ASRock X299 OC Formula OC Guide (living review) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 262 (permalink) Old 09-24-2017, 02:56 AM
RULE's Avatar
Rep: 2 (Unique: 2)
Some memory performance scaling on x265/1080p
3200c10-9-9-18-1T
3733c12-11-11-24-1T
3600c11-10-10-18-1T
io 1.30v/sa 1.40v
Hard Restart is sooo good for play with memory.
If you lost some memory channel, you can try to train one step lower memory multiplayer until you recover every channel, then raise the mupltiplayer to desired value.
If you stuck at EE, hard restart and try again, might pass after hard restart.
RULE is offline
post #22 of 262 (permalink) Old 09-24-2017, 11:09 AM
D-EJ915's Avatar
Rep: 15 (Unique: 14)
edit: see nick's post below regarding this: https://www.overclock.net/t/1638490/asrock-x299-oc-formula-oc-guide-living-review/0_50#post_26357811
This is probably extraneous to most everyone, but with 100% system stability on my OC I was getting random frame drops and stuttering in Final Fantasy XIV. After playing around disabling turbo boost fixed the issue but then my OC also bit the dust. I enabled turbo boost again and enabled the benchmark mode and the issue seems to have disappeared and I no longer get the frame drops. I have no idea what benchmark mode does but I guess I will leave it enabled. (this issue also occured at UEFI default/stock settings no OC)
I'd changed about a thousand other settings and parts out to try to fix this issue as well. Also another thing I ran into that Corsair Utility Engine also seemed to bog down the system a bit, but I haven't reinstalled it yet so maybe that got fixed too but just an FYI lol.
Kanna
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #23 of 262 (permalink) Old 09-24-2017, 10:44 PM
Hardware Rep
Nickshih's Avatar
Rep: 29 (Unique: 25)
opps.. i think you guys misunderstand of turbo boost and EIST. If turbo boost be disabled , cpu cant be turbo and can only stay lower than max non-turbo ratio.
For keeping cpu frequency as highest one under loading . U just need to disabled all C-state and keep high performance mode in OS.
Enabled benchmark tweak will do the similar job , but i will tweak more for some benchmarks to gain more point of records .
Nickshih is offline
post #24 of 262 (permalink) Old 09-24-2017, 10:49 PM
Hardware Rep
Nickshih's Avatar
Originally Posted by DVLux View Post
So, does this board really do x8 on all five slots? The manual sort of stops at four cards... redface.gif
44 Lane CPU - x16/x0/x0/x16/x8 or x8/x8/x8/x8/x8
28 Lane - x16/x0/x0/x8/x4 or x8/x8/x0/x8/x4
16 Lane - x16/x0/x0/x0/x4 or x8/x0/x0/x8/x4
but SLI support 4 cards max so far .
Nickshih is offline
post #25 of 262 (permalink) Old 09-24-2017, 10:51 PM
D-EJ915's Avatar
Originally Posted by Nickshih View Post
opps.. i think you guys misunderstand of turbo boost and EIST. If turbo boost be disabled , cpu cant be turbo and can only stay lower then max non-turbo ratio.
Thanks, admittedly I am kind of an OC noob with these newer chips so thanks for the info. I am not really hardcore into benching so I will set it up with the C-states method and compare. My issue was kind of an erroneous one I think no one else really would run into it but figured I would post in case anyone else encounters it at some point.
The board looks great btw and I dig the regular ATX formfactor vs the asus boards smile.gif It is not often you get a new system built and it works 100% the first try so nice job on the design.
Kanna
Mitty
(11 items)
Intel i7-7820X
Asus Strix 1080 Ti
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
Intel i7-3930k
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #26 of 262 (permalink) Old 09-24-2017, 11:22 PM
Hardware Rep
Nickshih's Avatar
feel free to ask anything here .
u can enabled benchmark tweak . and just change cpu ratio to find sweet spot for stability .
For example 45-48x for Gaming by Prime95 none-Avx loading . And avx offset -5 by prime95 Avx loading .
Bcz 95% software doesn't use any AVX instructions .
Nickshih is offline
post #27 of 262 (permalink) Old 09-25-2017, 04:00 AM
Hardware Rep
Nickshih's Avatar
Improved NVME performance , revised kabylake profile , fixed XP issue on Kabylake-X
picx.xfastest.com/nickshih/asrock/X29OCF113A.rar
Nickshih is offline
post #28 of 262 (permalink) Old 09-25-2017, 01:41 PM
DVLux's Avatar
Rep: 40 (Unique: 34)
Yeah, it says that on the support page... But I wanted to make sure it wasn't a typo tongue.gif
Also, that PCI-E x4 slot at the bottom... It's hooked up the CPU, right?
Meow?
DVLux is offline
post #29 of 262 (permalink) Old 09-25-2017, 08:50 PM
Hardware Rep
Nickshih's Avatar
black x4 slot is by PCH.
Nickshih is offline
post #30 of 262 (permalink) Old 09-25-2017, 08:54 PM
DVLux's Avatar
Then why does it get disabled when you don't use a 44-lane CPU? O_o That's ...weird.
Meow?
DVLux is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
