H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 64 - Overclock.net - An Overclocking Community
post #631 of 1518 (permalink) Old 02-25-2013, 10:31 PM
kritis's Avatar
Rep: 0
Originally Posted by DUpgrade View Post
^ Do you have a drill or dremel tool to take off the little bit of the edge of that side panel door?
No I don't tongue.gif I'll probably look though my screw collection and try to find one with a flatter head.
kritis is offline
post #632 of 1518 (permalink) Old 02-26-2013, 08:17 AM
7Shinoda's Avatar
Rep: 1 (Unique: 1)
I Can confirm that the H100 can easily fit inside a NZXT Switch 810 thumb.gif
also there is enough space on the top for a PUSH/PULL configuration
haven't tested if it can hold the radiator on the front/botton by removing the HDD cage
7Shinoda is offline
post #633 of 1518 (permalink) Old 02-26-2013, 08:32 AM
Ultimate Rig Winner
PedroC1999's Avatar
Rep: 315 (Unique: 220)
Will a H100i push/pull fit in a Zalman Z9 Plus?
PedroC1999 is offline
post #634 of 1518 (permalink) Old 02-27-2013, 07:10 PM
Nathan1's Avatar
Rep: 0
nvm
Nathan1 is offline
post #635 of 1518 (permalink) Old 02-28-2013, 01:24 AM
SeD669's Avatar
Rep: 17 (Unique: 14)
Hi there,
Just wondering if anyone else has had any experience of fitting a H80i into a Nanoxia Deep Silence 1 case please?
I know it will not fit on the rear of the case as this is for a 140mm fan, but I was hoping that the H80i could fit into one of the front case fan mounts as they are 120mm or if there is clearance possibly at the top?
Any help greatly appreciated!
Should be able to fit at the front from memory
SeD669 is offline
post #636 of 1518 (permalink) Old 03-02-2013, 03:51 AM - Thread Starter
Rep: 87 (Unique: 80)
Looking at the case I would say it would be very tight looking at how high the ATX backplate is and the amount of room to the top of the case, doesn't look like you can mount the fans externally either. I can't confirm or deny but it doesn't look promising.
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #637 of 1518 (permalink) Old 03-02-2013, 04:12 PM
NIK1's Avatar
Rep: 2 (Unique: 2)
Will a H100i push/pull fit in a Cooler Master Storm Trooper case.Just have it hooked up push for now exhausting out.
Nick's Gaming PC
(12 items)
I7-7700K
Asus Z270 IX Apex
Asus Dual-RTX2070-O8G
G Skill TridentZ/16 Gigs 2X8 RGB F4-3600C16-8GTZR
Samsung SSD 850 EVO 1TB (931 GB)
Force MP500 (111 GB)
TOSHIBA MQ01ABD050 (465 GB)
CORSAIR CX850M V2 (2017 Edition) CP-9020157-NA 850W
Swiftech H240X WaterCooler
CoolerMaster Mastercase 5 Pro
Operating System
Microsoft Windows 10 Pro
AOC U3277WB
NIK1 is offline
post #638 of 1518 (permalink) Old 03-02-2013, 04:34 PM
Kiracubed's Avatar
Rep: 2 (Unique: 2)
Just got 2 sets of the Corsair SP120 Quiet edition for a Push/Pull setup in my Corsair 650D...
And to my disappointment, they DO NOT fit! I have the bottom two fans screwed in fine, and it fits perfectly with just one pair of them bottom mounted. I placed the other two fans on top, and tried to fit it in, and it would not get in the right holes (inb4 that's what she said).
I'm using the Corsair 650D, tried to set up with the SP120 Quiet edition fans, and am using an ASRock Extreme 4 mobo.
Any suggestions on how to make it fit?
Also, in the chance it just won't, which option is best for one pair of fans? The bottom mounted fans in push (blowing upward), or pull (blowing downward into case)? I'm a bit of a noob with fans, and the SP120s don't have the arrows, but I suppose it's not needed since the back bracket is where it blows out from.
Kiracubed is offline
post #639 of 1518 (permalink) Old 03-02-2013, 05:29 PM
denman's Avatar
Rep: 63 (Unique: 59)
Can you post a pic? I'm using the SP120 push/pull on the rear (inside case) on my Corsair 400R (smaller case than yours) il with asrock extreme4z77 MOBO and it fits with plenty of room.
denman is offline
post #640 of 1518 (permalink) Old 03-02-2013, 07:11 PM
Kiracubed's Avatar
Rep: 2 (Unique: 2)
I'm trying top mounted with an H100.
