H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 27 - Overclock.net - An Overclocking Community
post #261 of 1518 (permalink) Old 02-06-2012, 02:23 PM
xDriftyy's Avatar
Rep: 76 (Unique: 62)
Originally Posted by phillyd View Post
yeah but i guess thats the benefit with a case like a full phantom tongue.gif
true. if i could do it over again, i would get a corsair full tower, but i still like this one now that the cutting is done
the corsair 600's are overrated. the obsidian are great i hear
loving my 650D! It's like a baby full tower, but a grown up mid tower smile.gif
theyre sleek, but i would have chosen a fractal if i wanted a simplistic look.
I grabbed this case because I love the look of it. And the window is a great size. The only thing I don't like about it are the clips on the side panel.
xDriftyy is offline
post #262 of 1518 (permalink) Old 02-06-2012, 05:45 PM
wheresstimpy's Avatar
Rep: 2 (Unique: 2)
ya i meant the obsidian, my buddy has one and says it is awesome, and he is one of those over the top crazy builders who is pretty picky and opinionated about his rigs, lol.
wheresstimpy is offline
post #263 of 1518 (permalink) Old 02-06-2012, 06:14 PM
rctrucker's Avatar
Rep: 77 (Unique: 56)
Anyone running the H100 on a 3930k or 3960x? I'm curious at your temps/overclock at idle and load. I still feel like I should be running cooler than I am, but not sure.
EDIT: If my temps JUMP from idle to loaded temps, is this a sign of a bad seating of the waterblock?
Idle temps are 35-37c, under load they are instantly 57-58c.
rctrucker is offline
post #264 of 1518 (permalink) Old 02-06-2012, 07:03 PM
phillyd's Avatar
Rep: 188 (Unique: 146)
mine jumps from 28-28 almost instantly, but settles at 43.
i dnt think its abnormal.
Ryzen & Vega Enthoo Evolv ATX TG Case Mod Build Log
Audio (Click to show)
Sources: The Spectre | Lenovus Maximus | Huawei Honor 8
DAC's: HiFimeDIY Sabre SPDIF | iBasso D-Zero
Amplification:ASL MG-Head OTL Mark III
Headphones: Sennheiser HD650 | Shure SE215K | Logitech UE6000
Speakers
Home Theater/Lenovus Maximus: Pioneer Elite SC-85 > Music Angel SDXE M9 > Klipsch KG5.2 w/Crites tweeters/crossovers
The Spectre: Adam Ax7
Build Logs (Click to show)Overclocking Accolades (Click to show)
phillyd is offline
post #265 of 1518 (permalink) Old 02-06-2012, 10:24 PM
rctrucker's Avatar
But mine are still way higher than yours frown.gif pulling in cool air to the case, push pull directly on rad, going to buy some curved needle nose to get a better seal.
post #266 of 1518 (permalink) Old 02-07-2012, 01:13 AM - Thread Starter
Rep: 87 (Unique: 80)
Watch out for contact of the block with any capacitors around the CPU that can give a bad contact, although the block is reasonably small so it shouldn't be an issue.
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #267 of 1518 (permalink) Old 02-07-2012, 08:43 AM
rctrucker's Avatar
Well, with a 2011 board, the asrock extreme9, there is not chance I'll touch those capacitors. If I did, I would truly be gifted.
post #268 of 1518 (permalink) Old 02-07-2012, 01:04 PM
Satx's Avatar
Rep: 3 (Unique: 3)
Hello good people of oc.net
i just installed Corsair H80 on my Thermaltake Element G Case.. it's compatible . There is no problem at all.
Other Hardwares: Asus P9X79 Pro Motherboard , Corsair Vengeance 8 GB DDR3 Quad Channel..
Satx is offline
post #269 of 1518 (permalink) Old 02-07-2012, 02:15 PM
phillyd's Avatar
Speakers
phillyd is offline
post #270 of 1518 (permalink) Old 02-08-2012, 12:11 AM - Thread Starter
No probs, just it's a commone problem that some people don't realise, more common with massive air coolers though.
What is the individual core temps you get? Also, if you plan to reseat the block then.... when applying, sit it loosely on the fittings, tighten the screws till you get a tiny bit of tension using using opposite corners, then work your way around them again (opposite corners) going that little bit further until they are finger tight. then give them an extra 1/4 - 1/2 a turn with a screwdriver.
You'll get a more even spread on the TIM and a better seated block.
Sorry if you think I'm teaching you to suck eggs but I don't know what your knowledge is obviously.
Thanks, kind of getting a little tired of saying it myself, it's like I'm a H80/100 sex pest or something! biggrin.gif
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
