System freeze when not under load 20 seconds after wake from sleep - Page 3 - Overclock.net - An Overclocking Community
post #21 of 42 (permalink) Old 01-18-2019, 09:27 AM
wingman99 Level 1
wingman99's Avatar
Quote: Originally Posted by jfriend00 View Post
Nothing conclusive yet (will probably take a few more days of not seeing the problem to be confident), but in the period of time that I could previously reproduce the problem, I cannot reproduce the problem after disconnecting the DVD drive.
The DVD drive is fairly old so one theory is that it requires some driver that is missing or just has some compatibility issues with modern hardware. It works fine right after booting (I used it to install Windows).
Another theory is that my motherboard has 8 SATA ports. 6 are part of the Z390 chipset (Intel) and 2 are from an ASMedia chip. The DVD drive was plugged into one of the ASMedia ports and I see that I don't have an ASMedia-specific SATA controller or driver (ASRock doesn't offer one on their drivers page). Not sure if that matters or not.
Anyway, I'll have to go a couple more days without seeing the problem. Then, I'll have to put my overclocks back and go a few more days to be confident. If this is the issue, I'll just replace the DVD drive with a new one or evaluate going without one.
If you find out it is the DVD try plugin it in a Intel SATA controller port.
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
wingman99 is offline
post #22 of 42 (permalink) Old 01-18-2019, 03:51 PM - Thread Starter
Memory Overclocker
jfriend00
That might be interesting as an academic exercise, but it's old, slow, noisy and caused problems when booting LinuxMint too so it's time to replace it anyway. I think it's so old that it's missing something that a modern OS expects. And a replacement is not expensive.
[email protected] (-1 AVX offset) on ASRock Z390 Taichi with Noctua NH-D15 air cooler
CPU offset voltage of -25mv, runs VRVout 1.240-1.313V on full AVX load, 1.225-1.275V on non-AVX load
2x8GB [email protected] at 1.45V, G.Skill F4-3733C17Q-32GTZKK (XMP rated [email protected])
EVGA GTX 1060 6GB OC with Corsair RMx 750W power supply
Samsung 970 EVO 500GB NVMe boot SSD and four other drives all in a Fractal Design R6 Case
jfriend00 is offline
post #23 of 42 (permalink) Old 01-18-2019, 04:31 PM
wingman99 Level 1
wingman99's Avatar
I'm just saying the new ASMedia ports might be having a problem with the DVD drive and to try the Intel SATA port with drive. I don't believe it is a bad DVD drive, just a possible SATA port problem.
i5 8600K OC 5.0GHz
Noctua NH-U14S
post #24 of 42 (permalink) Old 01-18-2019, 04:34 PM - Thread Starter
Memory Overclocker
jfriend00
I understand what you're saying. I've had enough other problems with the drive so I want to replace it (costs all of $30 to replace) and will plug the new one into an Intel SATA port (though I only have one free).
post #25 of 42 (permalink) Old 01-18-2019, 06:00 PM
wingman99 Level 1
wingman99's Avatar
Sounds good, post how it works out.
i5 8600K OC 5.0GHz
Noctua NH-U14S
post #26 of 42 (permalink) Old 01-18-2019, 06:16 PM
I Love this Hobby!
Gunderman456 will become famous soon enough Gunderman456 will become famous soon enough Gunderman456 will become famous soon enough Gunderman456 will become famous soon enough Gunderman456 will become famous soon enough Gunderman456 will become famous soon enough
Gunderman456's Avatar
I had the same problem with my Bit'O'Heaven build (in sig). My OCs were rock stable and been serving me well for years now even made it my HTPC and with the HD 7990 can even still game on it. However, when I had the computer hibernate I would have the same problem and I was pretty sure that it was the Corsair AX 850W PSU causing the issue. So I bought a much cheaper Thermaltake 600W PSU and the computer had no problems while hibernating. My solution was to reinstall the Corsair, make an OCN thread about the issue (Corsair rep never flinched by the way) and disabled hibernate and I had no issues since. I kept the Thermaltake as a backup for a while before putting it to good use in my Cigar case (in sig).
https://www.overclock.net/forum/31-p...-gold-psu.html
Wow - I just looked at your specs and low and behold it's a Corsair.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ 1160GHz Core/1350GHz Mem
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Open Water Loop
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Nixeus EDG 27" Freesync 1440p 144Hz
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Microsoft Sidewinder X5
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Intel Core i5-3570K @ 4.5GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990
G.SKILL Ripjaws X DDR3 8GB 1600MHz
Crucial SSD 128GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Corsair Vengeance MM200
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
AMD Athlon II X4 640
ASRock N68C-GS
NVIDIA 6600GT
G. Skill Ripjaws DDR3 1600MHz
WD Caviar Blue 500GB 16MB Cache 7200RPM
Optical Drive
LG Optical Drive
Thermaltake TR2 600W
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Viewsonic 19” Flatscreen CRT
Keyboard
Gigabyte GK-K6800 103
Mouse
Zalman ZM-M300
Mouse
Gunderman456 is offline
post #27 of 42 (permalink) Old 01-18-2019, 06:28 PM
dontworkSundysormedaysoff
buellersdayoff Level 1
buellersdayoff's Avatar
Disable sleep and hibernation
AIRBOURNE
(10 items)
buellersbox
(17 items)
i7 7700k
asus maximus viii hero
msi 1080ti gaming x
corsair 3200mhz
samsung 950 nvme
corair rm850x
cryorig r1 universal
TT modified
Operating System
win10
acer predator x34
i7 6700k
Asus maximus VIII Hero
Msi gtx 980ti
Corsair
samsung 950 pro m.2
samsung ssd
2tb spinner
Optical Drive
blu-ray rw
Corsair RM850x
custom EKWB
Phanteks
Operating System
windoze 10
Acer X34 gsync
Keyboard
Logi Orion G910
Mouse
Logi G502
Mouse
Logi 440
Audio
Kingston Hyperx cloud II + Edifier R1280T
buellersdayoff is offline
post #28 of 42 (permalink) Old 01-18-2019, 07:10 PM - Thread Starter
Memory Overclocker
jfriend00
I'm not using hibernation. The whole point here is that I want my system to be able to sleep.
post #29 of 42 (permalink) Old 01-18-2019, 07:12 PM - Thread Starter
Memory Overclocker
jfriend00
Except, I'm not using hibernation and the problem went away when I removed my DVD. I don't think this is on the PSU.
post #30 of 42 (permalink) Old 01-18-2019, 07:41 PM
I Love this Hobby!
Glad you sorted the problem!
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Optical Drive
Open Water Loop
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Mousepad
Audio
Crucial SSD 128GB
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
ASRock N68C-GS
NVIDIA 6600GT
Optical Drive
LG Optical Drive
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Keyboard
Mouse
Zalman ZM-M300
Mouse
