ASRock X299 OC Formula OC Guide (living review) - Page 25 - Overclock.net - An Overclocking Community
post #241 of 244 (permalink) Old 06-13-2019, 04:58 AM
Overclocker in training
ThrashZone's Avatar
Rep: 54 (Unique: 44)
Hi,
I have an asus board but yes 99..x needed the newest bios to be compatible and yes also I'm stuck on it too no bios flash back options unless I swap back to 79..x series.
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #242 of 244 (permalink) Old 06-13-2019, 08:16 AM
LN2 addict
bigblock990's Avatar
Rep: 70 (Unique: 42)
Quote: Originally Posted by pharaohspaw View Post
Sorry have been AFK for a while on this thread. RAMIdotGG how did your RAM situation work out?
I'm going to most likely be building another rig with one of these boards. Pharaoh, my first ever watercooled machine, is getting a bit old now (11 years old) and the amount of noise and heat it constantly generates is becoming a bit too much to bear. So if it works out $-wise, I'm going to build a new rig on another x299 OCF and a Skylake refresh, and replace Pharaoh with the current one.
Anybody know offhand if it is absolutely required to update BIOS to 1.60 to use a Skylake refresh CPU (99xx) on these boards? It sort of looks to me like I'd be better off staying with older BIOS revs with some of the quirks reported here in newer ones.
The board will boot with older bios' however to get the best performance/efficiency you need 1.60
bigblock990 is offline
post #243 of 244 (permalink) Old 06-13-2019, 05:02 PM
Missing the Good Old Days
pharaohspaw's Avatar
Rep: 50 (Unique: 43)
Thanks for the replies, I'll go back through this thread again and refresh my memory of what people have reported about newer BIOS updates. Which hasn't been much good since the early days if I am remembering much at all.
I did see where an update on their site is said to improve the per core specific clock setting that a number of posters here reported got broken somewhere around 1.17. So maybe it is better.
Old-school hotrod mechanic's proverb: "There is no replacement for displacement."
ASRock x299 OC Formula i9-7940X @4.6Ghz turbo clock (All Cores), -0.055V Adaptive VCore Offset, 30X Mesh @1.100V, 2.100V VCCIN (LLC Level 2) - BIOS v1.20
Intel i9-7940X
ASRock X299 Overclock Formula
EVGA GTX1080-FTW
EVGA GTX1080-FTW
Kingston HyperX Predator 32GB (4x8GB) DDR4-2133 / 2666 / 3000
Samsung EVO Pro 850 SSD
Samsung 950 Pro M.2
Western Digital RE3 SATA
Seasonic Platinum 1200 (SS-1200-XP3)
EK Supremacy EVO CPU Waterblock (Nickel + Plexi)
EK EK-FC1080 GTX FTW Nickel/Plexi Full Cover Waterblocks w/Nickel Backplates
EK FC-Terminal - Triple Plexi (Parallel)
Hardware Labs Black Ice Nemesis 420GTX (3x140)
Watercool Heatkiller Tube 100 DDC reservoir + DDC 3.2 pump housing
EK DDC 3.2 PWM pump
Primochill PrimoFlex Advanced LRT 3/8" x 5/8" Brilliant UV Blue Tubing
Monsoon Chaingun GunMetal/Black Chrome Compression Fittings
Thermaltake View91 RGB Plus (Tempered Glass)
Operating System
Windows 7 x64 SP1
Operating System
Fedora Linux x86_64
Keyboard
Logitech G510S
Keyboard
Coolermaster MasterKey MK750 RGB (Cherry MX Brown)
Mouse
Logitech G600
Mouse
Logitech G600
Audio
Realtek ALC1220
Audio
RME HDSPe RayDAT
(2) Xeon X5470 Harpertown Quads @3.33GHz (stock)
Tyan S5396 i5400XT
cheap PCI video card (it's a server now)
32GB (8x4GB) DDR2-667 FBDIMM (watercooled)
3Ware 9550SXU SATA RAID + (8) WD 1TB RE3 7200rpm SATA in RAID50 (~5.5TB)
PC Power & Cooling Turbo-Cool 1200
Looooooooong story... :)
Danger Den Black Series "Double Wide" Custom
Operating System
Fedora x86_64
Flat panels
pharaohspaw is offline
post #244 of 244 (permalink) Old 06-16-2019, 09:42 PM
D-EJ915's Avatar
Rep: 2 (Unique: 2)
I tested most of the BIOSes with my 9900X and they all work so pick whichever one works best for you and your chip
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
