OFFICIAL XSPC Raystorm Club - Page 3 - Overclock.net - An Overclocking Community
post #21 of 2341 (permalink) Old 10-06-2011, 04:53 PM - Thread Starter
macca_dj is an unknown quantity at this point macca_dj is an unknown quantity at this point macca_dj is an unknown quantity at this point
macca_dj's Avatar
Originally Posted by Not A Good Idea;15202837
Ok so i got mine in... 2 questions for you Martin if you're reading this (or anyone else that knows the answer may chime in)
1. What are all these backplates for? which is which?
2. How does the K2 Thermal paste they supply compare to Shin-Etsu (Shin-Etsu MicroSi X-23 7783D)?
3. how do the actual screws assemble. this didn't come with instructions (not to difficult to figure out, but i rather be safe then sorry...
thanks
ps quality looks great on this.
Congrats to you we hope to see some bench / comparisons between your previous cooler to,
I would presume the Water block fits the exact same way the RASA,
[ame]http://www.youtube.com/watch?v=WsONrAhuXeA&feature=related[/ame]
macca_dj is offline
post #22 of 2341 (permalink) Old 10-06-2011, 06:13 PM
Linux Lobbyist
Not A Good Idea Level 1
Not A Good Idea's Avatar
i just went on their website.. order is :spring, metal washer, plastic washer smile.gif
I pick things up, then i put them dooooown!
LMAO
Not A Good Idea is offline
post #23 of 2341 (permalink) Old 10-06-2011, 07:31 PM
Linux Lobbyist
ok well ive been running it for an hour so far... flow in my system seems to have increase by 25%. im estimating this because my flow meter spins ALOT faster now biggrin.gif and there is turbulence in my res where there wasnt before.
my water setup includes:
2 655 with ek tops
1 xspc dual bay res
3 xspc razor 580 blocks
1 xspc raystorm (replaces the swiftteck xt r2)
2 phobyia 360.2 rads
1 phobyia 240.2 rad
9 feet of 3/8ID tubing.
my idle temps are now 27 for my video cards, 35 for my cpu @5.1ghz
under load my temps are 43 for video cards.... and for my cpu... 57 (using the k2 stuff. im not sure if it has a cure time)
before they were 30 for VC, 40 for cpu
load was 47 vc and 70 for cpu with shin etsu and XT rev2
LMAO
post #24 of 2341 (permalink) Old 10-06-2011, 08:32 PM - Thread Starter
macca_dj's Avatar
Good going on the flow gain,
Have you marked down your ambient room temp so we can see if in time the XSPC K2 needs a curing time ?
Edit
We are going to be loving some pics of it in your system or even a Video link to youtube ;-)
macca_dj is offline
post #25 of 2341 (permalink) Old 10-06-2011, 09:14 PM
Raul-7 is an unknown quantity at this point Raul-7 is an unknown quantity at this point
Available at Sidewinder Computers.
A man who praises himself displays his deficiency of intellect.
Raul-7 is offline
post #26 of 2341 (permalink) Old 10-06-2011, 11:16 PM
Martinm210 has a spectacular aura about Martinm210 has a spectacular aura about Martinm210 has a spectacular aura about Martinm210 has a spectacular aura about Martinm210 has a spectacular aura about Martinm210 has a spectacular aura about Martinm210 has a spectacular aura about Martinm210 has a spectacular aura about Martinm210 has a spectacular aura about
Martinm210's Avatar
thanks
1) This should answer the back plate question in the upper left. Mine came with the Rasa instructions, but I'm guessing they are working on a Raystorm specific version. I only used the 1156 backplate for my i7-2600K processor (1156) socket motherboard.
xspc-rasa-11.jpg?w=614&h=494
2) I have not tested the K2, but based on it's consistency and looks, I would rate it pretty high or at least higher than any white pastes. I believe Vapor is going to test this TIM at some point which will be the more definitive test...he has TIM testing down to a fine science.
3) Yep, like this:
xspcraystorm071.jpg?w=614&h=661
Martinm210 is offline
post #27 of 2341 (permalink) Old 10-08-2011, 04:52 PM
16ReasonsWhy Level 1
it easy to pop those blue LED off and slap on some red ones?
16ReasonsWhy is offline
post #28 of 2341 (permalink) Old 10-08-2011, 05:37 PM
Nano5656 Level 1
Nano5656's Avatar
Ordered mine smile.gif I can't decide if I should switch from my 7/16 tubing and 1/2 barbs to 1/2 tubing and 1/2 id xspc black chrome compression fittings as well, ahhhh frown.gif
Nano5656 is offline
post #29 of 2341 (permalink) Old 10-08-2011, 05:40 PM
yanks8981 is on a distinguished road yanks8981 is on a distinguished road yanks8981 is on a distinguished road yanks8981 is on a distinguished road
yanks8981's Avatar
got mine in the mail this week, will be setting it up next week!
yanks8981 is offline
post #30 of 2341 (permalink) Old 10-08-2011, 07:27 PM
PTB2 Level 1
PTB2's Avatar
mine is here need to get 2 gtx 580's next then the watercooling begins.
its going to sit in the box for a bit till then.
PTB2 is offline
