Gigabyte master z390 buzzing sound - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 12-03-2018, 08:39 AM - Thread Starter
eliau81's Avatar
Rep: 4 (Unique: 4)
Hi
After building my new pc iv notice a strange sound from my pc like electronic buzz that always there from boot
I disabled all the fans and still the buzzing sound won't stop it definitely from motherbord VRM
I though its from PSU bot no its not
Iv recorded the sound so you can hear
Is it normal or i need to RMA the unit?
eliau81 is offline
post #2 of 16 (permalink) Old 12-03-2018, 09:25 AM
Mr.4way SLI
Moparman's Avatar
Rep: 197 (Unique: 177)
Does the sound change when it's under load?
Moparman is offline
post #3 of 16 (permalink) Old 12-03-2018, 09:43 AM - Thread Starter
eliau81's Avatar
Rep: 4 (Unique: 4)
no its a static noise idel or load
eliau81 is offline
post #4 of 16 (permalink) Old 12-03-2018, 09:52 AM
Mr.4way SLI
Moparman's Avatar
And it's 100% for sure the board? If you checked all other components Then RMA. almost the same sound as one of my PSU's that died recently.
Moparman is offline
post #5 of 16 (permalink) Old 12-03-2018, 12:21 PM - Thread Starter
eliau81's Avatar
Rep: 4 (Unique: 4)
I will switch PSU and update
eliau81 is offline
post #6 of 16 (permalink) Old 12-15-2018, 12:37 PM - Thread Starter
eliau81's Avatar
Rep: 4 (Unique: 4)
update
swiched the PSU and still nothing changed
i did a RMA and got a new one
still got that buzzing sound
any idea?
eliau81 is offline
post #7 of 16 (permalink) Old 12-15-2018, 12:40 PM
zervun's Avatar
Rep: 0
Quote: Originally Posted by eliau81 View Post
update
any idea?
Powersupplys can frequently cause buzzing - I would check that next. Have you made sure you have all the correct power connectors plugged in? ie if there is another 4x or 6x power supply pin on the board, you need your power supply matching one (don't use the one for the graphics cards)
Power supplys can cause buzzing on graphics cards, motherboards, etc not necessarily on the power supply itself.
zervun is offline
post #8 of 16 (permalink) Old 12-15-2018, 01:09 PM
Meep
Gilles3000's Avatar
Rep: 333 (Unique: 235)
Some motherboards just have components that like to buzz, its not a defect.
I'd either get a different board or a case with sound deadening if it bothers you much.
Gilles3000 is offline
post #9 of 16 (permalink) Old 12-15-2018, 01:57 PM - Thread Starter
eliau81's Avatar
Rep: 4 (Unique: 4)
iv dubbled check the connectors all seems in place also plugged the ex 4pin to the cpu
also swiched PSU
eliau81 is offline
post #10 of 16 (permalink) Old 12-16-2018, 02:32 AM
RazerCicaj's Avatar
Rep: 0
Have you tried unplugging all the fans ? Even the CPU heatsink...just to eliminate them.
RazerCicaj is offline
