H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 22 - Overclock.net - An Overclocking Community
post #211 of 1518 (permalink) Old 01-19-2012, 08:39 AM
Rep: 238 (Unique: 214)
chinesethunda is offline
post #212 of 1518 (permalink) Old 01-19-2012, 09:32 PM
phillyd's Avatar
Rep: 188 (Unique: 146)
the NZXT Phantom 410 is compatible with the h100.
but,
you must mount the radiator on one side of the plate and the fans on the other.
i do not think you could manage push-pull.
Ryzen & Vega Enthoo Evolv ATX TG Case Mod Build Log
Audio (Click to show)
Sources: The Spectre | Lenovus Maximus | Huawei Honor 8
DAC's: HiFimeDIY Sabre SPDIF | iBasso D-Zero
Amplification:ASL MG-Head OTL Mark III
Headphones: Sennheiser HD650 | Shure SE215K | Logitech UE6000
Speakers
Home Theater/Lenovus Maximus: Pioneer Elite SC-85 > Music Angel SDXE M9 > Klipsch KG5.2 w/Crites tweeters/crossovers
The Spectre: Adam Ax7
Build Logs (Click to show)Overclocking Accolades (Click to show)
phillyd is offline
post #213 of 1518 (permalink) Old 01-20-2012, 01:20 AM - Thread Starter
Rep: 87 (Unique: 80)
but,
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #214 of 1518 (permalink) Old 01-20-2012, 05:11 AM
Braaapp's Avatar
Rep: 34 (Unique: 29)
Originally Posted by khb008 View Post
Hey Guys,
I sincerely apologize if this has been posted before but I did do a thread search and couldn't find it.
Im pretty sure the H80 will be compatible with NZXT M59 in a push - pull using the rear 120 fan slot. But i'm wondering if the H100 will be supported if I do a Push-Pull using the Top two 120 mm fan slots.
The reason I ask is that the top slots are also for 140mm fans thus I just wanted to make sure that there isn't any unnecessary spacing between the two 120 slots. Thank you so much for your help!
I honestly don't see the H100 fitting inside the M59 in push-pull, and you may have trouble fitting it in just push OR pull depending on motherboard. You could push the radiator as close to the door side as possible and *maybe* clear motherboard interference but it's not pretty and some of your power connectors and ram slots may be blocked if they are near the top of the board:
450
I had to cut a hole for the pump and mount the radiator externally on my gamma because the VRM heatsinks did not allow space for the fans when mounted internally (centered in the grill like it is supposed to)...The gamma and M59 are essentially the same case. Like Mattyd said the spacing is incorrect for the H100 and you would have to trim the grill in 2 spots for the screws to line up with the radiator if you have room to center it.
Braaapp is offline
post #215 of 1518 (permalink) Old 01-20-2012, 05:53 AM
phillyd's Avatar
but,
ill get some on here of my setup tonight or tomorrow.
Speakers
phillyd is offline
post #216 of 1518 (permalink) Old 01-20-2012, 10:39 PM
phillyd's Avatar
now...
400
400
400
400
400
Speakers
phillyd is offline
post #217 of 1518 (permalink) Old 01-22-2012, 07:58 AM
Terrorsathan's Avatar
Rep: 1 (Unique: 1)
can you guys believe a Corsair H100 fits in a Corsair 400R case?! NO way!
Wish I could fit push/pull, tho.
450
450
450
http://smg.photobucket.com/albums/v338/morguewhorepa/?action=view&current=2012-01-16_11-04-49_241.mp4
Terrorsathan is offline
post #218 of 1518 (permalink) Old 01-22-2012, 08:12 AM
toyz72's Avatar
Rep: 110 (Unique: 93)
the h100 will also work in the fractal design arc mini with no modding. but if you want push pull setup,you'll need a 120mmx12mm rear fan.
toyz72 is offline
post #219 of 1518 (permalink) Old 01-23-2012, 01:29 PM - Thread Starter
Any pics?
post #220 of 1518 (permalink) Old 01-23-2012, 02:01 PM
phillyd's Avatar
One of the fans on my H100 died within 2 days of its receipt. I called corsair, the rep emailed me a coupon code for the h100 fan kit (2x120mm fans) free with free ups ground shipping so i now have an extra fan biggrin.gif
Speakers
phillyd is offline
