Streaming PC ? discussion - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 05-26-2018, 11:25 PM - Thread Starter
Linux Lobbyist
Rep: 0
i recently picked up an Alienware Alpha R1 with the i5-4590t and these boogers decent powerful pcs but im wondering how i would use the Elgato hd 60 pro with it im aware of the cables and stuff but let me hear some ideas guys . Im stoked to make this happen
DanTheMAnrockz is offline
post #2 of 13 (permalink) Old 05-26-2018, 11:35 PM
Iconoclast
Blameless's Avatar
Rep: 3135 (Unique: 1869)
Given that this system has a fairly modern NVIDIA GPU, I'd probably try using NVENC to encode video for streaming and see how that does, before resorting to a dedicated capture card, especially since the system has no internal expansion slots.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #3 of 13 (permalink) Old 05-26-2018, 11:50 PM - Thread Starter
Linux Lobbyist
Rep: 0
nvenc makes it look a tad grainy i already have the hd60 pro and the hd 60 but the hd60 pro offers better quality im just estatic to try this what im wondering is what cable would i use ive looked all over but no clear answers yet it seems no one has tried this wouldnt the egou ordeal work?
post #4 of 13 (permalink) Old 05-26-2018, 11:52 PM - Thread Starter
Linux Lobbyist
Rep: 0
ive been streaming for quite some time now and i want something small like this for a dedicated streaming pc
post #5 of 13 (permalink) Old 05-26-2018, 11:53 PM - Thread Starter
Linux Lobbyist
Rep: 0
i have a dedicated gaming pc as well so i shouldve clarified that im doing a dedicated streaming and a dedicated gaming setup
post #6 of 13 (permalink) Old 05-27-2018, 12:12 AM - Thread Starter
Linux Lobbyist
Rep: 0
what are your suggestions?
post #7 of 13 (permalink) Old 05-27-2018, 02:00 AM
Iconoclast
Blameless's Avatar
Egou? EGPU?
You might be able to connect the capture card the way you would an external GPU, but you'd probably be better off with a better external GPU.
However, since you've already got the capture card and seem to prefer it's video quality, the setup, if it's workable, should not be particularly complex. You attach the capture card the same way you would the external GPU--most solutions just convert the PCI-E lane(s) from the internal mini-PCIE slot to an external physical 16x slot--then passthrough the HDMI output from the system, through the capture card, then out to your display.
It should work the same way as on any other desktop, you simply have a more unconventional way to attach the capture card to the available PCI-E lanes.
Well, I would try playing with NVENC setting in OBS studio, but if you can't get the encode quality on par with the capture card, go ahead and use something like the EXP GDC to connect it to your R1.
post #8 of 13 (permalink) Old 05-27-2018, 02:37 AM - Thread Starter
Linux Lobbyist
Rep: 0
Egou? EGPU?
with the EXP GDC i wouldnt need a power supply right? since its such a low power consumption?
post #9 of 13 (permalink) Old 05-27-2018, 02:38 AM - Thread Starter
Linux Lobbyist
Rep: 0
there are no pcie lanes just the m.2 2230 its where the wireless/bluetooth card sits
post #10 of 13 (permalink) Old 05-27-2018, 02:51 AM
Iconoclast
Blameless's Avatar
Still need a way to power the slot, so you'd still need a power supply.
Edit: the 12v DC input from the AC adapter/power brick should be sufficient. So, no you probably won't need a separate ATX power supply.
That's PCI-E.
