MSI Z87-G45 won't post? - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 04-08-2020, 03:50 PM - Thread Starter
Rep: 3 (Unique: 3)
Hi All,
Apologies in advance if I've posted this in the wrong place, but I'm suddenly having an issue with my computer which I believe to be that the motherboard bought the farm, but would like confirmation based on expert opinions before I shell out the $$ for a new mobo and find myself in the same position but a bit lighter in the wallet.
I had just loaded up a game, maybe a few seconds in, and *crash*. The PC seemed to reboot but there was no display signal. I should note that I had 2 HDMI displays connected to my GFX card (all my rig details are in my sig), and was using the secondary display at the time. So I held the power button till it shut off, unplugged the power, re-plugged and tried again. Same thing, it powers on but no "beep" from the mobo (I can't specifically remember if it used to beep or not, but I believe it did), and no signal on any display. I took it apart, removing the GFX card and plugged one display to the onboard HDMI on the mobo. I removed the hard drives, and removed 2 of the 4 RAM sticks. Same thing. I tried removing all RAM. I've tried swapping RAM sticks. One of my displays has a VGA input and I'd like to connect it to that to rule out that it's simply not outputting a signal to the particular HDMI that I've connected to, since it was configured for the GFX card before, but I don't have a VGA cable. I've tried clearing the CMOS, and still the same result. It powers, but no beep and no display signal.
Can anyone advise if
a) This mobo is supposed to beep on post?
b) After clearing CMOS, should the mobo by default output a signal to the onboard HDMI? Or would it default to VGA/DVI?
c) Does it seem like this mobo is well and truly screwed or could it possibly be anything else that I haven't properly troubleshooted yet?
Thanks in advance for any replies.
My current rig
(11 items)
Intel Core i5-4670k Haswell
MSI Z87-G45 Gaming
Sapphire Radeon Nitro+ RX480 8GB
G.Skill Ripjaws X DDR3-2400 PC3-19200 4GBx2 (8GB)
Kingston 240GB SSD
OC-Z OCZ700MXSP
NZXT Gamma
Operating System
Windows 7 Ultimate 64-bit
Keyboard
Logitech G15
Mouse
Logitech G5
downer305 is offline
post #2 of 15 (permalink) Old 04-08-2020, 03:55 PM
What goes here?
speed_demon's Avatar
Rep: 142 (Unique: 101)
I had the MSI Z87-G55 and when my CMOS battery died the board starting acting a bit like this. Definitely time to replace the CR2032 battery either way at this point.
Ryzen 3900X
MSI X470 Gaming Plus
MSI R9 390 8GB
16GB DDR4-3000
120GB HP M700 SSD
Samsung Spintpoint M9T 2TB
Seagate Barracuda 500GB
Corsair HX1200 (2017)
Thermalright True Spirit 140
Fractal Define S
Operating System
Windows 10 LTSC
Keyboard
Alienware W/Cherry MX Switches
Mouse
Logitech G5
speed_demon is offline
post #3 of 15 (permalink) Old 04-08-2020, 04:05 PM - Thread Starter
Rep: 3 (Unique: 3)
Hi, thanks for the suggestion. I happened to have a spare CR2032 and just now swapped it out but unfortunately that didn't remedy the problem.
My current rig
(11 items)
MSI Z87-G45 Gaming
Kingston 240GB SSD
OC-Z OCZ700MXSP
NZXT Gamma
Operating System
Keyboard
Logitech G15
Mouse
Logitech G5
post #4 of 15 (permalink) Old 04-08-2020, 04:18 PM
cssorkinman's Avatar
Rep: 499 (Unique: 279)
Do you have a spare graphics card you can test with?
With all the troubles AMD's graphics drivers have at the moment, it could be the black screen bug.
My 5700XT will do this occasionally on its own and every time I choose restart in the windows shutdown menu.
cssorkinman is offline
post #5 of 15 (permalink) Old 04-08-2020, 04:40 PM - Thread Starter
Rep: 3 (Unique: 3)
Unfortunately, I don't have a spare GFX card to test with, but the mobo has a built-in display adapter with a DVI, VGA, and HDMI output. I've connected to the mobo's HDMI port, as I don't have a VGA cable or a display that supports DVI. So I'm keen to know whether the mobo will output to the on-board HDMI or not by default.
My current rig
(11 items)
MSI Z87-G45 Gaming
Kingston 240GB SSD
OC-Z OCZ700MXSP
NZXT Gamma
Operating System
Keyboard
Logitech G15
Mouse
Logitech G5
post #6 of 15 (permalink) Old 04-08-2020, 04:58 PM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
The PSU you have is terrible and might have killed your motherboard or something else
https://www.overclock.net/forum/31-p...tream-pro.html
This is not the first time an OCZ ModXStream Pro has killed something it has happened more than a few times and its known for it
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #7 of 15 (permalink) Old 04-08-2020, 05:18 PM - Thread Starter
Rep: 3 (Unique: 3)
Hmm, unfortunate to hear but interesting nonetheless. Thanks for the heads-up and I'll definitely take it under consideration and likely replace the PSU as a precaution when replacing whatever part has failed - once I've nailed down exactly which part failed. Do you reckon it's the mobo?
My current rig
(11 items)
MSI Z87-G45 Gaming
Kingston 240GB SSD
OC-Z OCZ700MXSP
NZXT Gamma
Operating System
Keyboard
Logitech G15
Mouse
Logitech G5
post #8 of 15 (permalink) Old 04-08-2020, 06:28 PM
It's not always easy to get it to switch onboard graphics for whatever reason.
I'm not nearly as particular about power supplies as Shilka is , but even I would say that's an awful psu.
post #9 of 15 (permalink) Old 04-08-2020, 07:17 PM - Thread Starter
Rep: 3 (Unique: 3)
Thanks, appreciate the advice. After Shilka's post, I started researching a bit and trawling eBay. I think I've narrowed it to either a Seasonic Prime Gold 750W or a Corsair SF600 Gold which fit within what I'm willing to spend. Would you guys suggest one over the other considering my setup? Admittedly, PSUs are probably the weak point of my PC knowledge. Is 750W overkill considering I'm only using one GPU? Or is it appropriate so that the PSU doesn't have to work so hard? Are there other alternatives you'd suggest?
My current rig
(11 items)
MSI Z87-G45 Gaming
Kingston 240GB SSD
OC-Z OCZ700MXSP
NZXT Gamma
Operating System
Keyboard
Logitech G15
Mouse
Logitech G5
post #10 of 15 (permalink) Old 04-09-2020, 02:43 AM
Senior OCN Member
shilka's Avatar
750 watt is overkill for a single GPU so anything higher than 650 watt is just a waste of money
As for the replacement the Prime is a good option but its not really what i would call cheap so you also got the Seasonic Focus GX if you are looking for something good but does not cost a fortune
And dont buy a second hand PSU from ebay thats very risky you dont know who the seller is and how the PSU was treated and for all you know it could be on its last legs which is why its being sold
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
