Ex-Box One S - Page 2 - Overclock.net - An Overclocking Community
Ex-Box One S
post #11 of 38 (permalink) Old 07-25-2018, 11:56 AM - Thread Starter
Draelren's Avatar
Rep: 0
Got the other two side posts in position.
Worked on the first top piece to the frame, and now the sides and top are curing until 9am tomorrow. Will then proceed to do the other 3 pieces along the top - then I can clean up my work and move onto paint.
Draelren is offline
post #12 of 38 (permalink) Old 07-25-2018, 07:26 PM
Ragsters's Avatar
Rep: 218 (Unique: 203)
Very interesting!
Tiny Dancer
(19 items)
Son's Build
(16 items)
White Noise (R.I.P)
(31 items)
i7 6800k
Asrock X99e-itx
RX Vega 56
Corsair Vengence LPX
SAMSUNG 960 EVO M.2 500GB NVMe
Corsair SF600w
Corsair H75
NF-F12 industrialPPC-2000 PWM
Ncase M1 V5 (Silver)
Operating System
Windows 10
BenQ 32" IPS 4K (BL3201PH)
Keyboard
Vortex Poker 3 (White with White LED)
Mouse
Logitech G102 Prodigy (Matte White)
Mouse
Glorious PC Gaming Race XXL Extended
Audio
Soundblaster Omni 5.1
Audio
Sennheiser HD 598
Audio
kanto Yu2 Desktop Speakers (Gloss White)
Audio
Kanto Sub 6 (Gloss White)
AMD Phenom II X6 1055T
Gigabyte 880GMA-UD2H
Asus GTX 660 Ti
Corsair Vengeance Pro
PNY SSD CS1311
Samsung SSD 830
Samsung Spinpoit F3
Antec Neo Eco 520C
Corsair H50
Silverstone FT03B
Operating System
Windows 7 Home Premium 64bit
Samsung SyncMaster 220wm
Keyboard
Coolermaster Quickfire Rapid
Mouse
Steelseries QcK
Mouse
Zowie Mico
Audio
Logitech LS21 2.1 Stereo Speakers
i7-3770K
Asus Maximus V Formula
VisionTek Reference 7970
Diamond Reference 7970
Corsair Dominator-GT 16GB (4x4GB)
SanDisk Extreme Pro
Western Digital Black 640GB
Seasonic X650 (Custom MDPC Sleeve)
Swiftech MCP35X DDC Pump - White Top
XSPC AX360 Triple 120mm Radiator - White
EK-Supremacy Clean CSQ - Nickel Plexi
Bitspower Silver Shining Fittings
7 x Scythe Gentle Typhoons D1225C12B4AP-15
Bitspower Acrylic DDC Pump Top
Bitspower DDC Top Upgrade Kit
Bitspower DDC / MCP35x Pump Heatsink - White (BP-DDCPC-WH)
2 X EK-FC7970 Nickel CSQ GPU Block
2 X EK-FC7970 Backplate - Black CSQ
EK-FB KIT ASUS M5F Nickel Motherboard Block
XSPC AX480 Quad 120mm Radiator - White
EK-Ram Monarch X4 CSQ - (EN) Nickel Plexi
CaseLabs Merlin SM8 (All White)
Operating System
Windows 7 64bit Home Premium Upgrade
Achieva Shimian Lite "Perfect Pixels"
Keyboard
Das Keyboard Model S Professional
Mouse
Mionix Avior 7000
Mouse
SteelSeries QCK Mini
Audio
Klipsch Pro Media 2.1
Audio
Sennheiser 598
Audio
Creative Soundblaster Z
Other
NZXT LED Kit - 2 Meter - White (CB-LED20-WH)
Ragsters is offline
post #13 of 38 (permalink) Old 07-27-2018, 02:05 PM - Thread Starter
Draelren's Avatar
Rep: 0
Got the rest of the frame taken care of yesterday.
Today was planning more of the interior components. Got the motherboard tray sorted out more. Added a center brace down the middle.
More planned out. The issue now is figuring out fill/drain port, and the pump. I believe I've found a pump that fits, but it's a bit spendy to buy, after already purchasing the power supply today.
Draelren is offline
post #14 of 38 (permalink) Old 07-30-2018, 04:12 PM - Thread Starter
Draelren's Avatar
Rep: 0
Since the frame was solidified last week, this morning I drilled the last holes needed, and then got onto painting the frame.
From there I test mounted the radiator, fans, and fittings once more. Fit snugly.
While I was test fitting, I had also sprayed the motherboard tray with the paint/primer also. Here we go with the progress as I had to leave it this afternoon.
