H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 56 - Overclock.net - An Overclocking Community
post #551 of 1518 (permalink) Old 01-28-2013, 12:07 AM
Bennakhi's Avatar
Rep: 0
this is my setup:
MB: ASUS P8Z77-M LGA 1155 Intel Z77
Processor: Intel Core i5-3570K Ivy Bridge 3.4GHz
RAM: SAMSUNG 16GB 1600Mhz
CPU Cooler: Corsair H80i
Storage: WD Blue 1TB
Case: SilverStone Temjin Series TJ08B-E
Optical Drive: ASUS Black Blu-ray Burner
VGA: not yet
PSU: Corsair AX850 Gold
SSD: Samsung 840 pro 128GB
When I ran Prime 95 the processor temp reached 72c is this normal with H80i cooler ?
Bennakhi is offline
post #552 of 1518 (permalink) Old 01-28-2013, 06:55 AM
liquidmetal14's Avatar
Rep: 1 (Unique: 1)
Originally Posted by Mattyd893 View Post
The concern in this specific case is not the RAM but the VRM heatsinks on the motherboard...
Normally run horizontally above the CPU socket and/or vertically to the left of the socket is all your power delivery and voltage regulation, dependant on the motherboard it can be quite large. Higher end boards that are designed specifically with OC'ing in mind often have larger velyheatsinks,
Yes, that's something I'm actively researching. I will be getting a Sabertooth x79 and I already have the Corsair 500R.
liquidmetal14 is offline
post #553 of 1518 (permalink) Old 01-28-2013, 12:32 PM
DUpgrade's Avatar
Rep: 78 (Unique: 68)
Originally Posted by Bennakhi View Post
this is my setup:
VGA: not yet
Are you running at stock or overclocking? You should run CPUZ when running Prime95 so we can see what you're running. I also like to use a program called Real Temp to determine temps are. http://www.techpowerup.com/realtemp/
While 75c is a bit high, even for Ivy which can run hotter, also what kind of ambient temps do you have? Do you have your H80i in an exhaust setup or intake setup?
"People willing to trade their freedom for temporary security deserve neither and will lose both." ~ Ben Franklin
DUpgrade is offline
post #554 of 1518 (permalink) Old 01-28-2013, 05:41 PM
Westfields's Avatar
Rep: 1 (Unique: 1)
H80i fits easily in my Azza Solano 1000 case with the exception of the side fan on the case. I had to take the fan off. If I put one fan on the outside of the case and one on the inside it might work as the measurements are so so close...but not sure if I can do that. There was absolutely nothing in the way on my Asus Sabertooth MB...it fit easily and mounted easily. corsair2.jpg 474k .jpg file corsairfan.jpg 1315k .jpg file corsorfan1.jpg 1311k .jpg file
Westfields is offline
post #555 of 1518 (permalink) Old 01-29-2013, 05:32 AM
Imprezzion's Avatar
Rep: 102 (Unique: 89)
I'm running a H100i push pull in a CM690 II Adv. Black & White edition using 2 140mm's in pull between the mesh and the case, then the rad underneath the top of the case and the stock corsair fans in push.
Fits like a glove only it is VERY close to the RAM, hanging above the locks with the fans, and it blocks the EPS 8 pins completely.
Now, I saw a very cheap second hand case I wanna use for a second S1366 build with a H100i as well but I dunno if it'll fit..
So, does a H100i in either Push or Pull or Both fit in a Aerocool Strike-X Advance (White Blue)?
Judging by the pics it might fit in the top just like the CM690 II has. Even in p+p but there's no confirmation anywhere.
Cars:
-Crashed: (not my fault ) '94 Nissan 100NX GA16DE (a.k.a. NX1600). Renault Laguna Phase I facelift '99 1.6 K4M. (Broke a strut and smacked a tree).
-Sold: '00 Nissan Primera P11-144 QG18DE, '97 Honda Prelude F20A4, 03 Ignis Sport.
-Current daily: '07 Ford Focus 1.6 Futura.
