H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 25 - Overclock.net - An Overclocking Community
post #241 of 1518 (permalink) Old 01-29-2012, 09:04 AM
joeyck's Avatar
Rep: 6 (Unique: 5)
http://www.youtube.com/watch?v=JzyKRifUPrg
Fits in the antec 1200 push/pull but u can only get two screws in but it is rock solid.
so if it fits inside the 1200 it will fit in the DF 85 as they have the same size minus like .5 inch in some areas, and the same fan size as one other on the back (120mm)
and read the comments fully as people have posted how this will affect / not affect the PCI. its a great video!
joeyck is offline
post #242 of 1518 (permalink) Old 01-30-2012, 04:40 PM
toyz72's Avatar
Rep: 110 (Unique: 93)
Originally Posted by Mattyd893 View Post
Any pics?
sorry took so long. this is my fractal design arc mini. as you can see the h100 is push/pull but, for the rear fan you'll need a 120x12mm fan. other than that , there is no mod's needed.
400
400
400
toyz72 is offline
post #243 of 1518 (permalink) Old 01-30-2012, 11:01 PM
Taiwanese's Avatar
Rep: 3 (Unique: 3)
400
400
400
Do you think a H80 would fit on the rear of that case? :O
Taiwanese is offline
post #244 of 1518 (permalink) Old 01-31-2012, 12:50 AM - Thread Starter
Rep: 87 (Unique: 80)
Yes you can, here's a link: http://forums.overclockers.com.au/showpost.php?p=13440020&postcount=12 although if you're buying new and have the extra bit of cash, i'd reccomend the H100
@everyone else, OP updated with additional info, thanks for the inputs.
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #245 of 1518 (permalink) Old 01-31-2012, 08:39 AM
joeyck's Avatar
Rep: 6 (Unique: 5)
600T push/pull.
Very slight mod (I dont even think its considered a mod lol)
joeyck is offline
post #246 of 1518 (permalink) Old 02-02-2012, 01:09 AM - Thread Starter
Thanks, nice vid. OP updated!
post #247 of 1518 (permalink) Old 02-02-2012, 06:05 PM
wheresstimpy's Avatar
Rep: 2 (Unique: 2)
i can confirm it will fit in a Rosewill Thor push pull but you better be handy with a dremel and a drill if you want to use tall ram and full sized fans in push pull. The biggest problem with this case is that the motherboard sits so high in the case. It really limits what you can do on the top area. They really didn't design it to have anything other than the one 230mm fan (stock) or the optional two 140mm (or 120mm) fans (well i guess i shouldn't say they, since we all know Rosewill didn't design this case, lol). With my parts combination i was forced to push the h100 as far over (away from the motherboard) as possible so i would have clearance. The h100 will bolt up to stock holes but it is too close to the motherboard in push pull. Once it is moved over you will need to cut away the material blocking the fans ( i cut the mesh too while i was at it). Then you need to drill some mounting holes, i only needed to drill 4 and then use washers to hold the other side through the mesh(closer to the motherboard). This is pretty solid and looks nice if you take your time. Then all that's left to do it remove the center plastic clips from the case top on the side you just covered up and trim any material away from the top where the bolts are so it will fit flush (all hidden once its together).
448448448
wheresstimpy is offline
post #248 of 1518 (permalink) Old 02-02-2012, 07:28 PM
phillyd's Avatar
Rep: 188 (Unique: 146)
Originally Posted by wheresstimpy View Post
i can confirm it will fit in a Rosewill Thor push pull but you better be handy with a dremel and a drill...
h100cut.JPG 62k .JPG file
wizbang.JPG 94k .JPG file
you probably could have done this with low profile fans on the original screw mounts if you had either one set of fans or the rad and a set of fans on the top of the case.
Ryzen & Vega Enthoo Evolv ATX TG Case Mod Build Log
Audio (Click to show)
Sources: The Spectre | Lenovus Maximus | Huawei Honor 8
DAC's: HiFimeDIY Sabre SPDIF | iBasso D-Zero
Amplification:ASL MG-Head OTL Mark III
Headphones: Sennheiser HD650 | Shure SE215K | Logitech UE6000
Speakers
Home Theater/Lenovus Maximus: Pioneer Elite SC-85 > Music Angel SDXE M9 > Klipsch KG5.2 w/Crites tweeters/crossovers
The Spectre: Adam Ax7
Build Logs (Click to show)Overclocking Accolades (Click to show)
phillyd is offline
post #249 of 1518 (permalink) Old 02-03-2012, 12:47 AM
toyz72's Avatar
still have not updated the h100 to the fractal design arc mini. there more than one mini. the picture i linked is an arc mini. mine is mounted in the top. comon matt biggrin.gif
toyz72 is offline
post #250 of 1518 (permalink) Old 02-03-2012, 01:22 AM - Thread Starter
Other posts added as well.
