ASRock X79 Extreme 11 Owners Issues & Hopefully Fixes - Page 2 - Overclock.net - An Overclocking Community
post #11 of 1202 (permalink) Old 08-04-2012, 07:35 PM
Iunno
AikenDrum's Avatar
Rep: 0
Actually, I just made an embarrasing discovery. I didn't check the auto-detect on my RAM, and when I did my cpu-z validation just now for the owner's list, I noticed it was running at a default of 666 instead of the 2133 it really is (yuk). I fixed that and I'm getting better results. I'll post them to the thread where Vega's been posting his and where I posted my flawed ones earlier today.
Edit:
Hm, the plot thickens. Now I'm back to the previous transfer rates. What changed since I started windows? When I got to the desktop, I was getting over 3GB sequential reads, now I'm down in the 2.6 range again.
AikenDrum is offline
post #12 of 1202 (permalink) Old 08-04-2012, 07:43 PM
Iunno
AikenDrum's Avatar
Rep: 0
Originally Posted by jgtown View Post
What controller(s) do your SSDs use? Currently, it seems that LSI is pointing fingers at the Indilinx controller on the Vertex 4.
Whatever's in Samsung 830's.
post #13 of 1202 (permalink) Old 08-04-2012, 07:56 PM
jgtown's Avatar
Rep: 0
Pretty sure Samsung's rolling their own triple-core ARM controller that they call the MCX.
New build on the bench:
ASRock X79 Extreme11, Intel i7-3930K, Galaxy GeForce GTX680 GC 4GB (x4 in transit)
jgtown is offline
post #14 of 1202 (permalink) Old 08-04-2012, 07:58 PM
Swolern's Avatar
Rep: 359 (Unique: 236)
How many do you have? Running in RAID 0?
Swolern is offline
post #15 of 1202 (permalink) Old 08-04-2012, 08:57 PM
Iunno
AikenDrum's Avatar
Rep: 0
8 in RAID0 on the onboard LSI.
post #16 of 1202 (permalink) Old 08-05-2012, 06:11 AM - Thread Starter
Linux Lobbyist
theseekeroffun's Avatar
Rep: 116 (Unique: 93)
Please post your system specs.
theseekeroffun is offline
post #17 of 1202 (permalink) Old 08-10-2012, 06:08 PM
RC15's Avatar
Rep: 0
Can I just ask what case people are using to mount this board. Just curious smile.gif
RC15 is offline
post #18 of 1202 (permalink) Old 08-10-2012, 07:17 PM
Swolern's Avatar
I have it in the HAF X 942.
Swolern is offline
post #19 of 1202 (permalink) Old 08-11-2012, 12:35 PM
jgtown's Avatar
Rep: 0
I'm using a Corsair 400R but I don't recommend it for this motherboard. The motherboard is recessed and, because it's 0.9" longer than ATX, the bottom SATA ports are partially blocked. I think I could use cables with very short heads if I lift that edge of the motherboard before plugging them in but it'd be a tight fit. OTOH, it's a decent case for other builds. Fairly cheap, lots of airflow, room to hide cables, room to mount standard radiators inside, low-key looks, etc.
Edited to add:
If you're planning to put 4 big video cards on this thing (why else would you buy it?) make sure the case has at least 8 expansion slot openings in the back. That, and the ability to hold a CEB form factor motherboard and long video cards are key.
jgtown is offline
post #20 of 1202 (permalink) Old 08-11-2012, 02:13 PM
jackk's Avatar
Rep: 8 (Unique: 6)
Cosmo II
jackk is offline
