
Well I was heading out to field service for my company when my wife jokingly said "take your computer its small". . . So i did.
I took it carry-on and TSA didnt even look at it twice. There were people behind me who thought it was absurd and needed to voice their opinion and that was really the only thing. I have a laptop I usually take but how can I pass up a good challenge!
Sent from my SM-G900P using Tapatalk
SSD:
Max78 is offline
