Having issues with my X99 build. Please help - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 04-10-2019, 08:29 AM - Thread Starter
Alpina 7's Avatar
Rep: 27 (Unique: 21)
Hey guys hope everyone is well. I haven’t posted here in a while but here goes. About 3 months ago I rebuilt my PC with all new cooling and a new case and it’s been running like a champ ever sense. Yesterday I go to turn on my computer to get on some black ops three zombies (don’t judge me lol) and low and behold my computer won’t cut on fully. Every two seconds it throws a Q code 14, turns off and then repeat the entire cycle every two seconds. On and off on and off again.
Well I am plugged everything check for sure it’s plugged everything back up turned it on and it finally booted up but now I’m running into the issue that it is only reading four out of eight of my sticks of ram. Well I am plugged everything checked for sure it’s plugged everything back up turned it on and it finally booted up but now I’m running into the issue that it is only reading four out of eight of my sticks of ram.
I took the sticks out thinking they were faulty and replaced them with the other sticks same thing so my ram is definitely working but the slots seem to not be reading them . And it’s having a tuff time starting up every time now and throw a Bf code so I have to reset with the mem ok! Button then it boots up fine.
So now I’m lost. Is my motherboard going bad. I see my cpu memory Controller screwed? Or could it be my power supply?
My specs are as follows:
Asus x99pro Usb 3.1
32gb Corsair dominator platinum 3000
Corsair Ax860i psu
5820k cpu.
Gigabyte waterforce 1080Ti
Everything’s on water.
Please help. This crap is getting to me and idk how to fix this without buying all 3 and playing the lottery on which one is the problem.
I’m going to update the bios tonight to see if that fixes it.
Thanks In advance.
Alpina 7 is offline
post #2 of 6 (permalink) Old 04-10-2019, 08:30 AM - Thread Starter
Alpina 7's Avatar
My baby 😞
Alpina 7 is offline
post #3 of 6 (permalink) Old 04-10-2019, 08:59 AM
Shawnb99's Avatar
Rep: 13 (Unique: 9)
Buy a PSU tester if you're concerned it's the PSU.
If the ram works but just not in some slots then it's likely the MB and you'll have to replace it.
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is online now
post #4 of 6 (permalink) Old 04-16-2019, 01:02 AM
Retired Staff
66racer's Avatar
Rep: 120 (Unique: 103)
If the EK block is new and part of the upgrade, loosen the block and see if the mem slots start reading again. Less common with x99 but still worth a shot. Check your cables and pins in all the cables, sometimes custom cables might have a pin back out of a connector which makes poor contact as well. Remove connectors and see if the pins are all lined up properly.
Good luck, having half the RAM show up is concerning. I have seen two 5930k memory controllers die during the lifespan of that CPU.
66racer is offline
post #5 of 6 (permalink) Old 04-16-2019, 01:07 AM
The last VRM burner
Rep: 6 (Unique: 4)
Have you monitored DRAM Voltage and CPU IO as well as System Agent voltages?
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
EVGA GeForce GTX660 2048MB DDR5/192bit SuperClocked 1101MHz/1505MHz
2x KHX2400C11D3/8GX 11-12-12-32-1T-250
Samsung 850 Pro
Toshiba HDWD10 (P300)
Corsair CS650M
Raijintek Tisis + Arctic Cooling MX4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
SteelSeries Rival 310
Mousepad
SteelSeries QCk Mini
Audio
Audio in Motion SC808
Audio
AKG K240 Studio 1st rev
Other
NZXT Hue+
Other
Mayflash F300
BroadPwns is offline
post #6 of 6 (permalink) Old 04-16-2019, 05:02 AM
Overclocker in training
ThrashZone's Avatar
Rep: 46 (Unique: 37)
Hi,
Image is fuzzy but it does not look like you have both cpu power ports used on the board 8+4 pin
I tried without using the additional 4 pin port and couldn't do much of anything
Many say that it's not needed but it does not hurt to connect both ports.
There is a over volt jumper to actually use both power ports make sure it's not in over volt position.
Newer bios for broardwell-e does indeed over shoot voltages especially vccio cpu 1.05 voltage to 1.25v peg it at it's default voltage 1.05v and also vccio pch 1.05v.
So leave ram frequency at default 2133 for a while and of course no XMP.
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
