Is manual VRM switching frequency worth using? - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 01-30-2019, 01:58 PM - Thread Starter
Rep: 0
I've read a higher vrm switching frequency can help stabilize or push higher overclocks at the cost of more VRM heat output.
Given I have a maximus xi formula with the vrm watercooled heat isn't an issue. I'm pushing a 5.1ghz daily. Should I run a higher vrm frequency
Jaz11 is offline
post #2 of 3 (permalink) Old 01-30-2019, 02:24 PM
Falkentyne's Avatar
Rep: 364 (Unique: 260)
Why don't you test it out and find out for yourself and report your results?
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is online now
post #3 of 3 (permalink) Old 01-30-2019, 03:08 PM
white owl's Avatar
Rep: 125 (Unique: 95)
So much this. Also air cooled VRM shouldn't be an issue either unless it was designed poorly.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
