[The Official] NZXT Vulcan Owners Club - Page 3 - Overclock.net - An Overclocking Community
post #21 of 2410 (permalink) Old 07-20-2010, 03:35 PM - Thread Starter
Rep: 16 (Unique: 14)
Originally Posted by Ruckol1 View Post
Ordered mine yesterday! Shipped from NJ USA according to the egg.
Is it your sig rig going in it?
And congrats on purchase!
TARRCO is offline
post #22 of 2410 (permalink) Old 07-21-2010, 09:18 AM
Dr. Games's Avatar
Rep: 0
Joining the club
Haven't built anything since '03.
This case was on sale so I picked it up back about a month ago.
Saw this case and its one of those cases I figured if I look at it long enough, I'll like it
Right now, I'm actually quite proud of it
So far, for the price and what you can fit into it, definitely an awesome uatx case.
Dr. Games is offline
post #23 of 2410 (permalink) Old 07-21-2010, 10:31 AM
Daniel Symonds
Xraven771's Avatar
Rep: 63 (Unique: 54)
how dose a normal sized cooler fit into this case xD ?
NZXT Elite
8700k
GIGABYTE Intel 1151 Socket Z370 Aorus Ultra Gaming ATX Motherboard
GTX 970 SLI
G.SKILL F4-3866C18D-16GTZR Trident Z RGB Series 16 GB (8 GB x 2) DDR4 3866 MHz
WD 4TB F1 +Samsung 960 SSD
Optical Drive
USB
Corsair 650w
Lian Li PC-A7F (Custom)
Operating System
Windows 7 X64
LG 24"
Keyboard
G15 V2
Mouse
Razer Lanches
Mouse
None
Xraven771 is offline
post #24 of 2410 (permalink) Old 07-21-2010, 11:40 AM
Ruckol1's Avatar
Rep: 87 (Unique: 81)
Everything in my sig rig except the motherboard.. I had to go mATX, so I picked up a M4A785-M for $45. Only worried a bit about putting my H50 in the front
And xRaven, according to reviews mostly any sized coolers will fit, almost ANY will fit if you don't mount a 200mm intake on the side panel. What were you considering as far as cooling solutions go?
Ruckol1 is offline
post #25 of 2410 (permalink) Old 07-22-2010, 01:09 AM
Daniel Symonds
Xraven771's Avatar
just on a review i saw the cooler was to tall because the case is thinner than most so it wouldn't fit in xD
NZXT Elite
8700k
GTX 970 SLI
Optical Drive
USB
Corsair 650w
Operating System
Windows 7 X64
LG 24"
Keyboard
G15 V2
Mouse
Razer Lanches
Mouse
None
post #26 of 2410 (permalink) Old 07-22-2010, 01:10 AM - Thread Starter
Which cooler is it?
I got my Xigmatek Dark Knight to fit. And that's a pretty large cooler.
TARRCO is offline
post #27 of 2410 (permalink) Old 07-23-2010, 07:20 AM
Dr. Games's Avatar
Rep: 0
I think the maximum sized cooler you can have in the unit is 165mm without the 200mm side fan.
Just look at the dimensions of the cooler you want to buy and see if its less then that.
My 212+ fit perfectly with plenty of clearance. Its at a 158.5mm in height.
post #28 of 2410 (permalink) Old 07-23-2010, 10:09 AM
Ruckol1's Avatar
Case arrived today.. here are some pictures.
Vulcan. Sufficient packaging, not over the top but gets the job done.
Baby on her side
Standing up fresh out of box
Front view
Front Drive bays: Note the stock cable management NZXT has done, not to shabby. Also the plastic underneath the bottom HDD bays to prevent the top of any long PCB's shorting from the metal of the case. Good thinking NZXT!
Accessories box.. HDD rails, numerous thumb screws as well as regular.
Bottom view, PSU intake dust filter visible on left.
Rear nekked view, panel off. Good job of cable management by NZXT.
PSU Mounted inside, fits perfectly. Not tight enough to scratch but not going anywhere.
PSU Cable management holes.
Removable HDD Bay. (Necessary for H50's.) Front panel off momentarily to do some fan work.
Fan work completed. Double 120mm top exhaust.
Motherboard in, H50 Rad in.
Everything installed, straight up view. Side panel off. Cable management didn't go as smoothly as I'd hoped, having the HDD's in the top bay made it more difficult. Note to anyone buying this case with an H50: It will work fine! Just make sure you have SATA cables that are long enough so you can run a reverse installation on the hard drives so the power and SATA are hidden. (Facing the other way/front of the case. Will have to pop off front panel.)
More Vulcan goodness. I have another 80mm orange LED exhaust fan I will be putting in but I was in a rush to just get everything going.
Another Side view.
Side view w.panel on.
Angled view to top it off!
Edit why aren't my pictures showing up?
Ruckol1 is offline
post #29 of 2410 (permalink) Old 07-24-2010, 05:11 AM - Thread Starter
Baby on her side
Front view
Another Side view.
Yeah I agreee... Why aren't the pictures showing haha.
TARRCO is offline
post #30 of 2410 (permalink) Old 07-24-2010, 05:17 AM
Liighthead's Avatar
Rep: 69 (Unique: 59)
NZXT say that some coolers wont fit in some sockets and will in others lol.....
aka something mite fit on a 1156.. but wont on a 775...
not sure what coolers n what evr but yeh
Liighthead is offline
