So using M.2 drives makes me lose sata ports in Aorus Master? Help me understand please... - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 11-06-2018, 10:02 PM - Thread Starter
shaolin95's Avatar
Rep: 33 (Unique: 31)
Hello,
So I finally got almost all my parts for my 9900k build but I was about to order a 970 Evo M.2 when I read that using an M.2 drive is going to disable 2 of my Sata ports of which already I only had 6 and was going to use all of them. Is this correct? Is there no way around this like maybe a PCI-e to Sata card?
I am old school with my X58 so not used to these things.
Thanks!
Aš tikrai myliu Lietuva!
9900k "The Kraken"
(12 items)
i9-9900k @ 5Ghz
Gigabyte Aorus Master Z390
EVGA 1080ti Hybrid
4x16GB G.SKILL Trident Z Royal Series Model F4-3200C14D-32GTRS
Samsung EVO 970 1TB
EVGA Supernova 1000 G3
Thermaltake Floe Riing RGB 360 TT Premium Edition
Thermaltake View 71
BenQ PD3200u
Keyboard
ROCCAT VULCAN 120 AIMO
Mouse
Roccat AIMO
Mousepad
ROCCAT Alumic Double-Sided
shaolin95 is offline
post #2 of 11 (permalink) Old 11-06-2018, 10:11 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1324 (Unique: 703)
http://www.tomshardware.com/forum/id...rt-issues.html
It seems to vary from board to board. I don't understand why it would ... M2 SATA, sure, but not an NVME. All my SATA ports still work on my Z170-E with my NVME.
Add in SATA card would solve your issues (if you have them) and they can be had cheap on eBay.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (Blues)
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is online now
post #3 of 11 (permalink) Old 11-06-2018, 10:12 PM
unityole's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by shaolin95 View Post
Hello,
Thanks!
z370 and z390 are the same in that regards, 24 pcie lanes, 3x m.2 slot, if all 3 m.2 are used then 4 sata ports will not work. i would recommend to run m.2 ssd via cpu lanes instead. not only you get lower latency without having to go through chipset you also dont lose any sata ports. you will lose pcie lanes though and single GPU is more than enough.
unityole is offline
post #4 of 11 (permalink) Old 11-06-2018, 10:15 PM
deepor's Avatar
Rep: 483 (Unique: 328)
Read the manual of the board. It has tables that show what's happening exactly when you put stuff into the different M.2 slots that the board has. Not all configurations will disable SATA ports, you need to look this up to find out what will happen.
deepor is offline
post #5 of 11 (permalink) Old 11-07-2018, 09:41 AM
Keninishna's Avatar
Rep: 0
Is the difference noticeable when running m.2 ssd via the cpu lanes vs the chipset? I know the chipset gets bottle necked by DMI as well but I haven't seen much on how badly as it kinda depends on what other devices are using the chipset. The thing is with this board at least if you use the second slot the GPU slot speed gets downgraded to 8x which I've seen reduces FPS in games by like a little less than 10% using a gtx 1080 ti.
As far as OP's question goes, according to the motherboard manual. http://download.gigabyte.us/FileList...ter_1001_e.pdf
Due to the limited number of lanes provided by the Chipset, the availability of the SATA connectors may be affected
by the type of device installed in the M2. sockets. The M2M connector shares bandwidth with the SATA3 4, 5
connectors. The M2A connector shares bandwidth with the SATA3 1; the M2P connector shares bandwidth with
the PCIEX4 connector. Refer to the following tables for details.
If you look at the diagrams, you can actually use all sata ports if you install a m.2 ssd in the middle m.2 connector (m2a) it will just share bandwidth on the first sata port or if the ssd is small enough to fit in the bottom m.2 (m2p) it will share bandwidth with the bottom pcie port. If your m.2 ssd won't fit in the bottom slot you could just get a m.2 pcie adapter and put it in the bottom pcie slot that way you don't share bandwidth with the sata drives (although they do ultimately get shared over the DMI).
Keninishna is offline
post #6 of 11 (permalink) Old 11-07-2018, 07:29 PM
unityole's Avatar
Rep: 1 (Unique: 1)
dmi 3.0 is like 3.9 GB/s at cap, there are no pcie 3.0 x4 SSDs that can exceed it yet unless you run at high QDepth so in terms of bottleneck, there isnt.
however running m.2 SSD via chipset mean going through chipset/dmi thus increases latency, where as running through CPU lanes doesn't have that extra latency. difference is probably not noticeable unless you do benchmark, though I do feel a bit snappier since im a storage enthusiast. Pcper has great article about it but thats the answer anyway.
but basically yes, he needs to look at his mobo's manual/schematic w/e it is called and see which port he could use. if he plan to use full 6 sata slots.. im afraid theres not a lot of option.
unityole is offline
post #7 of 11 (permalink) Old 11-13-2018, 02:23 AM
Rep: 0
Does that Problem affect all Z370/Z390 Boards or only Aorus Master?
I will buy a Aorus Pro Wifi but I Need all Sata Ports! In my Z370 Pro4 Asrock I had a M.2 Drive and was able to use all SATA Ports, so I wonder if its a general chip problem!
Mo2k is offline
post #8 of 11 (permalink) Old 11-15-2018, 07:58 AM - Thread Starter
shaolin95's Avatar
To update I used the bottom slot for the m.2 drive and all my Sata ports are available.
Thanks all
9900k "The Kraken"
(12 items)
i9-9900k @ 5Ghz
EVGA 1080ti Hybrid
Samsung EVO 970 1TB
Thermaltake View 71
BenQ PD3200u
Keyboard
Mouse
Roccat AIMO
Mousepad
post #9 of 11 (permalink) Old 11-15-2018, 12:47 PM
Mr.4way SLI
Moparman's Avatar
Rep: 194 (Unique: 174)
Use your m.2 on the very bottom port on the Master. Then you still have all of your Sata and also can still 2way SLI.
Moparman is offline
post #10 of 11 (permalink) Old 11-15-2018, 12:50 PM - Thread Starter
shaolin95's Avatar
LOL that is literally what I just said before your post
9900k "The Kraken"
(12 items)
i9-9900k @ 5Ghz
EVGA 1080ti Hybrid
Samsung EVO 970 1TB
Thermaltake View 71
BenQ PD3200u
Keyboard
Mouse
Roccat AIMO
Mousepad
Tags
aorus , Gigabyte , m.2 , master , Samsung
