about to start a new build, Have a few questions, Starting with ASUS ROG MAXIMUS XII Extreme or Formula - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 07-01-2020, 05:00 PM - Thread Starter
Rep: 14 (Unique: 13)
Hi,
as the name says, I am about to start a build, and I have alot of questions so I will be posting in different parts of the forum. But my first question, which should I get a Formula or a Extreme? I am going to watercool, and the wc part is nice in the formula but is it really needed? But the extra M.2 is nice on the Extreme but is it worth the extra for the 2 m.2s? I have a ton other questions.
Thank you for your help, time and info!
this is what i am looking at, can be persuaded to change my mind if you can give me good reason and show me a pretty build with WC. I am also looking at getting a Asus ROG strix Helios case with a Bykski distro block but not sure, i know I want a distro plate in my build.
10900k (or 3900x or 3950x, haven't desided for exactly which one yet)
asus rog Maximus XII extreme or Formula (still not sure)
Asus GeForce RTX 2080 Ti 11 GB ROG Strix Gaming OC
Corsair Dominator Platinum RGB 64 GB (4 x 16 GB) DDR4-3600 CL16 Memory
Sabrent Rocket 2 TB M.2-2280 NVME x2
Seagate BarraCuda 120 2 TB 2.5" Solid State Drive x2
Darkshadow74 is offline
post #2 of 8 (permalink) Old 07-01-2020, 05:57 PM
Not New to Overclock.net
cstkl1's Avatar
Rep: 83 (Unique: 62)
ram oc. normally i say go extreme for that 16x4gb. but as it stands. hero vs formula vs extreme no diff. if anything hero .. from two ppl feedback actually seemed better ok 4x8gb.
daisy chain bro is a real problem on 4dimm. you stand a better chance of getting 2x32gb stable.
cstkl1 is offline
post #3 of 8 (permalink) Old 07-01-2020, 06:39 PM - Thread Starter
So I was wanting to fill out the ram slots to look more even. But there's a problem with it? Or is 3600 good enough with 4 sticks?
Future Build Coming up, will update this when I get it done.
post #4 of 8 (permalink) Old 07-01-2020, 09:56 PM - Thread Starter
Also looking at maybe a msi build but not sure what everything to match for the sake of a fan build.
post #5 of 8 (permalink) Old 07-01-2020, 10:50 PM
cstkl1's Avatar
seriously unknown.
afaik on ram stability for 4dimm
msi>giga>asus atm.
cpu
asus>msi>giga on ease of oc
cstkl1 is offline
post #6 of 8 (permalink) Old 07-01-2020, 10:52 PM
Rep: 0
I was torn between the two boards myself. I ended up settling on the combination of the Formula and the separate thunderbolt card from the Extreme which I was able to source separately. For me it came down to the fact there didn’t seem be any real advantages going any higher than the Formula from a memory OC or VRM perspective.
Another big factor was size for me, the Formula was the best ATX sized board and the Extreme was E-ATX which would have been cramped for my H500M case.
Sent from my iPhone using Tapatalk Pro
Thebc2 is offline
post #7 of 8 (permalink) Old 07-01-2020, 10:57 PM - Thread Starter
I've decide on the formula too. Now case should i use the asus rog helios? Or can you suggest a better case, need it to hold a reservoir plate and 2 360 rads.
post #8 of 8 (permalink) Old 07-01-2020, 11:10 PM
ezveedub's Avatar
Rep: 143 (Unique: 101)
If you're running dual 360 rads, then use the Lian Li 011D XL ROG case. I have my Hero Xii in that case now. I believe they have reservoir plates for it, but not sure, as I don't use them.
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
