H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 20 - Overclock.net - An Overclocking Community
post #191 of 1518 (permalink) Old 01-06-2012, 12:32 AM - Thread Starter
Rep: 87 (Unique: 80)
Originally Posted by Crisco088 View Post
Would an H80 fit in an Azza Solano 1000
It should fit on the standard 120mm rear mount, beut might be too thick
See this pic of the H50 in that case:
https://www.overclock.net/t/876350/official-nzxt-phantom-club/4390#post_14543188
See how close the fan is too the pump!
Now consider this:
H50 Rad size: 150 x 120 x 25 mm
H80 Rad Size: 120mm x 152mm x 38mm
That extra 13mm thickness could be an issue!
Do not despair, it may also be possible to mount one fan externally (fan guard reccomended) like this:
https://www.overclock.net/t/294838/the-cooler-master-690-club/15970#post_15187365
No guarantees though!
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #192 of 1518 (permalink) Old 01-06-2012, 12:43 AM - Thread Starter
Originally Posted by Sethy666 View Post
Im thinking of a box type setup that sits over the fan and rads;
257
What you could actually do, that wouold be easy and look pretty good.. is pop to your local auto store and buy some car radiator grille mesh, can easily bend and shape that into a box and it's pretty cheap too.
DOn't know about in Aus but this is only 20GBP for tons of the stuff!
http://www.bestautobits.com/products/Car-Exterior-Black-Honeycomb-Grill-Mesh-Honeycomb-Size-12-x-6mm.html
post #193 of 1518 (permalink) Old 01-06-2012, 07:35 AM
acey's Avatar
Rep: 0
i just leveled it on top of the 2 180mm fans
in idle mode 2x120mm fans push no power only pull fans and the 180mm of raven running at 800rpm
see my rig:D
acey is offline
post #194 of 1518 (permalink) Old 01-06-2012, 03:06 PM
Sethy666's Avatar
Rep: 369 (Unique: 295)
Originally Posted by Mattyd893 View Post
Originally Posted by axipher View Post
Here's my update of how I installed the RAD in the Cooler Master 690 II Advanced
RED circles = Stock Corsair H100 screws (2 per shroud)
BLUE circles = 6-32 1 1/2" machine screws with washer and nut's (2 per fan)
YELLOW circles = Regular fan screws (2 per fan)
As you can see there is a little gap between the fans and shrouds and the shrouds just sit right on the BLUE screws that are helping hold the fans on the bottom of the case.
Looks good, link added to OP. Did you compare temps with push pull? Also, how are you controlling the fans?
Just as an aside for all H-series uses...
I took down my H100 Push/pull (intake) for a clean the other day and the rad was caked in dust. Ive only had it for 6 months.
Conventional fan filters can be hard to obtain or fit, so I grabbed a pair of my wifes old black stocking socks and placed those over the intake fans... works a treat. And the temps went down with out all that dust on the rad.
Even now, after a few days, there is a fine covering of dust on the 'filters'.
Pic of my setup prior to popping the stockings over the fans.
I'd really recommend this tip for all H series owners using an intake configuration thumb.gif
If anyone is interested, I can take a pic of the 'filters' in action when I get home tonight.
I'd really appreciate some more pics of the kinky filters, both for myself and the thread!
450
Sethy666 is offline
post #195 of 1518 (permalink) Old 01-06-2012, 07:22 PM - Thread Starter
450
Sorry mate, just to confirm, is thta a shroud and push/pull config with your misseses stockings?
post #196 of 1518 (permalink) Old 01-07-2012, 04:07 PM
XBarbarian's Avatar
Rep: 3 (Unique: 3)
Nice ingenuity Sethy666!
Humility isn't thinking less of yourself, it is thinking of yourself less often
XBarbarian is offline
post #197 of 1518 (permalink) Old 01-07-2012, 05:39 PM
Sethy666's Avatar
450
Yes, it is.
Sethy666 is offline
post #198 of 1518 (permalink) Old 01-09-2012, 12:01 AM - Thread Starter
Yes, it is.
Only problem could be with noise maybe, would depend on the mesh.
post #199 of 1518 (permalink) Old 01-09-2012, 12:19 AM - Thread Starter
see my rig:D
Thanks for the info, had a look at your rig, couldn't really see a pic that showed the setup that clearly, asny chance you can take one?
post #200 of 1518 (permalink) Old 01-13-2012, 01:38 AM
Ever Forward.
PR-Imagery's Avatar
Rep: 231 (Unique: 166)
I was certain the H80 would not fit in the Thermaltake Armor+ (VH6001) but I can confirm it does indeed fit; just with one fan pushing or pulling. It's tight but the rad fits fairly comfortably.
450
without modifications, the case can only do one fan on any of the H series coolers, to do a push/pull, the psu support beam will need to be shaved to make room for the rad
450
450
Update: Mounting fan externally on the back of the case just requires placing a couple washers(depending on the thickness, I needed three of the washers that came with the H80 which is a little thicker than your standard key) between the fan and the case to keep the fan blades from touching when used in the a pull configuration.
450
450
"The greatest good you can do for another is not just to share your riches but to reveal to him his own."
PR-Imagery is offline
