H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 11 - Overclock.net - An Overclocking Community
post #101 of 1518 (permalink) Old 11-28-2011, 08:10 PM
skwannabe's Avatar
Rep: 6 (Unique: 4)
Is the H100 compatible with Fractal R3?
skwannabe is offline
post #102 of 1518 (permalink) Old 11-30-2011, 12:14 AM
DarkStarCow's Avatar
Rep: 3 (Unique: 3)
Silverstone, Raven RV-03
H100
Front drive bay, pulling air into case.
Completely fills drive bay area so no drives can be installed. Can only have a "push" configuration.
DarkStarCow is offline
post #103 of 1518 (permalink) Old 11-30-2011, 11:00 AM
chinmi's Avatar
Rep: 1 (Unique: 1)
i have a very very old pc case, and thank god the h80 fits perfectly on it :
700
it's a very old asus ta-d2
450
planning on buying a better case to fit all my hardware, puting a 6990 and 460 (physx) inside this case makes it quite hot inside it....
i'm planning on getting a corsair 500r and upgrade my h80 to a h100. now i just wanna make sure, that i can easily put the h100 on 500r top fan place push pull configuration without the need of any modification right ??
chinmi is offline
post #104 of 1518 (permalink) Old 12-05-2011, 03:17 AM - Thread Starter
Rep: 87 (Unique: 80)
H100 will be fine in the 500r. See this link https://www.overclock.net/t/1130705/2500k-corsair-500r-with-h100#post_15141048
This only shown in push or pull, but as you can see, an additional pair of fans can fit on top easy enough, but some fan guards would be reccomended.
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #105 of 1518 (permalink) Old 12-05-2011, 03:33 AM - Thread Starter
Originally Posted by 5point6Titan View Post
i've had this case for a little over 3 years and i can't remember the exact model of the ThermalTake Armor series.
no fitment issues. good clearances with the mobo.
i'm using the 2 fans that were included with the H80...are there better fans out there? with the same low noise, of course?
mid 30's overclocked, to me is great....air cooling may be cheaper, but at least we don't have a huge chunk of aluminum and copper hanging off of the socket.
Not sure of the exact model either, the front looks the same as a lot that I've seen, i could tell you with an image of the top.
post #106 of 1518 (permalink) Old 12-05-2011, 03:34 AM - Thread Starter
I'm back, thread updated, reps given etc etc!
post #107 of 1518 (permalink) Old 12-06-2011, 05:36 PM
Ever Forward.
PR-Imagery's Avatar
Rep: 231 (Unique: 166)
H80 fits Silverstone TJ10 rear fan mount, tho when removing the mobo tray either the vertical support bar needs to be removed or the radiator needs to be removed first, as the rad hits the lip which the tray screws on to. Will also fit top fan mount with the Silverstone Rad support bar as well as the H100(should anyway, will know for sure when my H100 comes)
Probably obvious but it will be difficult to impossible to reach any connectors in the top left corner of the motherboard with the H80 mounted in the rear fan mount, even with the removable tray. May reduce airflow around vrm/mosfets.
450
450
450
"The greatest good you can do for another is not just to share your riches but to reveal to him his own."
PR-Imagery is offline
post #108 of 1518 (permalink) Old 12-07-2011, 06:45 AM - Thread Starter
Thanks, perfect post!
post #109 of 1518 (permalink) Old 12-08-2011, 11:36 AM
marblesmike's Avatar
Rep: 0
Does anyone know if the H80 (push-pull) will fit in the 400r case?
marblesmike is offline
post #110 of 1518 (permalink) Old 12-08-2011, 06:26 PM
Rep: 2 (Unique: 2)
Corsair H80
Fits in Fractal Design's Core 3000 case. I mounted it in the rear, the top works too, depending on how you want it setup.
448
tonyw is offline
