H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 49 - Overclock.net - An Overclocking Community
post #481 of 1518 (permalink) Old 10-05-2012, 03:35 PM - Thread Starter
Rep: 87 (Unique: 80)
Originally Posted by jshzigler View Post
Ok so I'm struggling trying to fit the h100 into my define mini. I've removed the hdd cages but the screws don't line up. I'm using the corsair fans that came with the h100. Not sure if I need to brake off the clips that hold the fans in but if I do that how do I keep the fans in there? Any help is appreciated.
Sorry I've been away, just moved from Germany back to the UK.
In this link from page 1 https://www.overclock.net/t/1144409/h80-h100-case-compatibility-thread-page-1-for-full-listings/80#post_15689783 the guy says that he mounted the H100 using only the bottom fan mount.
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #482 of 1518 (permalink) Old 10-07-2012, 03:11 PM
Lizard-Brain's Avatar
Rep: 10 (Unique: 8)
Cooler: Corsair H80
Case: SilverStone Fortress FT01
Fan: Noiseblocker BlackSilentPro 120 mm
Setup: rear, exhaust, push only (push-pull is possible)
more... (Click to show)
Lizard-Brain is offline
post #483 of 1518 (permalink) Old 10-13-2012, 03:46 AM
endy0430's Avatar
Rep: 0
anybody been able to fit the H100 in a silverstone tj09 b?
endy0430 is offline
post #484 of 1518 (permalink) Old 10-13-2012, 12:30 PM
Ever Forward.
PR-Imagery's Avatar
Rep: 231 (Unique: 166)
Check the link for the H100 in the TJ10 in the first post.
It would fit in the top dual 120, but you'd need to either make or buy a radiator support bracket to mount the fan/rad to. Depending on your board, you may or may not be able to do push pull.
The TJ10 has the exact same layout as the TJ09; with my board I can only do push pull over the memory slots/forward 120 mount, and just run push on the rear 120 mount as the 8pin for the cpu is in the way.
You can do push/pull no problem using fans thinner than 25mm (or 25mm on one side, and then a 20mm or thinner on the other) tho.
"The greatest good you can do for another is not just to share your riches but to reveal to him his own."
PR-Imagery is offline
post #485 of 1518 (permalink) Old 11-16-2012, 12:35 PM
Stevoandaredk5's Avatar
Rep: 28 (Unique: 26)
Corsair Vengeance C70 Mid Tower (Green)
H100i in Push/Pull with Corsair SP fans
Top 240mm mount
Had to supply the extra 8 screws required, very tight fit against the Z77 Sabertooth mobo, others might not have an issue.
700
700
700
700
"But I feel ya, I once lived in the times of mac n cheese and ramen noodles just to save pennies for computer gear or other critical items (booze)."
Stevoandaredk5 is offline
post #486 of 1518 (permalink) Old 11-18-2012, 03:47 AM - Thread Starter
Top 240mm mount
Thank you mate, thought this thread was just about done for contributions, first H100i I've seen. I've been real busy of late, so can you tell me, if you know that is, if there is any changes in the physical characteristics of the new H100i that would mean that it can't fit where the H100 does, or vice versa? From the info I could find it doesn't like there is, the rad is the same size.
Nice build btw, I love that board, so clean and tidy!
post #487 of 1518 (permalink) Old 11-23-2012, 12:22 AM
GamerPips's Avatar
Rep: 5 (Unique: 5)
Originally Posted by prey1337 View Post
Has anyone tried mounting these to the pair exhaust fans in the back of a NZXT Zero 2 Case?
My concern is that the radiator will hit the bottom of my PSU, which is fixed in place at that position only.
Here's a link to the case:
You can see in one of the gallery pics that the 120mm fans are right up next to where my PSU sits.
Is my option now left to the H80?
I tried it, doesn't fit.
GamerPips is offline
post #488 of 1518 (permalink) Old 12-06-2012, 02:42 PM
zGunBLADEz's Avatar
Rep: 105 (Unique: 76)
Have an acquaintance who manage to put an H100 on a Corsair 300R is almost in top of the rams tho.. I have my antec 620 like that no problems..
good news for those who want a 300R and a h100..
zGunBLADEz is offline
post #489 of 1518 (permalink) Old 12-14-2012, 11:40 PM
thekingbrah's Avatar
Rep: 0
Hey guys, I've got a Sentey Burton GS-6500 series Full Tower ATX Case.
I was wondering if the H100 could fit using the two 120mm fans up at the top of the case.
I've done some searching but don't seem to positively confirm that it will fit.
If it does fit, I'll probably get an H100 if not, I'll probably buy an H80 instead.
thekingbrah is offline
post #490 of 1518 (permalink) Old 12-17-2012, 03:48 AM - Thread Starter
I can't confirm for you either but basically, if the 2 x 120mm fans are next to eachother, and I mean almost/completely touching then you should be able to use the H100. The fans on the H100 use standard mounts and are next to eachother. Like I say though, no guarantees.
If the fans you have are spaced then the H100 will not fit on those fittings. That doesn't mean you can't MAKE it fit though wink.gif
Just to let people know I do still monitor this thread and update quite often, however due to work etc I'm not as active on these forums as I once was....... stupid firewall blocks this site which means I'm not here when I should be working smile.gif
