Asus Maximus XI Extreme (Z390) problem with 4600Mhz memory search to take best because 4600 is impossible - Overclock.net - An Overclocking Community
post #1 of 76 (permalink) Old 01-24-2019, 09:29 PM - Thread Starter
Trying to learn ^^
Fraizer's Avatar
Rep: 0
EDIT: please look last post because i know i cant reach 4600mhz but i need help to oc them at fast is possible i am actualy at 4133Mhz and timing 16-18. if i can with your help go more of 4133Mhz will be great ! but if is not possible i need some help to found the best timming at this speed
Hello
We have problem with the Asus Maximus XI Extreme and 4x 8gb =32 (even 2x 8gb =16 !) of 4600Mh from G.Skill the exact ref : G.Skill Trident Z Royal F4-4600C18D-16GTRS : Latency 18-22-22-42 at 1.45v. -> https://www.gskill.com/en/product/f4...gtrs#tabs-spec Same problem with the 4600Mhz "NON" Royal. (Royal is just the plastic they put on the led nothing else)
i make them run actualy in manual mode (not xmp) at 3200Mhz Only.
I tried to put only 2 ram on dual channel
i tried XMP 1 and 2 i put the G.Skill constructor voltage : 1.45volts but bios dont boot.
Maybe it need to put an higer value on the VCCIO and System Agent Voltage ???
i dont found them on the QVL of the ROG MAXIMUS XI EXTREME_Memory_QVL. those 4600 are on the market before novembre 2018 (with the 4600 non royal who are exactly the same)
https://dlcdnets.asus.com/pub/ASUS/m...y_QVL_0108.pdf
G.skill answer me is because Asus they dont add them then they will not work and no any other answer from g.skill usa who was rude by email and no more help...
Fraizer is offline
post #2 of 76 (permalink) Old 01-25-2019, 08:34 AM
ssateneth's Avatar
Rep: 44 (Unique: 39)
You can't really expect anything to work out of the box for 3200+. You might need tweaking of other settings to get your RAM working up to speed. I have a 4 x 16GB 3600MHz kit that does work at XMP, but a 2 x 8GB 4266MHz kit I have requires MANY reboots (5 to 50) to actually POST and be usable at 4266MHz. This may come down to the board being a 4 DIMM slot board. If your board is 2 DIMM slots, like an OC formula or Apex or Gene, you'll have better luck with high frequency kits due to better PCB trace layout suitable for high frequency RAM.
Intel Core i9-9900k (Silicon Lottery 5.1GHz @ 5.3GHz 1.36 VCore)
ASUS ROG MAXIMUS XI APEX
G.SKILL F4-4000C19D-32GTZSW (2x16GiB 4000MHz 19-19-19-39 2T, tuned to 4133MHz 14-17-17-31 2T)
EVGA NVIDIA GeForce GTX 1080 Ti FTW3
Seasonic PRIME 1300W 80+ Platinum
ssateneth is offline
post #3 of 76 (permalink) Old 01-25-2019, 02:52 PM - Thread Starter
Trying to learn ^^
Fraizer's Avatar
Rep: 0
the maximus xi extreme have 4 slots the 4266 are reconise.
i dont know at all what to put in setting to get those ***... working it was a big mistake to buy that
Fraizer is offline
post #4 of 76 (permalink) Old 01-25-2019, 03:07 PM
The last VRM burner
Rep: 46 (Unique: 27)
Have you tried increasing System Agent and IO Voltage?
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #5 of 76 (permalink) Old 01-25-2019, 03:12 PM - Thread Starter
Trying to learn ^^
Fraizer's Avatar
Rep: 0
hi BroadPwns
before that i will need to now what value exactly i have to put :/
but before that when i was oc the 9900k i put those value 1.15 and 1.20 but i was booting those memory at 3200mhz to be sure i will not have oc issue from the memory.
except the cpu i know approximatively how to deal with the voltage / oc but with memory realy nothing but get many warn about the vccio and sa
Fraizer is offline
post #6 of 76 (permalink) Old 01-25-2019, 05:39 PM
littledonny's Avatar
Rep: 76 (Unique: 68)
Quote: Originally Posted by Fraizer View Post
hi BroadPwns
Set them back to 1.15 and 1.20 and try again
littledonny is offline
post #7 of 76 (permalink) Old 01-25-2019, 06:01 PM
OC...D
Jpmboy's Avatar
Rep: 1342 (Unique: 583)
hi BroadPwns
post your question HERE. Lot's of helpful folks.
I have the Max XI also. I'm running my 3600c16 4x8GB kit at 4000C16.
Disable the MemOK switch on the MB. To start, set 1.25V VSA and 1.25V VCCIO, set VDIMM to 1.45V, do not load XMP (In fact, you'll need to clrcmos to remove all the XMP programming if you did load XMP prior). Set 16-16-16-38, leave all other timings on auto. F10.
Use the thread I linked to to continue...
