Ex-Box One S - Overclock.net - An Overclocking Community
Ex-Box One S
post #1 of 38 (permalink) Old 07-19-2018, 06:19 AM - Thread Starter
Draelren's Avatar
Rep: 0
Ex-Box One S
So it's been a few years since I started my Ex-Box 360 build, and I think I'm done with it. I updated that thread last week with it completed at PDXLAN last month. The build was even featured by AMD and they interviewed me. Got me itching to step my game up.
A few friends of mine had been pushing me to do something in an Xbox One; which I took a look at, and once again realized it would be too easy. I could fit normal components in it and just boot it. Enter in my new project: a One S, fully watercooled with a custom loop.
I didn't want to post things too early, since I already did that on my personal FB and had a few other people jump on the train and build their own.
As parts are purchased I will come back and add them here.
Ordered:
CPU: AMD Ryzen 2400G
Motherboard: ASUS ROG Strix X470-I Gaming
Motherboard Tray: CaseLabs Mercury S3 or Lian-Li PC-Q25 (unsure of yet)
CPU Waterblock: XSPC RayStorm Pro RGB WaterBlock White
CPU Waterblock: Swiftech Apogee SKF
Memory: Corsair Vengeance LPX 16GB 3000MHz
SSD: Samsung PM961 250GB NVMe
Radiator: Alphacool NexXxoS XT45 Full Copper 50mm Triple
Radiator fans: 3x GELID Silent5 FN-SX05-40
Rigid fittings: Primochill RevolverSX - Sky White
Rigid fittings: Nanoxia CF Hard Tube G1/4" to 12mm
PSU: HDPLEX 400W DC-ATX Power Supply
Sleeving: Teleios (Acid Green & Polar White), done by 'Tek by Design'
The cables and screws will be custom done for the build by a local modder, Tek by Design.
But here is the start of the project!
The day the shell arrived:
The system was already stripped out, I had just bought the shell off of ebay - so I got straight down to removing the plastic I didn't need that would just take up system space.
I planned out how I wanted to do the build more this time, and came up with the idea for a custom scratch built frame to hold all of the components. One I could just slip in the shell and drop in place, once I knew it was the right size.
I went to Lowes and picked up some short pieces of metal (couldn't get any longer than 3', wouldn't fit in my Lexus or my fiance's Miata otherwise)
Below is what it looks like when I test fit first inside of the console.
Took the metal out, gave it some marks...
Cut each piece down to slot into the other one.
Just this morning finished the other side.
And finally test fit back into the console.
Draelren is offline
post #2 of 38 (permalink) Old 07-19-2018, 07:11 AM
Preferred the old OCN
remz1337's Avatar
Rep: 20 (Unique: 20)
subbed!
In a recent discusssion:
Female colleague: "You are so logical, I'm not even sure you have a heart!"
Me: "I do, it runs at 4GHz."
if you are the best of the worst then you are still the worst of the worst. -Philosoraptor
Add me on Pokemon Yellow: Ash
remz1337 is offline
post #3 of 38 (permalink) Old 07-19-2018, 08:14 PM - Thread Starter
Draelren's Avatar
Rep: 0
When I got home from the office I had a package awaiting me! Radiator and waterblock.
Draelren is offline
post #4 of 38 (permalink) Old 07-20-2018, 10:28 AM - Thread Starter
Draelren's Avatar
Rep: 0
Done with progress for the day.
First thing when I got in the office this morning was test fit the radiator. It will be SNUGGGGGG. I may have to file and sand down a few pieces to get it to fit in the final version.
Next was to measure the distance from the bottom of the frame I'm building, to the top of the radiator - to figure out how tall to make the corner pieces. Got that measured and cut 5, so I had an extra one in case I messed up somewhere.
Next I marked the holes where the radiator would be mounted, and got those drilled, and tapped.
Last bit of progress for the day was to use some metal epoxy to get the frame to hold together on the bottom. The excess will be sanded off after the weekend, and more applied to the back side - but it's stuck like this for the 24 hour cure period.
After the second layer of epoxy is added, it will be time to finish mounting the radiator, and to start building the side corners and then thinking about the top 4 pieces (which will be flat).
Draelren is offline
post #5 of 38 (permalink) Old 07-20-2018, 10:29 AM
Filthy Casual
bajer29's Avatar
Rep: 108 (Unique: 93)
Interested in seeing where this is going.
