CHIPSET FAN: heatsink with tiny fan, with PLASTIC COVER: remove & replace??? - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 09-20-2018, 01:57 PM - Thread Starter
Not New to Overclock.net
pulverizor's Avatar
Rep: 0
question's in the title
my mainboard's PCH has this "protection" :
basically it's a small heatsink with a fan & all covered by plastic
now they call it "thermal armor"
but logic says it's more like a thermal trap because:
1) it all depends on the fan, and the fan will fail (small fans are designed to fail)
2) the plastic cover will act as an INSULANT since air's no longer blown up when the fan fails
3) NO HEATPIPE (unlike the Rampage boards) so cannot evacuate the heat out of the PCH heatsink, when the fan fails: the heat remains trapped under the plastic cover
in other words when the fan fails this protection becomes the opposite of a protection
so this smells of planned obsolescence right? they designed this to fail & damage the board by frying the PCH (Asus ain't exactly known for its ethics)
so should I remove this whole thing (the plastic along with the heatsink & fan) and just put a bigger passive chipset heatsink instead?
like this one:
at least it's "open" (not smothered by plastic) and doesn't depend on a fan
pulverizor is offline
post #2 of 10 (permalink) Old 09-20-2018, 02:36 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1159 (Unique: 661)
If you have decent airflow in your case I'd just unplug the fan and leave it as is. But IIRC the fans aren't even audible really ... so just leave it until it dies?
It's not like it's a 775 northbridge - the PCH on X79 on an HEDT board uses < 8w of power.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 10 (permalink) Old 09-20-2018, 02:42 PM - Thread Starter
pulverizor's Avatar
Rep: 0
yeah I considered that but like I said if the fan is off then the PLASTIC COVER will retain the heat from the heatsink
and since the plastic cover alone can't be removed...only the whole thing (heatsink+fan+plastic cover) can be removed
post #4 of 10 (permalink) Old 09-20-2018, 02:57 PM
9 Cans of Ravioli
The Pook's Avatar
Something that is only <8w likely can function without the heatsink in the first place. The plastic is not gonna hurt anything.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #5 of 10 (permalink) Old 09-20-2018, 03:58 PM - Thread Starter
pulverizor's Avatar
Rep: 0
hey believe me even with the heatsink AND functioning fan (at 3000rmp so that's slow mode): temperature of the PCH is almost 50°C on idle (not that prime95 makes it go up so I dunno what exactly makes a PCH temperature go up)
if it's already idling at 50°C with good airflow then imagine if the fan goes out and the heatsink's covered by that plastic with zero air flow?
why didn't they just put a bare heatsink with no cover & no fan?
post #6 of 10 (permalink) Old 09-20-2018, 04:09 PM
Meep
Gilles3000's Avatar
Rep: 306 (Unique: 223)
That motherboard is probably nearing 7 years in age now, maybe the TIM on the chipset has dried out?
Gilles3000 is offline
post #7 of 10 (permalink) Old 09-20-2018, 04:42 PM - Thread Starter
pulverizor's Avatar
Rep: 0
actually it's new in that it was never used those past years (even the I/O shield was still in its sealed wrap)
and can't fake the "new" smell either
anyway that doesn't answer the main problem - even if everything works well at the start, for argument's sake: look at first the pic of the cover & fan then tell me: what do you think will happen when that fragile fan stops spinning?
remember that the heatsink is covered by plastic & plastic doesn't exactly conduct heat
also remember there's no heatpipe going out of the heatsink
so what happens when that fan stops spinning??
post #8 of 10 (permalink) Old 09-24-2018, 04:07 AM
aramil's Avatar
Rep: 34 (Unique: 29)
I have had the Z77 sabertooth in the past (full plastic armour) and used it with and without fans (as the manual said I could) it makes very little difference to the temps when the fans are on or off (a few degrees over extended periods). So your call. At <8watts of power I would not worry at all.
System: Intel i7 8700K delidded Griz | ASRock Z370 Taichi | Gigabyte GTX 1080 G1 gaming 8Gb | Samsung 960 EVO NVMe | Samsung 1Tb F2 | WD 1Tb | Corsair 750TX v2 | 32Gb (2x16) Corsair Vengence | Corsair K90 Keyboard | Coolmaster MLP 140 | Corsair Carbide 400C | AOC 27" 2560x1440 | Windows 10 Pro 64bit | Linx10 & Linx 12v64 Tablets - ED: CMDR Aramil Lorrathain
aramil is offline
post #9 of 10 (permalink) Old 09-27-2018, 07:37 PM - Thread Starter
pulverizor's Avatar
Rep: 0
the z77 sabertooth is VERY different though: most of the mainboard is covered by plastic EXCEPT a few things like the PCH heatsink which is exposed to air (no plastic to smother it)
a bit the opposite of mine actually - look at the pics I posted in the OP - which is why my plastic-covered PCH needs a fan to blow out the air trapped by the plastic
that's no problem though I was able to remove only the plastic cover, and keep the metal heatsink : )
I kept the fan too (difference is without the plastic, the fan will blow air all around it & it won't be funnelled toward the PCH. no biggie. at least when the fan fails, the heatsink won't be covered by plastic so the hot air can escape)
!!! I tested with & w/o the fan: temperature difference on an almost empty PC is about 7°C: w/o the fan it's 50°C on idle, with fan it's about 43°C on idle, on a system with no hard drive, 1 usb flash drive & 2 ram sticks on stock speed
and that's with the plastic cover removed & heatsink exposed. imagine how much hotter it'd be with the plastic & without the fan! (again look at the pic in the OP)
>>> now another question is, what's the "best" way to "stress" a PCH?
what sort of activity in the PC makes the PCH as hot as possible? (for testing purposes)
increase ram clock?
increase number of ram sticks? (quad channel?)
increase number of hard drives?
increase number of usb drives?
theoretically if I do ALL these things at once (8 ram sticks, an SSD on every sata port, and a flash drive on usb port, then somehow do a read or write operation on ALL these drives simultaneously) how much hotter can it get compared to say, a system with no hard drive, only 1 usb drive (live usb) and only 1 ram stick at stock speed?
what'd be the temperature difference?
post #10 of 10 (permalink) Old 02-21-2019, 12:47 PM
Rep: 0
Hey, I've got the same board, and am looking to do the same thing. Would you mind going into detail with how you managed to remove the plastic shroud? Do you have to remove the entire fan assembly to remove it?
Yunekomi is offline
