EVGA Z390 Dark USB questions - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 07-02-2019, 12:23 PM - Thread Starter
TMatzelle60's Avatar
Rep: 16 (Unique: 16)
I have a USB 3.1 Gen 2 Type-A port and I was wondering will I run into any problems hooking up the below USB 3.0 Hub to that port? Will this cause problems with any of my controls or anything I hook up to it?
The purchased hub.
https://www.newegg.com/orico-h7928-u...9SIA1DS0CF0426
TMatzelle60 is offline
post #2 of 5 (permalink) Old 07-02-2019, 12:42 PM
Custy
Rep: 12 (Unique: 8)
Sorry for your loss (-$28.40), and yes, backwards compatible =D
$13.59
https://www.amazon.com/ORICO-7-Port-.../dp/B018V7VMNC
"The Type-A connector is the USB connector found on most devices, the connector has to be positioned in a specific way to allow you to plug it in.
The Type-C connector is symmetrical. This means it will fit no matter which way is pointing up!"
Rocklin is offline
post #3 of 5 (permalink) Old 07-02-2019, 12:44 PM - Thread Starter
Only paid 10 dollars for it 3 weeks ago when they had a sale and coupon I had around so no lose on my side
But thank you for your help!
post #4 of 5 (permalink) Old 07-02-2019, 12:49 PM - Thread Starter
Thanks I understand the type A and type c but I wanted to make sure that the 3.1 Gen 2 port Type A would work fine and without hitch with the 3.0 hub I showed above. I know it won't run at those speed that gen 2 runs at but this hub is used for my Stick, Throttle and rudder pedals so I wanted to make sure
post #5 of 5 (permalink) Old 07-02-2019, 12:50 PM
Custy
Rep: 12 (Unique: 8)
you are redeemed, np =) smiles for you
Rocklin is offline
