H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 152 - Overclock.net - An Overclocking Community
post #1511 of 1518 (permalink) Old 09-07-2016, 03:03 AM
F@ruk's Avatar
Rep: 2 (Unique: 2)
Hello,
Are 280mm rads compatible with CM 690 III? (Corsair H110, H115)
Thank you.
post #1512 of 1518 (permalink) Old 11-26-2016, 02:11 PM
NitroOC's Avatar
Rep: 3 (Unique: 3)
I have a PC with a 4770K and two R9 290's in a 750D Corsair, can I put two H80's for the GPU's on the front panel where the fans go or do I need to split them up?
I am 56% addicted to Counterstrike. What about you?
NitroOC is offline
post #1513 of 1518 (permalink) Old 01-10-2017, 10:53 PM
Gorhell's Avatar
Rep: 0
Hi everyone does
H100i fits on Zalman GS1000 CPU case?
Gorhell is offline
post #1514 of 1518 (permalink) Old 01-11-2017, 04:23 AM
Rep: 107 (Unique: 94)
I had this 100i for five years. Should i replace the cooler? I am surprised it's still running okay. Just concerned lol..
DONATE IN HONOR OF SYRILLIAN
: : The Official Corsair H50/H70/H100 Hydro Series Club : :
NZXT H700i PC Gamer
Skate Warrior and Youtuber Gamer
post #1515 of 1518 (permalink) Old 01-11-2017, 04:37 AM
Old and Decrepit
JustinThyme's Avatar
Rep: 48 (Unique: 34)
New case that is 100% compatible with every one of these.......
Das Beast
(30 items)
I9 9940X
Asus Rampage VI Extreme
Asus Strix 2080 Ti OC
Corsair Dominator Platinum RGB CMT64GX4M8Z3600C16
Samsung 960 Pro
Samsung 850 EVO
Intel 905P
Corsair AX1600i
2x Heat Killer IV Strix 2080ti blocks with back plates
Aquaero 6 pro controller
Corsair SP120 PWM x 11
Heatkiller IV pro
Heatkiller Tube 200
EKWB 480 XE
EKWB 480 PE
EKWB 360XE
Corsair LL 120 PWM X8
D5 pumps x2 in serial bitspower head with mod kit
Heatkiller VRM block
Aquacomputer Next D5 pump mounted to Heatkiller tube 200 res
Phantek Entoo Elite Black
Operating System
WIN 10 Pro
ASUS PG349Q
Keyboard
ASUS Core
Mouse
Asus spatha
Mouse
Asus Sheath
Audio
Audio Engine A5+
Audio
SVS1000 Sub
Audio
Audio engine 192kBPS DAC
JustinThyme is offline
post #1516 of 1518 (permalink) Old 10-16-2017, 08:05 PM
Jaybro's Avatar
Rep: 0
I'd like to ask if the H110i Dual 140mm would fit a corsair 100R case?
Jaybro is offline
post #1517 of 1518 (permalink) Old 07-18-2018, 08:49 PM
Linux Lobbyist
Malign's Avatar
Rep: 1 (Unique: 1)
Just an update, The Corsair 110i 280mm does fit into the Fractal Define R4 in the front. You will have to remove all HD bays. To make it work without modification, you need to have in push/pull or push. With doing so, only 2 screws line up on the front filter. I did mine as pull with two 140mm shrouds in order for the radiator to be connected as the actual radiator is too big for where it mounts the fans. You will need to set radiator inside but mount it by screwing the outside screws while it sits inside. You will not be able to open the filter door all the way due to size but just enough to be able to remove filter for cleaning. I can provide pictures if you want.
Malign is offline
post #1518 of 1518 (permalink) Old 08-14-2018, 09:18 AM
Fettered Firewall
Ictinike's Avatar
Rep: 332 (Unique: 278)
Asking if the 100i or 115i @ 280mm will fit topside on Corsair Obsidian 750D.
Think it will be it's an older series as well board (LGA2011) and have an H90 140mm single on it now in the back and other than a pump going; it fits.
TIA!
Intel Core i7 4930K
ASUS Rampage IV Black Edition
MSI Gaming X - GTX 1080
G.SKILL Ripjaws X 4x8GB
Samsung EVO 850
Corsair GS700
Corsair Hydro H90
Operating System
Windows 10 Professional
Dell S2716DG
Keyboard
Custom Mechanical (Ortholinear Planc Keyboard)
Mouse
Razor Naga MMO
Audio
ASUS Xonar DGX
Ictinike is offline
