Can we please talk about Water chillers?! 3950x cooling upgrade possibly - Overclock.net - An Overclocking Community
post #1 of 42 (permalink) Old 12-07-2019, 01:04 PM - Thread Starter
newls1's Avatar
Rep: 30 (Unique: 25)
Currently, my 3950x is pretty tough to keep cool with my highend water cooling (EK 60mm 420 rad in push/pull fan config, D5, heatkiller Pro IV copper block cpu only loop) with CCD0 @ 4.525GHz and CCD1 @ 4.325GHz using 1.350v die and package temps will be VERY HARD to cool during summer times here in Atlanta Ga area. Absolutely always wanted to experiment with a waterchiller, more specifically the units performance-pcs sells. They seem priced right and have good reputations for being constant duty units (even though this pc will never be run for very long durations, its more of just a fun pc to play with) in the below links are the chillers im looking in to. Having a hard time deciding if 400watts will be enough or 790watts for extra insurance. Also, my current water cooling setup is 2 separate loops. 1 for cpu and 1 for gpu, but when I go chiller, do i combine both cpu and gpu and have the gpu reep the benefits of this type of cooling, or just keep it simple at first and make it cpu only at first...? I know people say to remove the rad from the chilled loop, but is this still the case? I mean it makes sense, might actually "ADD" heat into the loop, so i understand the theory behind it, but if i was to leave it in as a fail safe, is that bad?
I understand the whole condensation thing, i used to phase change cool with a "chilly1" phase changer back in the day with my FX55/FX57 overclocks, but these chillers I can set right to the dew point to minimize condensation, but of course i will do extra preventative measures to prevent hardware failure. Need your thoughts and opinions on this possible future cooling upgrade (pretty huge upgrade) hopefully someone has experience with waterchillers and can tell me yay or nay? Thank you
https://www.performance-pcs.com/wate...r-hc-300a.html
https://www.performance-pcs.com/wate...r-hc-500a.html
**Intel System** Asus Z390E Strix / 8700k @ 4.85Ghz / 32GB BDie @ 3200 CL14 / PowerColor 5700XT / eVGA 850w PSU / Sammy 960 EVO m.2 / MX500 250gb games SSD / 49" Samsung UltraWide 144Hz
**AMD System** Asus ROG Crosshair VIII Hero / 3950X @ 4.580GHz (CCD0) 4.380GHz (CCD1) 1.350v/ 64GB DJR Mem @ 3740MHz CL16 / 2080 Ti / eVGA 1200 Plat PSU / Sabrent 1Tb PCIe4.0 m.2 / MX500 500gb games SSD / 34" LG UltraWide 144Hz
(Dual watercooling loops for CPU and GPU, all highend)
newls1 is online now
post #2 of 42 (permalink) Old 12-07-2019, 01:10 PM
skupples's Avatar
Rep: 629 (Unique: 342)
well, one big loop is traditionally a better option than splitting things, and if you keep the chiller set at a conservative temp, you shouldn't have any issues.
I return to this idea every summer, trust me.
skupples is online now
post #3 of 42 (permalink) Old 12-07-2019, 01:34 PM - Thread Starter
newls1's Avatar
well, lets do it. make it a group purchase maybe performance pcs will cut a few bucks off if we both purchase??
post #4 of 42 (permalink) Old 12-08-2019, 09:48 AM - Thread Starter
newls1's Avatar
ok, so im going to purchase this chiller ( https://www.performance-pcs.com/wate...r-hc-300a.html ) now the last final questions... Is there a res inside that unit i need to fill and use along with a res in my case? Would using 2 D5's in series be a good choice to go with, and do i mount them in my case, or what? really getting excited about this as this would be a HUGE cooling upgrade but i dont want to rush into this without doing all my homework?
post #5 of 42 (permalink) Old 12-08-2019, 10:06 AM
Hardware Princess
Hydroplane's Avatar
Rep: 37 (Unique: 29)
The 300 should be plenty for a 3950x running above the dew point. Go for the 500 if you want to add the radeon 7 to the loop. The unit has a res internally but you will need a pump. 1 D5 is plenty, you can put it wherever you want. You will want to get a humidistat (like $10 on amazon) if you don't have one. Then you can use a site like dpcalc.org to calculator/monitor your dew point.
Definitely take the rad out, if you are running the water below room temp, then the rad is adding heat to the loop instead of removing.
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #6 of 42 (permalink) Old 12-08-2019, 10:32 AM - Thread Starter
newls1's Avatar
thanks for the reply. i was hoping to keep the rad in just for a failsafe, and on cold days when i dont need the chiller, it would be like using a normal loop. Also, performance pcs says to keep rad in, and i always wondered why. I understand the logic behind it, like it will add heat, but..... will it really be that much??
post #7 of 42 (permalink) Old 12-08-2019, 10:41 AM
Why is it smoking?
Mr. Mojo's Avatar
Rep: 361 (Unique: 296)
Just spitballing here, but you could run the rad in parallel with the chiller and include shutoff valves on both, which would make switching between the 2 trivial.
Black Feathers
(22 items)
AMD Ryzen 7 3700x
Gigabyte x570 Aorus Pro Wifi
Sapphire Radeon RX 5700 XT
Crucial Ballistix Elite DDR4 3600
Sabrent Rocket NVMe PCIe 4.0 M.2 2280
Sabrent Rocket NVMe PCIe M.2 2280
Seasonic FOCUS Plus 750
EK-KIT Classic RGB P360
EK-Vector Radeon RX 5700 +XT RGB - Nickel + Plexi
Arctic P12 PWM PST
DEEPCOOL RF120M
XSPC G1/4" Inline 10k Sensor, Chrome
EK-CryoFuel Solid Cloud White (Premix 1000mL)
Lian-Li PC O11 Dynamic (white)
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio Technica ATH-M50x
Audio
Logitech Z333
Intel Core i7 4710HQ
NVIDIA GeForce GTX 970M
16GB DDR3L
Samsung 850 EVO
HGST Travelstar 7K100
Operating System
Windows 10
BenQ XL2720T
Keyboard
Microsoft Sidewinder X4
Mouse
Gigabyte M8000X
Mouse
Steelseries
Audio
Audio-technica ATHM40x
Audio
MTX iX1 Headphones
Mr. Mojo is offline
post #8 of 42 (permalink) Old 12-08-2019, 04:05 PM - Thread Starter
newls1's Avatar
trying to think where on my loop i introduce the chiller into.. my loop is as follows, pump-res combo, rad, cpu block, res. So how do i plumb this chiller in? go like this maybe: Res - pump - out of case down to chiller - back into case to cpu block - res?
post #9 of 42 (permalink) Old 12-08-2019, 05:18 PM
Overclocker in training
ThrashZone's Avatar
Rep: 115 (Unique: 78)
Hi,
Air chilling is a lot more straight forward and can be used in other applications than water chiller can
Air chiller can be a backup if house a/c goes out or for outside events
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #10 of 42 (permalink) Old 12-08-2019, 07:33 PM
toolmaker03's Avatar
Rep: 90 (Unique: 68)
ok so can this CPU and GPU be chilled yes. first point go to the phase change section to get more information. second you will need at least twice the cooling capacity, of the load wattage to cool that component. so will a 500 watt cooler cool a 790 watt CPU? no it will not. in fact it will take at least 1500 watts of cooling to keep this cool. so it will take three 500 watt units to keep this CPU cool.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is online now
