H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 43 - Overclock.net - An Overclocking Community
post #421 of 1518 (permalink) Old 05-25-2012, 08:51 AM
Rust Buckets for Days
axipher's Avatar
The H-series RADS have a low fin-density so low-RPM fans should be fine.  I'm just not sure how they would compare in relation to the Corsair fans, or something like the AP-15 Gentle Typhoons like I'm running.
Spoiler!
axipher is offline
post #422 of 1518 (permalink) Old 05-25-2012, 08:54 AM
Ever Forward.
PR-Imagery's Avatar
Rep: 231 (Unique: 166)
H80/H100 stock fan specs
Fan Speed: (+/- 10%): up to 1300 RPM (Low Noise), 2000 RPM (Balanced), and 2500 RPM (High Performance)
Fan Airflow: 46 - 92 CFM
Fan dBA: 22 - 39
Fan Static Pressure: 1.6 - 7.7mm/H20
"The greatest good you can do for another is not just to share your riches but to reveal to him his own."
PR-Imagery is offline
post #423 of 1518 (permalink) Old 05-25-2012, 10:01 AM
Fan dBA: 22 - 39
Thnx..
Anyone know if the orientation of the head unit matters? I know the rad can be mounted any wich way (so I'm told), but was wondering about the actual mounting & it's orientation.
formula m is offline
post #424 of 1518 (permalink) Old 05-25-2012, 10:08 AM
axipher's Avatar
Fan dBA: 22 - 39
Thnx..
Nope, any way that will fit.  AMD's can only go two ways, but on Intel you can go all 4 ways.
Right now I have my tubes coming off the bottom because it puts the least amount of twist and stress on the tubes.
Spoiler!
axipher is offline
post #425 of 1518 (permalink) Old 05-25-2012, 10:35 AM
post #426 of 1518 (permalink) Old 05-25-2012, 09:27 PM
diaz's Avatar
Rep: 1 (Unique: 1)
TJ08-E
Fan fits even if it overlaps the pump.. The pump is just the right height so that the fan clears it by about 1-2mm. Sorry for crappy pic, the lighting turned out funny.
May 2012 072.JPG 1433k .JPG file
diaz is offline
post #427 of 1518 (permalink) Old 06-01-2012, 10:07 AM
m00nshake's Avatar
Rep: 0
Good afternoon everyone:
I just joined the site as I'm building a new monster and I've got the Coolermaster HAF X case and a Corsair H100 liquid cooler.
Watching the Youtube video, the guy uses some special screws that he picked up at the hardware store to mount the liquid cooler to the top of the case. I'm not sure why this is necessary because the Corsair H100 comes with mounting screws with washers and it does work with the HAF X case. I'm able to screw it down and it does hold it in place. Is there a reason why he is using special screws?
Thanks in advance for any insight. ~m00n
m00nshake is offline
post #428 of 1518 (permalink) Old 06-01-2012, 10:09 AM
Linux Lobbyist
Degree's Avatar
Rep: 35 (Unique: 27)
What about the NZXT Switch 810?
Degree is offline
post #429 of 1518 (permalink) Old 06-01-2012, 12:12 PM
Bacchus84's Avatar
Rep: 0
Looking to build a new system but I'm wondering if the H100 will fit in the configuration I would like to have
I'm planning on getting the new HAF XM case with the Asus Z77 Sabertooth motherboard + Corsair Vengeance RAM sticks with the spikey heatsink and installing the rad + fans inside the case (push config) so the top 200mm case fan can remain where it is.
Something like this:
327
Has anyone tried this yet?
Since the MB is raised a bit higher due to the thermal armor plastic cover I'm wondering how much clearance there will be inside and if I'll need low profile RAM.
The case is not on the list of supported cases here and I've been unable to find a definitive answer about this specific combo of hardware and rad placement.
Thanks in advance,
Bacchus84
Bacchus84 is offline
post #430 of 1518 (permalink) Old 06-08-2012, 12:58 AM
3930K's Avatar
Rep: 157 (Unique: 115)
Does the H100 fit the 800D p/p? (120x25 fans)
Upgrades which are in consideration: U2713HM | Samsung 830 256GB | Keycaps | Sleeving | AX1200i
Warning: Spoiler! (Click to show)
The blue LEDs make it run cooler.
You should also get some Apple stickers so it won't get viruses, an Alienware logo so it can play games amazingly and some Razer gear so everyone knows you are totally 1337.
3930K is offline