Draelren is offline
post #15 of 38 (permalink) Old 08-02-2018, 01:07 PM - Thread Starter
Draelren's Avatar
Rep: 0
Not too much of an update today, but I'm headed out for a family vacation over the weekend for my sons birthday. Figured I would get an update up before I left.
Here is the frame set in the console to give an idea of how it will work when done.
Draelren is offline
post #16 of 38 (permalink) Old 08-08-2018, 02:16 PM
Newb to Overclock.net
mouacyk's Avatar
Rep: 167 (Unique: 124)
Looking good so far. Best of luck!
CPU: Q6600 X5470 2100T 1680V2 9900K
GPU: 8800GT 9800GTX+ 750Ti 1080Ti
RAM: 2x8GBTZ
Gentoo64 in Water
(14 items)
LGA775 X5470
(6 items)
9900K 5GHz 1.224v
EVGA Z370 Micro
MSI 1080TI GXEK 2100.5/12627
16GB Trident Z 4000C16
970 EVO 500GB
Seasonic X850 Gold
480mm Radiator Custom
Silverstone FT03
Operating System
Windows 7 Ultimate 64-bit
Operating System
Gentoo Linux 64 Multi-Lib
Acer Predator XB271UH 165Hz
Keyboard
Logitech G710+
Mouse
Logitech G502
Audio
Sound Blaster Z
X5470 4GHz (stock v)
GA-EP45-UD3P
EVGA 9800 GTX+ 512MB
8GB 4x2GB GSkill 1066MHz DDR2
XSPC Rasa, D5 + Res, 240mm Rad
Lian-Li PC7-HX
mouacyk is offline
post #17 of 38 (permalink) Old 08-09-2018, 04:00 PM - Thread Starter
Draelren's Avatar
Rep: 0
Had a long weekend and had to deal with a death in the family - but now back finally with some updates!
Got the motherboard test mounted again, and worked on balancing the components to make sure it will be steady upon completion.
The power supply, power brick, and sleeving / wires showed up today, so I got a chance to break out the stock cables before the custom ones get made - and do a test of the hardware.
The entire build will be using less than 100w or so estimated on full load, so I went with some 18 AWG wire to help with the cramped space, and then some Teleios sleeving in 'Polar White' and 'Acid Green'.
Test fitting PSU.
Draelren is offline
post #19 of 38 (permalink) Old 08-15-2018, 11:56 AM - Thread Starter
Draelren's Avatar
Rep: 0
Work started on the sleeving this week, which is being done by a coworker who also runs his own modding business as 'Tek by Design'.
The 24 pin will likely be the shortest and most complicated one in the world.
Draelren is offline
post #20 of 38 (permalink) Old 08-15-2018, 11:59 AM
pez
pez's Avatar
Rep: 633 (Unique: 488)
This gets better with every post. Will you be putting a GPU in this? I looked through the posts again and didn't see anything with you clarifying or mentioning that.
>>>[Official] OCN Headphones and Earphones Club
Trndsttr
(17 items)
DooMSlayeR
(15 items)
OverCoaster
(14 items)
2700X [4.2GHz]
ASUS ROG Crosshair VI Hero [WiFi AC]
Titan X Pascal [Hybrid]
G.SKILL TridentZ 3600 [16GB]
Samsung 960 Evo [500GB]
Mushkin Enhanced Reactor [1TB]
EVGA 550 G2
Celcius S36 + F120MP
Meshify C
Operating System
Windows 10 Professional [x64]
Acer Predator X34
Dell E2417H
Keyboard
Razer Huntsman Elite
Mouse
Finalmouse UL Phantom
Mousepad
Razer Gigantus
Audio
Schiit Bifrost Uber + Schiit Asgard 2 + HEXv2/HD700
Audio
Razer Leviathan 5.1 Soundbar
1700
Asus Strix B350-I
Sapphire Vega64
G.SKILL TridentZ 3200 [16GB]
Kingston A1000
Crucial P1
Corsair SF600
Noctua L9a
A4-SFX
Operating System
Windows 10 Pro [x64]
Sony X900E
Keyboard
Logitech K830
Audio
Sherwood RX-4109
Audio
Cerwin Vega D-3
Other
Xbox Elite Controller [White]
i7 7700K [4.7GHz]
ASUS Z270i STRIX
ASUS GTX 1070 FE
Corsair Vengeance LPX 3K [16GB]
Kingston HyperX Savage [480GB]
Corsair SF600
Corsair H75 + F120MP
NCASE M1 [v5]
Operating System
Win 10 Pro [x64]
Dell S2716DGR [144hz]
Keyboard
HHKB Pro v2 [White]
Mouse
Logitech G502
Mouse
SS QcK Heavy
Audio
AudioQuest Dragonfly Black + Sennhesier HD650
pez is offline
