H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 47 - Overclock.net - An Overclocking Community
post #461 of 1518 (permalink) Old 07-30-2012, 11:45 AM
semi-legit
candy_van's Avatar
Rep: 800 (Unique: 619)
You guys think a 12mm exhaust fan would fit inside an Arc Mini with a H100 configured as below?
(found these on overclockers.uk)
Looks pretty tight, but I think it might work if I use a fan grill.
I know I could fit a regular 25mm or 20mm fan in the exhaust with the tubing facing the other direction, but I'd prefer the other way (makes it easier to access stuff when needed).
- aesthetics are subjective and opinions are like posterior orifices -
Stugots III
(18 items)
i7 3770K @ 4.5 GHz
ASUS Maximus V Gene
EVGA GTX 1070 Ti
2 x 8GB G.Skill 2133 MHz
250GB Samsung 850-EVO
1TB WD Blue SSD
1TB WD Blue EZEX
2TB Samsung Spinpoint F2
Seasonic X-560W
H100i + NB Pros
Fractal Arc Mini
Operating System
Win 10 x64 Pro
Dell S2716DG
Keyboard
Filco Majistouch I
Mouse
Mionix Naos 7000
Audio
JDS Labs Element
Audio
Beyerdynamic DT-770 Pro (250)
Audio
Audioengine A2s + A8
candy_van is offline
post #462 of 1518 (permalink) Old 08-01-2012, 04:21 AM
Sypherian's Avatar
Rep: 0
Helping a friend building a socket 2011 x79 chipset he has the HAF X case but just found out last night that the H80 as a rear mount in p/p configuration would give clearance issues with the heatsinks on his corsair vengeance ram. Is it possible to mount the H80 in the top instead preferably in p/p configuration?
Sypherian is offline
post #463 of 1518 (permalink) Old 08-04-2012, 04:15 AM - Thread Starter
Rep: 87 (Unique: 80)
Yes, it doesn't really matter where, you may just have to change the configuration of the rest of the airflow for best results. You could also consider mounting the H80 at the rear with one fan on the outside case, the rad and second fan inside, might give you some more breathing room, this is what i did on my CM690. Fan guard recommended if you do go down that route though, you just need a hole for the fan connection to go through which in the HAF X shouldn't be an issue.
Originally Posted by candy_van View Post
You guys think a 12mm exhaust fan would fit inside an Arc Mini with a H100 configured as below? Warning: Spoiler! (Click to show)
The picture you provided shows an exhaust fan, it is just mounted on the outside of the case. As for whether one will fit inside, I'm not going to give an opinion without some close up pics or measurements.
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #464 of 1518 (permalink) Old 08-04-2012, 07:10 AM
Rep: 20 (Unique: 19)
H80 fits the top and rear exhausts of the CM Storm Sniper with P/P config. Posted it on pg44 but wasnt added.
StarCraft 2 NA: SonJaC.113
squall325 is offline
post #465 of 1518 (permalink) Old 08-05-2012, 11:40 PM - Thread Starter
I've added it now, do you have any pics to support it?
post #466 of 1518 (permalink) Old 08-16-2012, 04:04 PM
xXUNLUCKYXx's Avatar
Rep: 3 (Unique: 3)
Got a H100 in my Cosmos 1000 push/pull very slight mod required as is doesnt fully line up with the radiator vent size on the top of the case but works really well .biggrin.gif
xXUNLUCKYXx is offline
post #467 of 1518 (permalink) Old 08-17-2012, 02:44 AM - Thread Starter
Any chance of some pics?
post #468 of 1518 (permalink) Old 08-19-2012, 03:30 AM
Prpntblr95 is offline
post #469 of 1518 (permalink) Old 08-19-2012, 06:57 AM
Ryzen Torturer
Darkstalker420's Avatar
Rep: 20 (Unique: 20)
Hi i have a Lancool K62 Dragonlord case and was wondering if anyone had successfully fitted a H100 into it. I think it's do able but would like to see some pics before i buy a H100.
Thanks.
AMD RyZen R7 1700
ASUS ROG Strix B350-F Gaming
XFX R9 390
16GB Corsairs Vengence [email protected]
Samsung 840EVO 256GB & Seagate 1TB
Corsairs HX750W
Corsairs H110i GT
K62 Dragonlord
Operating System
Windows 10 Pro
SONY 40" V3000 1080p HDTV
Keyboard
Logitech Wireless
Mouse
Logitech Wireless
Mouse
Steelseries
Audio
Xonar DSX
Darkstalker420 is offline
post #470 of 1518 (permalink) Old 08-21-2012, 07:36 AM - Thread Starter
Originally Posted by Prpntblr95 View Post
H100 up top on the Thermaltake V4
(Case is terrible for cable management.)
Thanks, added to initial post.
Thanks.
Not sure, I had a look but couldn't find info specific to your version. The best thing to do is to ask over at the official Dragonlord thread on here. LINK
If you find the right info, with some pics then please come back and give me the link so I can add it to the ever increasing OP.
@all - Thanks for your efforts and information. Thread is now up to > 138K views, glad it is getting some decent traffic.
