Asus Rampage Extreme Overclocking Guide - Overclock.net - An Overclocking Community
post #1 of 830 (permalink) Old 09-04-2008, 10:01 AM - Thread Starter
Ghostleader's Avatar
Rep: 270 (Unique: 207)
Welcome to the Asus Rampage Extreme Overclocking Guide
Rampage Extreme reviews
Review at Hardware Canucks
Review at HardOCP
Review at Elite Bastards
Review at Legit Reviews
Review at Techgage
Other must read links
ASUS Maximus Extreme - the Extreme Benchmarker's Choice?
ASUS ROG Rampage Formula:Why we where wrong with the Intel X48
Intel X38 Tango - Is High FSB Overclocking Worth It?
Rampage Extreme Bios
Rampage Extreme Bios Ver 0206 Not official
Rampage Extreme Bios Ver 0301
Rampage Extreme Bios Ver 0401 Not official
Rampage Extreme Bios Ver 0403 Not official
Rampage Extreme Bios Ver 0501
Rampage Extreme Bios Ver 0601 Not official
Rampage Extreme Bios Ver 0701
Rampage Extreme Bios Ver 0801
Rampage Extreme Bios Ver 0901
Rampage Extreme Bios Ver 1104
Rampage Extreme Bios Ver 1201
Rampage Extreme Bios Ver 1202
Rampage Extreme Bios Ver 1301
Asus ftp site
EZ Flash 2 “ the best, the safest and the most convenient way to update BIOS"
Latest Intel chipset driver (Intel X48/ICH9 Chipset Software Installation Utility) from Station-Drivers.com
Latest Intel chipset driver (Intel X48/ICH9 Chipset Software Installation Utility) from X-drivers.com
Latest RAID driver (Matrix Storage Manager Driver) from Station-Driver.com
Rampage Extreme 1202 Bios Template
Extreme Tweaker
Ai Overclock Tuner           [Manual,Auto,X.M.P,CPU Level Up,Memory Level Up]
OC From Memory Level Up      [Auto,PC3-11600,PC-12800]
FSB Frequency                []
CPU Ratio Setting            []
> CPU configuration
C1E Support                  [Disabled,Enabled]
CpU TM Function              [Disabled,Enabled]
Max CPUID Value Limit        [Disabled,Enabled]
Vanderpool Technology        [Disabled,Enabled]
Execute Disable Bit          [Disabled,Enabled]
Core MultiPprocessing        [Disabled,Enabled]
* CPU clock skew             []
* NB clock skew              []
FSB Strap to North Bridge    [Auto,200,266,333,400]
PCIE Frequency               [100]
DRAM Frequency               []
DRAM Command Rate            [Auto,1N,2N]
DRAM Timing Control          [Auto,Manual]
1st information
CAS# Latency                 []
RAS# to CAS# Delay           []
RAS# PRE Time                []
RAS# ACT Time                []
RAS# to RAS# Delay           [Auto]
REF Cycle Time               [Auto]
WRITE Recovery Time          [Auto]
READ to PRE Time             [Auto]
2nd information
READ to WRITE Delay(S/D)     [Auto]
WRITE to READ Delay(S)       [Auto]
WRITE to READ Delay(D)       [Auto]
READ to READ Delay(S)        [Auto]
READ to READ Delay(D)        [Auto]
WRITE to WRITE Delay(S)      [Auto]
WRITE to WRITE Delay(D)      [Auto]
3rd information
WRITE to PRE Delay           [Auto]
READ to PRE Delay            [Auto]
PRE to PRE Delay             [Auto]
ALL PRE to ACT Delay         [Auto]
ALL PRE to REF Delay         [Auto]
DRAM Static Read Control     [Auto,enabled,disabled]
DRAM Dynamic Write Control   [Auto,enabled,disabled]
> DRAM Skew Control :
DRAM CMD Skew on Channel A   [Auto]
DRAM CLK Skew on DIMM A1     [Auto]
DRAM CLK Skew on DIMM A2     [Auto]
DRAM CTL Skew on DIMM A1     [Auto]
DRAM CLT Skew on DIMM A2     [Auto]
DRAM CMD Skew on Channel B   [Auto]
DRAM CLK Skew on DIMM B1     [Auto]
DRAM CLK Skew on DIMM B2     [Auto]
DRAM CTL Skew on DIMM B1     [Auto]
DRAM CTL Skew on DIMM B2     [Auto]
Ai Clock Twister             [Auto,Lighter,Light,Moderate,Strong,Stronger]
Ai Transaction Booster       [Auto,Manual]
(-- Manual --)
Common Performance Level     []
Pull in of CHA PH1           [Disabled]
Pull in of CHA PH2           [Disabled]
Pull in of CHB PH1           [Disabled]
Pull in of CHB PH2           [Disabled]
(-- Manual --)
EPU II Phase Control         [Auto,Full Phase]
*** Please key in numbers or select voltage!***
CPU Voltage                  []
Load-Line Calibration        [Auto,Disabled,Enabled]
CPU PLL Voltage              []
FSB Termination Voltage      []
CPU GTLVref(0)               [Auto]
CPU GTLVref(1)               [Auto]
CPU GTLVref(2)               [Auto]
CPU GTLVref(3)               [Auto]
NB GTLVref                   [Auto]
North Bridge Voltage         []
DRAM Voltage                 []
NB DDRVref                   [Auto]
DDR3 Channel A Vref          [Auto]
DDR3 Channel B Vref          [Auto]
South Bridge 1.5 Voltage     []
South Bridge 1.05 Voltage    []
CPU Spread Spectrum          [Auto,Disabled]
PCIE Spread Spectrum         [Auto,Disabled]
Moderate OC suggestion
Here´s a moderate OC suggestion that I have so you can get started.
