H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 35 - Overclock.net - An Overclocking Community
post #341 of 1518 (permalink) Old 02-27-2012, 01:15 PM
dejahboi's Avatar
Rep: 62 (Unique: 53)
IMAG0351
dejahboi is offline
post #342 of 1518 (permalink) Old 02-27-2012, 02:43 PM
Once more into the Fold
franz's Avatar
Rep: 300 (Unique: 243)
Antec 1200. Corsair H80
Mounted in rear bottom fan opening. Still running rear top fan as exhaust.
Would fit rear top by removing top 200mm fan and modding case.
Running 2x Scythe AP-15s in push pull as an exhaust.
Still experimenting with fan orientation.
Well here are the pics!!
Unfortunately I cant use my top PCIE slot due to the minimal clearance. Not an issue now, but when I get more GPUs I will have to do some modding. wink.gif
I am going to try another reseat of the cooler. I think I can do a little better with the temps and get less of a temperature spread between each core.
1903256
1903264
franz is offline
post #343 of 1518 (permalink) Old 02-28-2012, 09:59 AM
_REAPER_'s Avatar
Rep: 59 (Unique: 50)
1903256
1903264
You can turn the H80 90 or 180 degrees and it will still work just fine.
_REAPER_ is offline
post #344 of 1518 (permalink) Old 02-28-2012, 02:25 PM
franz's Avatar
Thanks for the suggestion, but it wouldnt matter either way. If I rotated it 90 degrees I couldnt close the side of the case and it would probably hit some mosfet heatsinks on the other side. If I go 180 the end cap is still in the way..... Really the only option is to pull the top rear fan and rig up a mount to move the rad up a few cm.
franz is offline
post #345 of 1518 (permalink) Old 03-03-2012, 12:35 AM
MPowar's Avatar
Rep: 1 (Unique: 1)
H80 P/P DOES FIT in the REAR ofAntec 200 case, however, its a tight fit.
Mobo: GA-P55-UD3
Ram: Gskill-RipjawsZ ram w/ Turbulence II fan
GFX: Radeon HIS HD4870
450
450450450
MPowar is offline
post #346 of 1518 (permalink) Old 03-06-2012, 09:01 PM
mu5tang71's Avatar
Rep: 3 (Unique: 3)
Update on my Thermaltake Overseer rx-i. Just installed a H100 push pull config with 2 200mm on top of that. Total of 6 fans cooling this baby.thumb.gif
After a torture test with prime 95 maxed out at 53°C 1/2hr test at full load. i7 860 @2.80GHz 3.15GHz
mu5tang71 is offline
post #347 of 1518 (permalink) Old 03-06-2012, 11:28 PM - Thread Starter
Rep: 87 (Unique: 80)
Is that low profile RAM in there? If yes, would it still fit with something like Corsair Dominator with the larger heatsink????
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #348 of 1518 (permalink) Old 03-07-2012, 05:21 PM
mu5tang71's Avatar
Rep: 3 (Unique: 3)
Yes it is a low profile ram. I have a push pull config so a ram stick like the dominator might not fit. It may fit with just a push config and use the top 200mm fans to pull. But low profile ramm is what would most likely be needed in my opinion....... Posted a pic of the clearece to the fans from the ram sticks...... There is about 1/4" of clearance between the sticks and the fan
post #349 of 1518 (permalink) Old 03-07-2012, 11:58 PM
_REAPER_'s Avatar
It will fit with push/pull with dominator ram it will just be tight
_REAPER_ is offline
post #350 of 1518 (permalink) Old 03-08-2012, 12:10 AM - Thread Starter
Thanks for the updates.. put a caveat on the OP that it MAY be HW dependant, don't want people whinging when they don't do the correct research!
