H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 41 - Overclock.net - An Overclocking Community
post #401 of 1518 (permalink) Old 05-12-2012, 09:01 AM
Incatius's Avatar
Rep: 2 (Unique: 2)
It is nexus 1000rpm fan, I think it is this one here
http://www.newegg.com/Product/Product.aspx?Item=N82E16835610006
I bought it couple of years back and not at home to confirm it.
Incatius is offline
post #402 of 1518 (permalink) Old 05-12-2012, 09:42 AM
1689 Federalist
lightsout's Avatar
Rep: 250 (Unique: 214)
Cool thread. Can't believe I didn't see it as I was just shopping for a new case plus H100. Anyways the H100 fits in the top of the Corsair 550D. I have it in push. I saw someone with push pull but that all depends on your mobo heatsinks. Don't think it would work on mine.
Not the greatest pic but you can see the two fans just popping out below the top of the case.
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
Sapphire Reference RX 5700
GSkill 16gb 3200c14 Flare
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
LG 32GK650F-B 1440p 144hz
Mouse
Sensei Raw
Audio
Sony Core Bookshelves
lightsout is offline
post #403 of 1518 (permalink) Old 05-13-2012, 07:37 AM
LogiTekkers's Avatar
Rep: 11 (Unique: 7)
I am doing a mATX build for a friend and am just wondering if anybody knows if the Define Mini will fit a H80 to the rear fan mount? I'm pretty sure it would, but if anybody could give any info that would be great, and +rep biggrin.gif
LogiTekkers is offline
post #404 of 1518 (permalink) Old 05-13-2012, 09:03 AM
Ever Forward.
PR-Imagery's Avatar
Rep: 231 (Unique: 166)
Well it doesn't quite make it into the Thermaltake V4
450
If I remember correctly, when I tried it, there wasn't enough height to properly line up the mounts with the case and the rad/fan, plus it will extend quite a bit over the motherboard, even it it did fit, not sure if it would clear any VRM heatsinks/cpu socket etc.
450
But it does look like there's a little bit more space between the top of the fan and roof of the case, so maybe it will make it in there.
"The greatest good you can do for another is not just to share your riches but to reveal to him his own."
PR-Imagery is offline
post #405 of 1518 (permalink) Old 05-13-2012, 09:32 AM
Rep: 11 (Unique: 7)
^^^ Thank you for your input, that is some good food for thought. I would'nt want to order it and just hope it squeezes in with the motherboard installed etc, am I correct in thinking the H60/70 are narrower than the H80? Thank you again +rep
Which Corsair/Antec liquid coolers can definitely fit in the Define mini that someone here has installed? As it is not imperative that I use the H80, I was just thinking the latest model, the better rolleyes.gif
post #406 of 1518 (permalink) Old 05-13-2012, 10:00 AM
Blizlake's Avatar
Rep: 124 (Unique: 99)
Well, someone did it in [H] (pic).
The thread itself, click.
Blizlake is offline
post #407 of 1518 (permalink) Old 05-13-2012, 10:40 AM
skwannabe's Avatar
Rep: 6 (Unique: 4)
Anyone with a P280 running push n pull H100?
skwannabe is offline
post #408 of 1518 (permalink) Old 05-13-2012, 06:22 PM
Ever Forward.
PR-Imagery's Avatar
The H80(rad is 38mm thick) in p/p with 25mm fans is just short of 90mm thick vs 75mm with the H70(rad is 25mm thick) in p/p.
Rational thinking says It should clear the motherboard just fine tho.
post #409 of 1518 (permalink) Old 05-13-2012, 11:14 PM
moonshine6456's Avatar
Rep: 2 (Unique: 2)
hi, looking to get a h100 for my rig below. thumb.gif Planning to switch my haf 912 to something else (don't like the looks of the haf) , what would you recommend? Would like a very good airflow case biggrin.gif
moonshine6456 is offline
post #410 of 1518 (permalink) Old 05-21-2012, 02:55 AM
Anthartic Rain's Avatar
Rep: 0
OMG I just buy the H100 and a Cosmos S1000, I'm waiting for my 3930 to build up the thing, wish me luck trying to set up a push n pull on the top. I'll post here the results.
Anthartic Rain is offline