Xeno Storm V 1.2
(17 items)
i7 4790K (delidded)
GIGABYTE|GA-Z87X-D3H
EVGA 1080TI FTW3
4x4GB GSKILL @ 2133MHz
WD 1002FAEX
KINGSTON V300 120GB
SanDisk Ultra Plus 128GB
Samsung 850 EVO 500GB
WD Green WD5000AADS
Corsair AX850
Cryorig R1 Ultimate
Phanteks Enthoo Pro M SE
Operating System
Windows 10 Enterprise
Acer XB270HU Predator
Keyboard
E-Element Z-88 RGB
Mouse
Corsair M65
Audio
Logitech X230 2.1
bajer29 is offline
post #6 of 38 (permalink) Old 07-20-2018, 10:50 AM
H₂O Aficionado
Slaughtahouse's Avatar
Rep: 117 (Unique: 94)
Subbed to the original thread, will sub once again
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
Stridsfordon 90
(20 items)
M1 Abrams
(18 items)
Asus G53
(0 items)
Intel 3930K
Asus Sabertooth X79
GTX 780 SC
Patriot Black Viper
Samsung 840 SSD
WD Black 7200 RPM
Corsair AX 850
XSPC EX 360 Radiator
XSPC Raystorm CPU Block
XSPC Titan/780 GPU Block
EK-XRES 100 Revo D5 - Acetal
XSPC D5 Pump
Fractal Design Meshify C
Operating System
Windows 10
QNIX 27"
Keyboard
Logitech G710+
Mouse
Razer Death Adder 2013
Mousepad
Mouse Rug
Audio
Sennheiser HD 6XX
Audio
Bose Companion III's
i7 3930K
Asus Sabertooth X79
Geforce GTX 780 EVGA SC 3GB + XSPC Waterblock
Patriot Viper 3 16GB (4 x 4GB) DDR3 2133
SAMSUNG 840 Series 250GB
Corsair AX850
XIGMATEK Dark Knight II Night Hawk Edition
XSPC 360mm radiator, Raystorm CPU block, D5 pump
Corsair Vengeance Series C70 Military Green (Custom paint)
Operating System
Windows 10
QNIX QX2710 27" 100hz
Samsung 2233RZ 22" 120hz
Keyboard
Logitech g710+
Mouse
Razer DeathAdder 3.5G
Mouse
Mouse Rug
Audio
Bose Companion III's Speakers
Audio
Sennheiser HD 558 Headphones
Audio
Sennheiser HD 6XX Headphones
Slaughtahouse is offline
post #7 of 38 (permalink) Old 07-20-2018, 11:01 AM - Thread Starter
Draelren's Avatar
Rep: 0
Did you take a look at the pic I just put up not that long ago of the 360 one? Using a Ryzen 2400G now and it is an awesome little sleeper/gamer system for my office.
Thanks for your continued support and subscription!
Draelren is offline
post #8 of 38 (permalink) Old 07-20-2018, 11:17 AM
H₂O Aficionado
Saw the notification but haven't had the time to read or view the new pictures this week.
No problem! I love case modding, especially consoles. Glad that you're coming back with this new thread
Stridsfordon 90
(20 items)
M1 Abrams
(18 items)
Asus G53
(0 items)
Intel 3930K
Asus Sabertooth X79
GTX 780 SC
Patriot Black Viper
Samsung 840 SSD
WD Black 7200 RPM
Corsair AX 850
XSPC D5 Pump
Operating System
Windows 10
QNIX 27"
Keyboard
Logitech G710+
Mouse
Mousepad
Mouse Rug
Audio
Sennheiser HD 6XX
Audio
i7 3930K
Asus Sabertooth X79
Corsair AX850
Operating System
Windows 10
Keyboard
Logitech g710+
Mouse
Mouse
Mouse Rug
Audio
Audio
Audio
post #9 of 38 (permalink) Old 07-21-2018, 12:12 PM - Thread Starter
Draelren's Avatar
Rep: 0
More parts arrive! 3 intake fans for the radiator, LED strip for the lighting, and my motherboard tray - directly from Lian-Li themselves.
Draelren is offline
post #10 of 38 (permalink) Old 07-24-2018, 09:47 AM - Thread Starter
Draelren's Avatar
Rep: 0
Monday when I got into the office I worked on setting the frame up on some spacers and got the exterior of the frame epoxy'd.
Last night got some more pieces in for the build also, except the CPU I had to drive down to Fry's to get it quickly.
Got the system test booted, and then proceeded to get the block assembled, lighting installed, and fittings attached.
Next was looking at the motherboard tray (only have the Lian-Li one currently, caselabs one won't be in for a bit) - cut the lian li down to size that it needed to be, and figured out how I was going to attach it (if I go that route)
The next issue is that the fans that will be used for the radiator are only 15mm long, rather than the standard 25mm. Had to cut the 12 screws down to the appropriate sizing.
Just to get an idea of what it will look like:
Next thing that got done was I test fit the radiator with the side posts installed, and then got them positioned, they are now curing for the next 24 hours.
Draelren is offline
