H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 21 - Overclock.net - An Overclocking Community
post #201 of 1518 (permalink) Old 01-13-2012, 01:47 AM - Thread Starter
Rep: 87 (Unique: 80)
Originally Posted by PR-Imagery View Post
I was certain the H80 would not fit in the Thermaltake Armor+ (VH6001) but I can confirm it does indeed fit; just with one fan pushing or pulling. It's tight but the rad fits fairly comfortably.
450
without modifications, the case can only do one fan on any of the H series coolers, to do a push/pull, the psu support beam will need to be shaved to make room for the rad
That is snug, thanks for the input...
Can you fit the second fan on the outside of the case for Push/Pull? Similar to this:
https://www.overclock.net/t/294838/the-cooler-master-690-club/15970#post_15187365
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #202 of 1518 (permalink) Old 01-13-2012, 01:56 AM
Ever Forward.
PR-Imagery's Avatar
Rep: 231 (Unique: 166)
Didn't try it, but I do believe my friend ran his H50 in a push/pull with the fan on the back of the case, would say its possible to do the same; will check when I get a chance. The mesh on the outside is raised tho, think it would actually push into the blades.
"The greatest good you can do for another is not just to share your riches but to reveal to him his own."
PR-Imagery is offline
post #203 of 1518 (permalink) Old 01-13-2012, 02:05 AM - Thread Starter
That link was to my case (CM690 Std) the mesh is also slightly raised but not enough to impact the fans. Doesn't effect cooling either but obviously a fan guard is reccomended, plus you need a hole to pass the fan cable through.
post #204 of 1518 (permalink) Old 01-13-2012, 02:38 AM
Ever Forward.
PR-Imagery's Avatar
I know he did say he had a fan on the back of it for a while, didn't really make a difference on the H50 with the Armor+.
Never saw it for myself tho, so I will check it for sure, see how effective it is with the H80.
post #205 of 1518 (permalink) Old 01-14-2012, 11:20 PM
nvidiaftw12's Avatar
Rep: 238 (Unique: 191)
I'm pretty sure you can fit a h-100 in a In Win Dragon Rider.
nvidiaftw12 is offline
post #206 of 1518 (permalink) Old 01-18-2012, 04:41 AM
ThePariah's Avatar
Rep: 0
Would the H100 fit in the top of a Fractal Design Arc Midi case in a push/pull configuration, with the Asus P8Z68-V Pro/Gen3 motherboard installed?
I'm wondering about the clearance between the radiator/fans and the mobo heatsinks/RAM(Corsair Vengeance Low Profile).
I really need a confirmation about this before I buy the components.
ThePariah is offline
post #207 of 1518 (permalink) Old 01-18-2012, 05:15 AM
Blizlake's Avatar
Rep: 124 (Unique: 99)
Should fit fine as 60mm rad with 25mm fans does. 60+25=85, 27+25+25=77
The arc midi fans are offset so your ram and mobo shouldnt be any issue.
Blizlake is offline
post #208 of 1518 (permalink) Old 01-18-2012, 10:26 PM
khb008's Avatar
Rep: 0
Hey Guys,
I sincerely apologize if this has been posted before but I did do a thread search and couldn't find it.
Im pretty sure the H80 will be compatible with NZXT M59 in a push - pull using the rear 120 fan slot. But i'm wondering if the H100 will be supported if I do a Push-Pull using the Top two 120 mm fan slots.
The reason I ask is that the top slots are also for 140mm fans thus I just wanted to make sure that there isn't any unnecessary spacing between the two 120 slots. Thank you so much for your help!
khb008 is offline
post #209 of 1518 (permalink) Old 01-19-2012, 12:55 AM - Thread Starter
Originally Posted by khb008 View Post
Hey Guys,
There is quite a few scenarios like this. As a general rule, if there is space for 2x120/140mm fans then it will fit, however the screw holes may not always line up with the case ones due to spacing etc.
There is normally a workaround for this, either by adding a couple of holes or using anothe rmethod of attaching. The most important thing is that the Rad+flans has the room to start with.
post #210 of 1518 (permalink) Old 01-19-2012, 05:10 AM
phillyd's Avatar
Rep: 188 (Unique: 146)
i just bought the phantom 410 and corsair H-100.
i have seen them installed together on youtube, i will post when i get mine done (tonight).
i may pick up some nice 120mm fans to do push/pull with it.
Ryzen & Vega Enthoo Evolv ATX TG Case Mod Build Log
Audio (Click to show)
Sources: The Spectre | Lenovus Maximus | Huawei Honor 8
DAC's: HiFimeDIY Sabre SPDIF | iBasso D-Zero
Amplification:ASL MG-Head OTL Mark III
Headphones: Sennheiser HD650 | Shure SE215K | Logitech UE6000
Speakers
Home Theater/Lenovus Maximus: Pioneer Elite SC-85 > Music Angel SDXE M9 > Klipsch KG5.2 w/Crites tweeters/crossovers
The Spectre: Adam Ax7
Build Logs (Click to show)Overclocking Accolades (Click to show)
phillyd is offline