400 9 3,6GHz 1600 777 21 Strong tRD5 (this one is a real sweet spot when use bus 400 and ram @ 1600, if you want know why, read this post)
Tested with BIOS 1202, Q9650, 2x2 OCZ Platinum LV PC3-12800 (1600C7) and GTX 285.
If people run different BIOS, cpu and/or ram configuration some volt values have to be alter.
People in this thread that run other configurations can give suggestion to what changes has to be done.
Transferred ownership of thread to Ghostleader [Robilar]
Courtesy to Robilar for the pictures below.
"The Househeater"
Crosshair V Formula-Z / FX-8350 / G.Skill TridentX 2400C10 / GTX690
Ghostleader is offline
post #2 of 830 (permalink) Old 09-04-2008, 10:01 AM - Thread Starter
Reserved 1
"The Househeater"
post #3 of 830 (permalink) Old 09-04-2008, 10:02 AM - Thread Starter
Reserved 2
"The Househeater"
post #4 of 830 (permalink) Old 09-04-2008, 10:02 AM - Thread Starter
Reserved 3
"The Househeater"
post #5 of 830 (permalink) Old 09-04-2008, 10:06 AM
Rep: 287 (Unique: 233)
i hate you. seriously.
I can not wait for some pics.
Mmansueto is offline
post #6 of 830 (permalink) Old 09-04-2008, 10:08 AM
Retired Staff
Robilar's Avatar
Rep: 675 (Unique: 477)
Hang on, I'll post a couple of teasers...
Home PC
Intel G3440
Asus B85M-E/CSM
EVGA GTX 950
Patriot Viper 3 - 2x8GB 1600hz
Samsung EVO 850 - 500GB + 4TB x2 / 3TB x 2 - WD
Optical Drive
LG CH12LS28 Bluray
Corsair CX430 V2
Scythe Big Shuriken 2 w/Corsair SP120 Fan
NMEDIAPC HTPC 6000B w/ Pro LCD Module
Operating System
Windows 10 64 Bit
Samsung 75" TV....
Keyboard
GooBang Doo MX3
Mouse
GooBang Doo MX3
Robilar is offline
post #7 of 830 (permalink) Old 09-04-2008, 10:09 AM
Rep: 188 (Unique: 162)
I thought it was coming in this Friday Rob ?.
"Don't talk like one of them. You're not! Even if you'd like to be. To them, you're just a freak, like me! They need you right now, but when they don't, they'll cast you out, like a leper! You see, their morals, their code, it's a bad joke. Dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these... these civilized people, they'll eat each other. See, I'm not a monster. I'm just ahead of the curve."
45nm is offline
post #8 of 830 (permalink) Old 09-04-2008, 10:15 AM
Retired Staff
Robilar's Avatar
I went and picked it up myself.
Check the first thread for a few initial pics
Home PC
Intel G3440
Asus B85M-E/CSM
EVGA GTX 950
Optical Drive
LG CH12LS28 Bluray
Corsair CX430 V2
Operating System
Windows 10 64 Bit
Samsung 75" TV....
Keyboard
GooBang Doo MX3
Mouse
GooBang Doo MX3
Robilar is offline
post #9 of 830 (permalink) Old 09-04-2008, 10:16 AM
I have told him on numerous occasions, that he makes it mighty hard for anyone to play catch-up.
I may be getting this board. the Maximus Extreme is such a tempermental board. i constantly have issues with it. Mainly the RAM. I hope that the Rampage Extreme is better.
I am curious to see how easy the tweak-it controls are to access with 2 gpus installed.
Rob, you are one lucky man. Now get that watercooling system built.
EDIT: that is a very nice looking board.
post #10 of 830 (permalink) Old 09-04-2008, 10:17 AM
Retired Staff
Robilar's Avatar
Next on the list. I particularly like the fact that the swiftech water block will fit on the NB without any modifications
Home PC
Intel G3440
Asus B85M-E/CSM
EVGA GTX 950
Optical Drive
LG CH12LS28 Bluray
Corsair CX430 V2
Operating System
Windows 10 64 Bit
Samsung 75" TV....
Keyboard
GooBang Doo MX3
Mouse
GooBang Doo MX3
Robilar is offline
