H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 19 - Overclock.net - An Overclocking Community
post #181 of 1518 (permalink) Old 01-05-2012, 05:30 AM
Rust Buckets for Days
axipher's Avatar
Originally Posted by Mattyd893 View Post
Originally Posted by axipher View Post
Here's my update of how I installed the RAD in the Cooler Master 690 II Advanced
RED circles = Stock Corsair H100 screws (2 per shroud)
BLUE circles = 6-32 1 1/2" machine screws with washer and nut's (2 per fan)
YELLOW circles = Regular fan screws (2 per fan)
As you can see there is a little gap between the fans and shrouds and the shrouds just sit right on the BLUE screws that are helping hold the fans on the bottom of the case.
Looks good, link added to OP. Did you compare temps with push pull? Also, how are you controlling the fans?
And using the NZXT Sentry Mesh. Although I always have them on 100% and I can't really hear them, so they may as well be plugged directly into the PSU.
Spoiler!
axipher is offline
post #182 of 1518 (permalink) Old 01-05-2012, 01:33 PM
Sethy666's Avatar
Rep: 369 (Unique: 295)
I'd really appreciate some more pics of the kinky filters, both for myself and the thread!
Ill take a couple of pics and post them when I get home from work tonight.
Im thinking about making a filter cover using the stockings. Its still a concept-in-my-head ATM and Im guessing its going to be pretty ghetto but we'll see tongue.gif
Sethy666 is offline
post #183 of 1518 (permalink) Old 01-05-2012, 01:52 PM - Thread Starter
Rep: 87 (Unique: 80)
Quite easy actually if you think, if you have fan guards on both sides of the H100 fans, the stocking can go all the way round using the corsair screws to keep it in place, guards are cheap.... one possibility anyway!
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #184 of 1518 (permalink) Old 01-05-2012, 01:57 PM
Eaglesfan251's Avatar
Rep: 10 (Unique: 8)
Just installed my H80 in the rear of my Antec 900. Can't put the side panel on unless you cut one of the side panel fan mount clips off. I'll post a pic when I get off of work.
Eaglesfan251 is offline
post #185 of 1518 (permalink) Old 01-05-2012, 01:59 PM
Sethy666's Avatar
Im thinking of a box type setup that sits over the fan and rads;
257
Sethy666 is offline
post #186 of 1518 (permalink) Old 01-05-2012, 02:23 PM
Crisco088's Avatar
Rep: 1 (Unique: 1)
Would an H80 fir in an Azza Solano 1000
Crisco088 is offline
post #187 of 1518 (permalink) Old 01-05-2012, 02:24 PM
Crisco088's Avatar
Rep: 1 (Unique: 1)
Would an H80 fit in an Azza Solano 1000
post #188 of 1518 (permalink) Old 01-05-2012, 02:36 PM
videoman5's Avatar
Rep: 190 (Unique: 178)
I don't have one(an H100, that is), and I can't find a picture of an H100, but here is a link with a 240mm watercooling loop in an Xigmatek Utgard.
3dmark06: 23655
CPU-Z
1. Wear gaudy colors or avoid display
2. Lay a million eggs or give birth to one
3. The fittest shall survive yet the unfit may live
4. Be like your ancestors or be different
5. We must repeat!
videoman5 is offline
post #189 of 1518 (permalink) Old 01-05-2012, 04:42 PM
royalflush5's Avatar
Rep: 40 (Unique: 40)
Heres my h80 in my CM Elite 430.... 501
Sorry about the flash btw, point and shoot fail
As you can tell, its CRAMPED, I wasn't even able to use all 4 screws (only 2) because the CPU block was just in the way (the second fan ends up resting on the pump, but works just fine really), it also covered my CPU power connector, make sure you plug your cable in before you install the rad. . . other than that, its a tight, tight fit, but it works if you have the case, just make sure everything will line up before you install it thumb.gif
Steam: Heavy Weapons Guy | Origin: Royalflush5 |
I don't always fold proteins, but when I do, I prefer team OCNClubs! (Click to show)
sneaky.gif: : The Official Corsair Hydro Series Club : : sneaky.gif
royalflush5 is offline
post #190 of 1518 (permalink) Old 01-05-2012, 11:16 PM
Rep: 10 (Unique: 8)
700
700
700
400
