H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 14 - Overclock.net - An Overclocking Community
post #131 of 1518 (permalink) Old 12-21-2011, 08:43 PM
boss_da_man's Avatar
Rep: 3 (Unique: 3)
Just installed a H80 in a Antec Eleven Hundred case.
http://www.antec.com/Believe_it/product.php?id=NzA0NTA1&lan=us
boss_da_man is offline
post #132 of 1518 (permalink) Old 12-22-2011, 05:33 AM
XBarbarian's Avatar
Rep: 3 (Unique: 3)
450
Lame Droid X pic.. and more cable mgmnt required.. but
H80 with both Push / Pull Inside TJ08-E
no O/C yet.. tonight!
Humility isn't thinking less of yourself, it is thinking of yourself less often
XBarbarian is offline
post #133 of 1518 (permalink) Old 12-22-2011, 07:59 AM - Thread Starter
Rep: 87 (Unique: 80)
Do you have pics of the install?
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #134 of 1518 (permalink) Old 12-22-2011, 08:02 AM - Thread Starter
Originally Posted by hmar View Post
H80 fits at the back or upper site of an Antec P183 V3 case, no H100 however
hmar
Any pics of the install?
post #135 of 1518 (permalink) Old 12-22-2011, 08:05 AM - Thread Starter
Thread updated, if i missed any posts then let me know!
post #136 of 1518 (permalink) Old 12-22-2011, 08:08 AM - Thread Starter
Originally Posted by m0bius View Post
I don't have a pic on hand to prove it at the moment, but I have an h100 p/p in my Corsair 500r. It is most definitely a tight fit however, bottom fan hang precariously over VRM heatsink of CHVF with less than 1mm clearance.
WOuld really liks to see a pic if you have one, would help a lot of people if the fit is really tight. Thanks
post #137 of 1518 (permalink) Old 12-22-2011, 10:01 AM
Ever Forward.
PR-Imagery's Avatar
Rep: 231 (Unique: 166)
H100 came in, fits perfectly in the top dual fan mount of the TJ10(it would also fit in the top fan mount of the TJ09, as both cases are structurally exactly the same). The radiator bracket hasn't arrived yet tho, so its just twist-tied to where the bracket would go.
450
(Will get a cleaner pic when the bracket arrives)
The H80(the H100 in push/pull is about the same thickness as the H80 with just one fan) would fit in the top mount(will require bracket or will need to be tied/screwed on to the tool-less fan mount) as well in either a push or pull configuration but not push/pull
*you may be able to do push/pull depending on your motherboard layout, such as some AMD boards, but on most Intel motherboards in push/pull it will hit either the memory slots or processor/pump.*
On installing the H100 properly it was found that it will not fit as perfectly in a p/p on motherboards with the cpu or any connections running along the top edge.
450
450
450
That may be a problem.
450
Slim height fans would work however > 120mmx12mm - 120mmx20mm- Frozen-cpu
450
"The greatest good you can do for another is not just to share your riches but to reveal to him his own."
PR-Imagery is offline
post #138 of 1518 (permalink) Old 12-22-2011, 05:40 PM
Rep: 3 (Unique: 3)
Yes I do.. I will uploaded it... (later on)
post #139 of 1518 (permalink) Old 12-22-2011, 08:28 PM
5point6Titan's Avatar
Rep: 2 (Unique: 1)
old case : thermaltake armor
new case : Cooler Master Silencio
no fitment issues with the H80, perfect fit. with the H80 on the lowest fan setting and the sides on and the front panel closed...it's dead silent from a few feet away.
the case came with a fan in the rear 120mm place, but i re-located that to the front along with the fan already there. i think i will probably have to get higher output fans, these seem kinda weak.
700
700
535
540
5point6Titan is offline
post #140 of 1518 (permalink) Old 12-22-2011, 08:40 PM
Rust Buckets for Days
axipher's Avatar
I can't 100% confirm the H80 specifically, but the CoolIt Eco 120 mm Rad fits perfectly fine in the front of the Fractal Design Core 1000 in Push Pull, but you lost the vertical HDD mounting.
I was still able to mount 2 SSD's on the vertical HDD mount, and the HDD's in the optical drive bays.
So I see no problem with the H80 fitting in the Fractal Design Core 1000.
Spoiler!
axipher is offline
