H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 66 - Overclock.net - An Overclocking Community
post #651 of 1518 (permalink) Old 03-07-2013, 10:01 AM
TomcatV's Avatar
Rep: 170 (Unique: 126)
Originally Posted by bencher View Post
i bought a h100i today and tried fitting it in my haf 922.
Was really disappointed and upset.
IT DOES NOT FIT....
The first 4 screw holes line up, but the second 4 are way off.
Did anyone experience this?
YES ... and I notified Matty of this with my link HERE post#19907 ... Why Matty didn't include it I don't know, and then mislinks a CM690 under the HAF922 heading rolleyes.gif
@Matty ... You know I commend your thread and work done ... see HERE post#509 ...
For example the H100/HAF922 should read ...
HAF 922
Fits top in Push or Pull (with slight mod's), P/P only w/2of4 fans outside the case - links - LINK
From my link above ... Quote November 2011 ...
My biggest concern was if the H100 would fit in my case without considerable modding. I searched high and low for information on the above combination. No joy anywhere The ASRock E4/G3 has fairly tall heatsinks! With the H100 in hand, I intially didn't think it would clear the uppermost heatsink and still be able to use the 120mm fan hole alignment on top? :O It did clear by 3/16ths of an inch (see pic). I did have to extend (dremmel) 2 of the mounting holes about a 1/4" to have 6 total mounting screws (not 8) and its plenty secure!
Originally Posted by Fahrenheit85 View Post
Howdy y'all, any idea how the H110 will fit in a P280? Would love to do this with 2 Nocturia 140 fans. Does it make more sense to push outside air over the rad and into the case? Or pull air from the case to outside? In my head it makes more sense to pull from the case to outside to keep the case ambient temp down.
The H100(i) is essentially the same concept as the H110, But it can depend on your case circulation to begin with, your Overclocks (heat generated) /and your ambients. In the above examle, I have an additional Silverstone FM121 high CFM running @1500rpm as an additional front intake providing more fresh/cool air to the H100. With my setup (Top/Exhaust/Push) all my case components ran cooler with my Mobo as much as 3c-5c cooler while only loosing 1c-2c on my CPU cooling, and dust management of the radiator is signifigantly reduced ... have a read through the Corsair Hydro forum HERE searching H100 or just take my word for it ... hope that helps thumb.gif
TomcatV is offline
post #652 of 1518 (permalink) Old 03-08-2013, 11:58 PM
Funcrazy1's Avatar
Rep: 57 (Unique: 53)
im really looking into getting one of this cooling systems but what one works with the nzxt tempest case?
Funcrazy1 is offline
post #653 of 1518 (permalink) Old 03-09-2013, 02:47 AM
ARCbuilder's Avatar
Rep: 1 (Unique: 1)
H100i (with bigger tubes) fits great in the Fractal Arc MINI (no push pull).
Replaced the exhaust fan with a slim one, just in case.... But regular fan thickness would have worked as well.
Temp idle: 23-30 degrees Celcius
Temp load: max 60 degrees
Stable & quiet OC: 4,7 Ghz
Managed max 5,3 Ghz, but not very stable and the PSU couldn't cope with it. (AX750)biggrin.gif
Some pictures:
ARCbuilder is offline
post #654 of 1518 (permalink) Old 03-09-2013, 05:23 AM - Thread Starter
Rep: 87 (Unique: 80)
The Tempest is listed on page 1.
@All - New info added to the OP, if I missed anyone then please let me know!
@TomcatV - OP modified reference your comments, must have missed it before or forgot to modify the OP! Cheers! thumb.gif
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #655 of 1518 (permalink) Old 03-09-2013, 12:15 PM
Funcrazy1's Avatar
I notice that its posted but thats a nzxt tempest 410 is that the same as the original tempest when it first came out?
post #656 of 1518 (permalink) Old 03-09-2013, 06:13 PM
Baking Cookies
BonzaiTree's Avatar
Rep: 46 (Unique: 39)
Would the h110 fit in a Cooler Master HAF X?
I'm sure it would with some modifications, but I'm wondering if it would without any.
2009 WRX with 298awhp/304awtq (SOLD)
2016 WRX (Daily driver)
BonzaiTree is offline
post #657 of 1518 (permalink) Old 03-10-2013, 03:23 AM - Thread Starter
I can't answer that as I'm not familiar with the original version. You could always ask over at NZXT Tempest User Community
Well I'm sure there is plenty of room the only issue would be the mounting points, if you have 2 x 140mm fan mounts in the top it should fit depending on the spacing, judging by the number of custom loops done in HAF X cases, I don't think there will be an issue but no guarantees.
post #658 of 1518 (permalink) Old 03-10-2013, 09:55 AM
Baking Cookies
BonzaiTree's Avatar
There are two 200mm fans on top of the HAF X I believe, but I'm not sure if they include mounts for two 140's.
And really, I suppose it wouldn't be a big deal if I had to drill a few holes, lol.
I don't have the case yet, just curious.
post #659 of 1518 (permalink) Old 03-10-2013, 10:37 AM
dezmick's Avatar
Rep: 1 (Unique: 1)
I am wanting to know if a H90 will fit in a Corsair 650 D at the rear exhaust fan location, or if my only option would be to mount it up top. Thanks: Mick
dezmick is offline
post #660 of 1518 (permalink) Old 03-10-2013, 12:48 PM
Rep: 7 (Unique: 5)
Would the h110 fit on the top of a 500r?
I can't seem to find any confirmation on it throughout the internet.
Core I9-9900k @ 5.1
Asus Maximus XI Gene
EVGA 2080TI XC Black Edition
CMK16GX4M2K4700C19
Samsung 970 Evo m.2 nvme
Silverstone SFX-L 800W
280mm Slim + 360MM Thick
Fractal Design Meshify S2
Operating System
Windows 10 64bit
Acer XB271HU
Audio
Sennheiser HD 800s + Questyle CMA600i
xSneak is offline