-Current funcars: '03 Peugeot 206CC 2.0 RFN fully riced and tuned (Turbo coming soon)
Full-On Rainbowbarf
(16 items)
P45 power!
(9 items)
i9 9900K @ 5.1Ghz 1.248v
MSI MEG Z390 ACE
MSI Armor GTX1080 Ti w/ Accelero IV @ 2063/6500Mhz
Corsair Vengeance RGB B-Die @ 4200 16-17-17-28-280-2T 1.54v
Samsung 850 EVO 500GB x2
Samsung 970 Evo 1TB
Seasonic Focus Plus Gold 750W
EK MLC-Phoenix 280 Kit
Phanteks Enthoo Evolv X
Operating System
Windows 10 Pro X64
Samsung S27B350H @ 1080p 75Hz OC
Iiyama GB2788HS @ 144Hz
Keyboard
Logitech G710+
Mouse
Trust GXT31
Mousepad
Corsair MM300 Large
Audio
Steelseries Siberia V2
Intel Core 2 Quad Q6600 G0 @ 3Ghz (333x9)
MSI P45 Neo2-FR
MSI GTX760 Gaming X
6GB completely random 1 and 2GB sticks. All 4 different ones.
A-Data 120GB SSD
AOpen 350w
Some huge aluminum Xeon heatsink
Cartboard box.
Operating System
W10 Pro x64
Intel Xeon E3-1270v1 @ 3.8Ghz
ASUS P8H61-i R2.0
Sapphire R9 280X Vapor-X @ 1230Mhz core.
16GB Kingston HyperX Savage 2400CL11 @ 1333CL6
Kingston 240GB SSD
Corsair CX600
Corsair H110i GTX
Custom open test bench made from a cut-up CM690 v1
Operating System
W10 Pro X64
Samsung 23" cheap thing
Keyboard
Cheapest one Aldi had
Mouse
Mousepad
The desk...
Imprezzion is offline
post #556 of 1518 (permalink) Old 01-29-2013, 08:09 AM
Rep: 18 (Unique: 15)
Edit: Moved to an appropriate thread.
BenC is offline
post #557 of 1518 (permalink) Old 01-29-2013, 08:44 AM
DUpgrade's Avatar
Originally Posted by BenC View Post
I've finally decided it is time to retire the Thermaltake Armor 2 I've been using for 9 years now.
My biggest goal is to mount my radiator vertically within the case. Here is the catch; I am using a Swiftech MCR220.
The internal reservoir adds a bit of height to the radiator.
I've been hoping to attach the rad push/pull, rad inside the door of either a http://www.newegg.com/Product/Product.aspx?Item=N82E16811139010] Corsair 500r,
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008] 400R, or something similar.
I do not mind modding the door a bit.
Any input suggestions?
Cheers.
DUpgrade is offline
post #558 of 1518 (permalink) Old 01-29-2013, 08:58 AM
Deleted by User.
BenC is offline
post #559 of 1518 (permalink) Old 01-30-2013, 10:02 AM
Lordfire's Avatar
Rep: 0
Just for the lulz:
H40 did not fit my Thermaltake V3. Who cares?
Lordfire is offline
post #560 of 1518 (permalink) Old 01-30-2013, 10:16 AM - Thread Starter
Rep: 87 (Unique: 80)
This is the first time I've heard of this case so had a look but couldn't find anything definitive.
The case you're looking at has a good review and internal pics here http://www.techpowerup.com/reviews/Aerocool/Strike-X_Advance/5.html
The cases bigger brother the Strike-X ST has a horrendous amount of room.. http://forum.donanimhaber.com/m_64501864/tm.htm
Is this a done deal? Or are you open to other cases?
Originally Posted by Lordfire View Post
Just for the lulz:
H40 did not fit my Thermaltake V3. Who cares? Warning: Spoiler! (Click to show)
The first Azza for the thread, I shall add it to the OP! Thanks
Reference the fan, no problems with putting a fan on the outside as long as you have somewhere to route the fan cable. I once did the same on a CM690 Std simply to give more room inside the case. It had no effect on cooling or performance.
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
