Need help on Chiller Fluid - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 12-27-2018, 05:53 PM - Thread Starter
Rep: 0
Hello,
this probably should've gone in the regular water cooling section but oh well. Anyway, I need advice on the fluid for my chilled loop. I need one that wont kill my acrylic blocks but will help me go as low as possible. Thank you!
Bradwell is offline
post #2 of 12 (permalink) Old 12-29-2018, 02:19 AM
Not new to Overclock.net
Willhemmens's Avatar
Rep: 217 (Unique: 191)
Most people use automotive antifreeze/engine coolant as far as I know.
Willhemmens is offline
post #3 of 12 (permalink) Old 01-02-2019, 07:08 PM
Rep: 21 (Unique: 21)
The best option that is cost effective is pure or nearly pure ethanol. You can find it in the form of indoor fireplace fuel. I’ve had trouble sourcing legitimate pure ethanol but have taken the fireplace fuel down to -40 with no freeze up. You can also use methanol in the form of windshield wiper fluid but methanol can be dangerous.
Glycol based coolant will start to gel at lower temps and put major strain on your pump.
If you can’t source ethanol at all you can use Everclear drinking spirits but that is pricey.
Veltri is offline
post #4 of 12 (permalink) Old 10-01-2019, 03:49 AM
Rep: 1 (Unique: 1)
What are you using chill the ETOH to -40c?
Thermal_Preist is offline
post #5 of 12 (permalink) Old 10-01-2019, 05:08 AM
Meep
Gilles3000's Avatar
Rep: 308 (Unique: 224)
Unfortunately, ethanol will damage acrylic, as do most solvents.
I believe there are some engine coolants that will still stay fairly fluid at very low temperatures. Another user on the forum just bought a bunch of antifreeze brands and just put samples in the freezer at different ratios to see which gels up the least with the highest water content.(water still hast the highest thermal capacity)
Gilles3000 is offline
post #6 of 12 (permalink) Old 10-01-2019, 07:39 AM
Overclocker in training
ThrashZone's Avatar
Rep: 92 (Unique: 67)
Hi,
Which chiller ?
Home made/ retail ?
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #7 of 12 (permalink) Old 10-02-2019, 01:32 AM
Rep: 1 (Unique: 1)
Yes it will...but there are also plenty of non acrylic blocks...if you go this way just swap out the blocks.
Acetal is ethanol and methanol safe, as are EPDM and Nitrile...plenty of blocks and o-rings not made from acrylic. Acetal is even ok with Acetone. for that matter there are plenty of full copper/nickle blocks.. also safe with ethanol.
even plenty of reservoirs made from glass which again is safe with ethanol.
your biggest issue is could be your pump choice...which again...even EK lists the materials... Stainless steel, PPS-GF40, EPDM O-rings, Aluminium oxide... all ok with Ethanol.
PPS-GF40 - (Xytron) - which is the impeller mould...again excellent resistance to acetone at and ethanol.
post #8 of 12 (permalink) Old 10-02-2019, 01:37 AM
Meep
Gilles3000's Avatar
Quote: Originally Posted by Thermal_Preist View Post
Yes it will...but also plenty of non acrylic blocks...if you go this way just swap out the blocks.
Spoiler!
I know, but OP specifically asked for a coolant that won't damage his acrylic blocks, so I'm pretty sure he wants to keep them.
post #9 of 12 (permalink) Old 12-01-2019, 08:50 PM
Home built chiller.
Veltri is offline
post #10 of 12 (permalink) Old 12-01-2019, 08:59 PM
True. But acrylics really aren’t suitable for chillers anyway. If OP wants to play around near dew point, sure, they will work. But the real low temperatures will destroy off-the-shelf water cooling components regardless of the coolant. The waterblock on my chiller is fully brazed shut and all copper. It looks a lot like an evap from a phase unit. No O rings or gaskets or plastic parts anywhere. They just don’t hold up to low temps.
Veltri is offline