ASUS Z370/Z390 Motherboard Support Thread, Coffee Lake OC Guide
X299
(33 items)
x99
(17 items)
Z370
(20 items)
7980XE
7740X
10980XE
10980XE @ 4.8
ASUS Rampage VI Apex
Gigabyte Aorus G9
Rampage VI Extreme Omega
3x Nvidia Titan V
GTX 1080
2 2080Ti FE / EK Vector Blocks
G. Skill 2x(2x8GB) 3600c15 @4000c16
Two 4x8GB GS 3600c16 kits @ 4200c17
INtel Optane 900P
2x256 Plextor Raid 0
WD Raptor
Samsung Sm 961
Corsair AX1500i
EVGA 850 G3
Seasonic Platinum 1300W
Aquacomputer GiGant 1680 (4x420)
Koolance EXC-800
2x Koolance -3K3U
Microcool Banchetto 101 (Alu)
Corsair 570X
Lian Li
Case Labs
Operating System
Win 10 Pro
Operating System
Win 7 Pro
ROG Swift
AOC 144Hz
TCL 55" 4K60
Keyboard
Ducky
Mouse
Spatha
6950X
ASUS Rampage V Extreme-10
AsRock Radeon VII / Blkski Block
G Skill 8x8GB 3200c14 @3400c13
Samsung 960 Pro
Optical Drive
ASUS BR/DVD/CD
Corsair AX1500i
2x360 Aq Copper Rads
Aquaero 6
Koolance ERM-3K3U (9-fan mora)
Ek Full Cover MB waterblock
CaseLabs Mercury S8
Operating System
Win 10 Pro
Operating System
Win 7 Pro
AGON 32 inch
Keyboard
Das Pro
Mouse
Logitech G700
8700K
8086K
ASUS Maximus X Apex
Titan Xp
Titan Xp
2x8 GB G.Skill 4400c19
G.Skill 3600c16 4x6GB
Intel 750
Optical Drive
PLextor DVD/CD
Corsair AX1500i
Corsair HX 1200i
Seasonic Titanium 850W
360Rad + Chiller
Koolance ERM-3K3U
Corasir 570
Operating System
Win 10
Operating System
Windows 7 Pro
55" 4K
Keyboard
HyperX Alloy FPS Pro
Mouse
SteelSeries Rival
Jpmboy is offline
post #8 of 76 (permalink) Old 01-25-2019, 06:44 PM - Thread Starter
Trying to learn ^^
Fraizer's Avatar
Rep: 0
@Jpmboy :
thank you for this link
Please dont take bad my questions i am realy lost about memory this why i make this order mistake.
- i set the speed at 4600Mhz right ?
- why i should put : 16-16-16-38 ? when the timing of g.skill are "Tested Latency: 18-22-22-42" ? --> it will be great to have the timing you set at 4600Mhz ! ♥
- What is the difference between XMP 1 and XMP 2 ? And what is the negative point if we dont set one of them and do a manual settings ?
to help this is the manufaturer spec for those 8Gb at 4600Mhz is: (i have 4 of them to make 32GB, from 2 sperate boxes, each 16Gb)
Test speed : 4600mhz
Tested voltage : 1.45volts
Fraizer is offline
post #9 of 76 (permalink) Old 01-25-2019, 07:33 PM
OC...D
Jpmboy's Avatar
no, with the above settings lets first see if we can get 4000 16-16-16 to boot with 1.45V and the vsa/vccio settings I mentioned. I know what ram kit you have. XMP will not work. Another problem is mixing kits at that (or any) speed. kits of 4 are binned to work together. Combining sticks from 2 identical kits will rarely work at XMP (like really rarely at speeds like that) and hopefully wil lwork together at a lower speed.
I'd put 4600 aside for now...
X299
(33 items)
x99
(17 items)
Z370
(20 items)
7980XE
7740X
10980XE
10980XE @ 4.8
Gigabyte Aorus G9
3x Nvidia Titan V
GTX 1080
INtel Optane 900P
WD Raptor
Samsung Sm 961
Corsair AX1500i
EVGA 850 G3
Koolance EXC-800
2x Koolance -3K3U
Corsair 570X
Lian Li
Case Labs
Operating System
Win 10 Pro
Operating System
Win 7 Pro
ROG Swift
AOC 144Hz
TCL 55" 4K60
Keyboard
Ducky
Mouse
Spatha
6950X
Samsung 960 Pro
Optical Drive
ASUS BR/DVD/CD
Corsair AX1500i
Aquaero 6
CaseLabs Mercury S8
Operating System
Win 10 Pro
Operating System
Win 7 Pro
AGON 32 inch
Keyboard
Das Pro
Mouse
Logitech G700
8700K
8086K
ASUS Maximus X Apex
Titan Xp
Titan Xp
Intel 750
Optical Drive
PLextor DVD/CD
Corsair AX1500i
Corsair HX 1200i
360Rad + Chiller
Koolance ERM-3K3U
Corasir 570
Operating System
Win 10
Operating System
Windows 7 Pro
55" 4K
Keyboard
Mouse
SteelSeries Rival
Jpmboy is offline
post #10 of 76 (permalink) Old 01-25-2019, 07:34 PM
Dillmiester's Avatar
Rep: 85 (Unique: 76)
Its no wonder cause the boards specs shows 4400, thats pretty up there without factoring the variances in memory controller it seems to me that it gets harder over 4000, I seen there was alot of people on other brands boards that were having trouble.
Asus has a memory profile called RAW MHZ try and load that you could go a little higher in voltage. It is possible tighter timings could be more stable with higher frequencies not the first time I've heard something to that effect but with Ryzen.
*Edit
I would like to add if you look up 4600 DDR4 the Gskill sticks are showing 1.5 volts not the Royals.
Dillmiester is offline
