System freeze when not under load 20 seconds after wake from sleep - Page 5 - Overclock.net - An Overclocking Community
post #41 of 42 (permalink) Old 01-27-2019, 03:28 PM
wingman99's Avatar
Rep: 63 (Unique: 46)
Quote: Originally Posted by jfriend00 View Post
After taking the DVD drive out of the ASMedia SATA controller, the hang after sleep wakeup completely went away.
But, I was still having a couple other occasional problems. While just using the computer, not under any meaningful load like just typing, the computer would occasionally freeze for 20-30 seconds. If I was patient, it would come back and then work normally again.
More seriously, every once in a while, I'd bet a BSOD DPC_WATCHDOG_VIOLATION. Again, all I'd be doing is just typing away, not under load at all. Removing my memory OC or my CPU OC didn't make the DPC_WATCHDOG_VIOLATION BSOD go away (a few times a day).
In researching possible causes of DPC_WATCHDOG_VIOLATION, a lot of the sources where related to SATA drivers. Hmm, this seems suspiciously like it may have been related to the hang-after-sleep-wakeup issue I was having earlier. Further research suggested that sometimes the problem can be fixed by making sure you're using Microsoft's SATA driver that is comes with Windows, not some other SATA driver.
I looked at what SATA driver I had installed and it was from Intel Rapid Storage Technology driver and utility ver:16.7.0.1009 which was recommended to be used with my motherboard by ASRock (on the download page for my specific Z390 Taichi motherboard). As an experiment, I decided I'd remove the Intel Rapid Storage Technology driver and let Windows install it's own SATA driver.
So far, I've had no momentary freezes and no BSODs of any kind since I remove that Intel Rapid Storage Technology driver in two days whereas I would see a momentary freeze and BSOD a couple times a day before. I have a theory that the Intel driver was causing problems with the ASMedia SATA port. I was unable to run extended stability tests over night (like RAMTest) before without getting the DPC_WATCHDOG_VIOLATION BSOD and now I can just fine and I just finished two, two hour Prime95/Blend runs (one with AVX and one without). So, the system seems pretty solid now. Obviously, one needs longer than two days to have high confidence the issue is gone for sure, but by making one and only one change to my system it went from seeing the problem multiple times a day to not seeing it at all.
If I were really trying to diagnose root cause, I'd reinstall the Intel Rapid Storage Technology driver and remove anything from the ASMedia SATA port (that requires unplugging a hard drive that is currently in use because of the number of drives I have) and run with that for a few days. But, that's probably ASRock's responsibility, not mine. I'm just happy to have a stable system again.
So far, I've had trouble with two sets of drivers on ASRock's download page, the Intel Rapid Storage Technology driver and the Realtek high definition audio driver which I also uninstalled after it was causing a regular AUDIODG.EXE page fault (visible only in the Windows event viewer). My system is working better without either of those drivers.
I just use windows 10 default drivers and have less problems.
i5 8600K
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #42 of 42 (permalink) Old 01-27-2019, 03:32 PM - Thread Starter
Memory Overclocker
Rep: 24 (Unique: 10)
It really depends upon the specific hardware item. My 10Gbps ethernet port did not function at all until I added the right drivers from the ASRock download site. Though I'm not using WiFi in my system, an installation note said it wouldn't work either without installing the right drivers. But, so far things are happy with the generic Microsoft SATA driver.
[email protected] (-1 AVX offset) on ASRock Z390 Taichi with Noctua NH-D15 air cooler
CPU offset voltage of -25mv, runs VRVout 1.240-1.313V on full AVX load, 1.225-1.275V on non-AVX load
2x8GB [email protected] at 1.45V, G.Skill F4-3733C17Q-32GTZKK (XMP rated [email protected])
EVGA GTX 1060 6GB OC with Corsair RMx 750W power supply
Samsung 970 EVO 500GB NVMe boot SSD and four other drives all in a Fractal Design R6 Case
jfriend00 is offline
