Help more than one folding program - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 09-26-2004, 03:18 PM - Thread Starter
Rep: 173 (Unique: 136)
can someone give me step by step to set up folding more than one core because when i put each into different directory and different machine id it still says that i have one program alrdy runin and it shuts down the second one which i try to bring up
aznchowboy650 is offline
post #2 of 11 (permalink) Old 09-26-2004, 03:19 PM
is it even possible i have never heard of that
ThE_GeNeRaL is offline
post #3 of 11 (permalink) Old 09-26-2004, 03:25 PM
Rep: 297 (Unique: 183)
Are you trying run it on P4 w/HT or the mobile in system profile?
archer_456 is offline
post #4 of 11 (permalink) Old 09-26-2004, 03:29 PM
Overclockiit
Rep: 364 (Unique: 216)
In order to run more than 1 core on a pc you gotta have Hyper Threading.
If you have HT download the graphical version and install.
Now dl the console version it will ask you a bunch of question pertaining to the setup, when it comes to the advanced option click yes it will give you an option shortly after to change the machine id 1-8 change it to 2, hope that helps.
|2A|N is offline
post #5 of 11 (permalink) Old 09-26-2004, 05:41 PM - Thread Starter
ty shucks i don't got ht too bad lol
post #6 of 11 (permalink) Old 09-26-2004, 05:54 PM
Retired Staff
Rep: 1130 (Unique: 519)
I can run two executions at once...I think...I can run the graphical version and the console version at the same time, though I don't think it does any good because I'm sure one just takes priority over the CPU resources
YiffyGriffy is offline
post #7 of 11 (permalink) Old 09-28-2004, 01:42 AM
Rep: 0
I downloaded both and the console version never showed any options neither did the graphical program??.
goin Nutz is offline
post #8 of 11 (permalink) Old 09-28-2004, 08:32 AM
Retired Staff
Rep: 354 (Unique: 187)
If the config stuff doesn't come up for the console, you can make a shortcut to the [email protected] console program. Then right click on the shortcut, choose properties, then add -config to the end of the short cut (after the quotes). that will make it do the setup process again. Then after you're setup, you can take the -config out.
I dunno about the graphical one.
Fold for the cure & team 37726!!
H2O cooling: Chevette heatercore, 172mm 258CFM fan, Apogee GT, and Ehiem 1250. Load temp @ 1.45vcore 41C.
DeathONator is offline
post #9 of 11 (permalink) Old 09-28-2004, 04:28 PM
Rep: 0
Thanks, you deserve a few rep points for that!
post #10 of 11 (permalink) Old 09-28-2004, 04:32 PM
is it possible to dual fold on amd cpus?
