Below Ambient AMD (Ryzen 3000 & Navi) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 26 (permalink) Old 08-05-2019, 04:48 AM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by Cerberus View Post
is this for 24/7 use? I ran a SS phase back on my 955BE, it ran well for a long long time, but I ended up getting pin rot, even with die-electric grease in the cpu socket. 4 pins fell off.
Yes 24/7.
Corrosion that caused your pin rot only occur with both oxygen and moisture (hydrolysis/electrolysis & oxidation)... so in a dry nitrogen atmosphere this issue is prevented. Hence my interest in anybody’s experience running a system under N2 desiccation.
Thermal_Preist is offline
post #22 of 26 (permalink) Old 08-05-2019, 04:58 AM
Missing the Old days
Cerberus's Avatar
Rep: 253 (Unique: 217)
Quote: Originally Posted by Thermal_Preist View Post
Yes 24/7.
oh, you're not wrong, I ran -40c in a room with no a/c for nearly three years without disassembly. it ran fine even with those 4 pins gone (by fine i mean it was able to play cs source and browse the web)
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Folding Rack
(9 items)
Work Folder
(7 items)
AMD r7 2700x
ASUS ROG Crosshair VI Hero
Nvidia Titan X Pascal
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G602
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD r7 1700x
MSI X470 Gaming Plus
ZOTAC GTX 980 AMP!
Geil EVO 1x4GB DDR4
Toshiba 3TB
Silverstone ST-1000PT
4U Rosewill
Operating System
Ubuntu 18.04LTS
Headless
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
post #23 of 26 (permalink) Old 08-09-2019, 10:27 PM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by ShrimpBrime View Post
I do agree 100%. But I'm an enthusiast and take interest in specialized cooling such as glycol chillers and SS.... probably because I've never used either cooling type apparatus.
But done plenty of other chilling methods, just about all the other chilling methods in fact.
Currently running 2700X on stock air. -30c didn't make any difference in max OC, but did allow the use of lower volts at X oc.
Just curious what flow rate you are getting at -30c and what fluid?
also, how many pumps in series are you using?
post #24 of 26 (permalink) Old 08-10-2019, 09:31 PM - Thread Starter
Rep: 1 (Unique: 1)
After doing some more flow testing and temp testing, i think i can control the pressure and temps down to -20c at 42-45% glycol for benchmarks, i think -12 will be the limit for full load continuous operation with 1 GPU.
But to get sufficient flow at G1/4 i will need to add pumps.
Option 1
- two pumps in series and remove CPU jet plate giving a fluid flow:
Chiller > Agitator pump > RAD > twin d5 in series > CPU > GPU(s) > Chiller
with Jet plate in, the pressures spike when flowing enough.
Option 2
- one pump for CPU with jet plate still in
- one pump for GPU
- common return to chiller.
Has anyone run Glycol like this before? what was the solution for jet plate restrictions?
post #25 of 26 (permalink) Old 08-12-2019, 10:19 PM
FX-5000
ShrimpBrime's Avatar
Rep: 66 (Unique: 47)
Flow rate is variable. However it's (water) not cooling a processor, it's cooling a TEC which cools the cpu to -30c.
I was merely stating that even at such a temperature, -30c, there was no more to be gained with a 2700X processor. Better results with Ryzen chips would be under an LN2 pot. sry for any confusion there.
ShrimpBrime is offline
post #26 of 26 (permalink) Old 08-12-2019, 11:31 PM
Rep: 3 (Unique: 3)
Quote: Originally Posted by Iwamotto Tetsuz View Post
Spending the money on the xtreme cooling gives dimineshing returns
Compared to the fancy CPU w a cheap 120mm AIO chiller + OC
I belive overclocking is stupid if you want outright perfomance and you currently are water chilled with AIO water 120mm rads or better.
Overclocking older tech often has the same practical value as hot-rodding your dad's 1980's Mitsubushi Galant.
Whilst there may be street cred in having the fastest Mitsubushi Galant in the state, it is still going to be slower than your mum's stock 2019 model SUV.
clannagh is offline
