H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 39 - Overclock.net - An Overclocking Community
post #381 of 1518 (permalink) Old 04-13-2012, 11:25 AM
Rep: 4 (Unique: 4)
In the Silverstone Raven 02 picture:
http://i52.tinypic.com/2z6dv7p.jpg
It seems like he uses some sort of brackets in order to get the H100 mounted on top of the 180mm fans at the bottom, where do you get these brackets?
RamGuy is offline
post #382 of 1518 (permalink) Old 04-16-2012, 03:55 AM - Thread Starter
Rep: 87 (Unique: 80)
Not sure, but I'm sure a little time with google will find them. Just search for 240mm radiator mounts/brackets
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #383 of 1518 (permalink) Old 04-20-2012, 02:51 AM
Kujakape's Avatar
Rep: 1 (Unique: 1)
400
My Fractal Desing Define R3 with Corsair H80.
Kujakape is offline
post #384 of 1518 (permalink) Old 04-20-2012, 03:08 AM - Thread Starter
Thanks, Added to OP!
post #385 of 1518 (permalink) Old 04-22-2012, 04:55 PM
rickydlam's Avatar
Rep: 1 (Unique: 1)
The links for the Push/Pull setup for a Fractal Design Arc Midi are incorrect. You do not need to buy a 120mm x 12mm rear fan to clear the radiator. A 140mm x 25mm works just fine.
My current setup is a h100 with 2x Noctua NF-F12 pushing and 2x Corsair h100 Fans pulling with a stock 140mm x 25mm fractal design case intake fan from the rear.
Proof.
448
448
rickydlam is offline
post #386 of 1518 (permalink) Old 04-23-2012, 06:20 AM - Thread Starter
Thanks for the info, the OP has been updated with your post linked first.
post #387 of 1518 (permalink) Old 04-27-2012, 03:33 AM
xXUNLUCKYXx's Avatar
Rep: 3 (Unique: 3)
Will the Corsair H100 Fit in my Coolermaster Cosmos 1000 case?
xXUNLUCKYXx is offline
post #388 of 1518 (permalink) Old 04-27-2012, 04:26 AM - Thread Starter
Yes:
post #389 of 1518 (permalink) Old 04-27-2012, 05:15 AM
Rep: 3 (Unique: 3)
Ive seen this video but i wasnt sure if this was modded or not suppose i can buy it and see.
post #390 of 1518 (permalink) Old 04-27-2012, 07:56 AM - Thread Starter
As a general rule, if there is 2 120mm fan mounts next to each other, and there is enough room for the rad plus fan without hitting any heatsinks on your mobo then it should fit.
