H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 10 - Overclock.net - An Overclocking Community
post #91 of 1518 (permalink) Old 11-25-2011, 06:17 PM
Rep: 9 (Unique: 8)
Anyone know or have a link to information on whether the H80 will fit in a silverstone sugo sg-03 case?
I believe the H40 and H50 fit but the H80 is much larger
granno21 is offline
post #92 of 1518 (permalink) Old 11-27-2011, 06:29 AM
michael_sj123's Avatar
Rep: 0
If I buy two of these and mount them on my DF-85 and connect the H100 to it, would it work or would it look plain stupid (and not work)?
michael_sj123 is offline
post #93 of 1518 (permalink) Old 11-27-2011, 06:34 AM
jdip's Avatar
Rep: 21 (Unique: 21)
jdip is offline
post #94 of 1518 (permalink) Old 11-27-2011, 10:32 AM
kev_b's Avatar
Rep: 153 (Unique: 80)
kev_b is offline
post #95 of 1518 (permalink) Old 11-28-2011, 03:19 PM - Thread Starter
Rep: 87 (Unique: 80)
Originally Posted by jdip View Post
Thanks! Might have to get it made into a sticky soon!
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #96 of 1518 (permalink) Old 11-28-2011, 03:20 PM - Thread Starter
Originally Posted by kev_b View Post
Here's a updated picture, maybe after the holidays I'll build a intel setup.
450
Looks good, getting massive though!
post #97 of 1518 (permalink) Old 11-28-2011, 03:26 PM - Thread Starter
Personally I wouldn't, you won't get any cooling benefit, you'd be better off with 2 decent 120mm fans like the Scythe GT-1850rpm, they're quieter than the Corsair fans and cool about the same.
As for whether it would fit, there is a link to your case on my first post, but it's not great. I haven't received any better info yet.
post #98 of 1518 (permalink) Old 11-28-2011, 03:34 PM - Thread Starter
I don't have a yes or no answer, had a look at the case, I'm not familiar with it. I would say yes initially, but it would be very hardware dependant based on dimensions. Sorry I can't be of more help, if you do find a definitive answer, let us know so i can update the thread!
post #99 of 1518 (permalink) Old 11-28-2011, 03:36 PM - Thread Starter
Thread has been updated with the most recent posts, good to see this thread is now appearing as first result on google when searching H80/100 and certain case names!
i'm off to continue my hols, will check back when I'm home.
Thanks again to the input so far!
post #100 of 1518 (permalink) Old 11-28-2011, 06:47 PM
5point6Titan's Avatar
Rep: 2 (Unique: 1)
i've had this case for a little over 3 years and i can't remember the exact model of the ThermalTake Armor series.
no fitment issues. good clearances with the mobo.
i'm using the 2 fans that were included with the H80...are there better fans out there? with the same low noise, of course?
mid 30's overclocked, to me is great....air cooling may be cheaper, but at least we don't have a huge chunk of aluminum and copper hanging off of the socket.
700
571
5point6Titan is offline
